camchain
WULFSTAN
PostPosted: 18:00 - 25 Apr 2012    Post subject: camchain Reply with quote
alright lads so ive got camchain rattle when its cold.can anyone give me a idea how many miles ive got till i have to sort it as money is a bit tight cheers. Thumbs Up its a 1990 cbr 600 with 50000k on
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Budgetboy
PostPosted: 18:31 - 25 Apr 2012    Post subject: Reply with quote
Just done a camchain on a ZZR im making into a trackbike.
I would say if its only like it when cold you have a good 10-15k left..
This is the chain i took out after 140,000 miles on left, new on right.You get stiff links over time, which (can) make it jump the teeth on the cam chain gear.But i would say you will be fine for a bit.
Expensive job though.. Engine out,split cases..
https://img405.imageshack.us/img405/92/zzrrebuild143.jpg
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
WULFSTAN
PostPosted: 18:41 - 25 Apr 2012    Post subject: Reply with quote
right so the plan looks to be run this engine into the ground and put the 17k engine i got lieing about didnt wont to but needs must thanks mate for the quick answer Thumbs Up
mab
PostPosted: 19:10 - 25 Apr 2012    Post subject: Reply with quote
Is it still running the stock cam chain tensioner? if so, you may be able to sort the noise out by replacing it with a manual one
Budgetboy
PostPosted: 19:16 - 25 Apr 2012    Post subject: Reply with quote
Not a problem mate. Thumbs Up
Timmeh
Cam chain rattle when cold is normal for CBR600s.
As is the clutch basket whine.
My first CCT lasted nearly 70k before needing replacing.
WULFSTAN
PostPosted: 19:35 - 25 Apr 2012    Post subject: Reply with quote
thanks for the info Thumbs Up
69chris
PostPosted: 14:23 - 26 Apr 2012    Post subject: Reply with quote
unless you need to get in the engne for something else why split the cases ?????
i'v done loads of c/chains with the engine still fitted by just cutting the old chain, feeding the new one in fixed to the old and refttng the new one using a rivet link
surely im not alone on this one Confused
bodger
PostPosted: 14:29 - 26 Apr 2012    Post subject: Reply with quote
This is standard practice in my book. Thumbs Up but then some might sqirm a bit doing it this way
Budgetboy
PostPosted: 15:22 - 26 Apr 2012    Post subject: Reply with quote
Well i would not do that.But thats my opinion.
I tend to look at it this way.. A motorcycle chain comes to you split with a link.. A camchain comes to you UN-split.. i wonder why?
The cam chain goes at a far far faster rate than your drive chain and by knocking out a link pin and replacing it you weaken the chain.
Just my opinion mind. Wink
The last post was made 14 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 66.62 Kb
