Bike wont start!!!!!!
burnleyman188...
PostPosted: 17:39 - 30 Apr 2012    Post subject: Bike wont start!!!!!! Reply with quote
Hi, i have a 2007 honda cg, and it wont start. When i turn on the ignition and try to start it all i get is the sound that it makes trying to start. i have absolutly no idea what the problem is.
cheers.
J.Cook
at106
PostPosted: 18:21 - 30 Apr 2012    Post subject: Reply with quote
Has it got fuel?
Is the spark plug wet?
Does the spark plug spark?
burnleyman188...
PostPosted: 10:40 - 01 May 2012    Post subject: Reply with quote
at106 wrote:
Has it got fuel?
yeah it has got fuel, the spark plug shouldnt be wet as i havent taken the little cover thing off it and how do i check to see if it sparking?
J.Cook
Sako
PostPosted: 10:49 - 01 May 2012    Post subject: Reply with quote
when you remove the spark plug, what is the state of the plug?
at106
PostPosted: 11:54 - 01 May 2012    Post subject: Reply with quote
burnleyman1882 wrote:
at106 wrote:
Has it got fuel?
What i mean is when you remove the spark plug from the engine does it have fuel on it?
To see if it has a spark, remove the plug, fit the spark plug cap and earth the threads on any metal part of the bike (engine) then press the elctric start button, you should see a bright blue spark.
PostPosted: 13:05 - 01 May 2012    Post subject: Reply with quote
Check the kill switch.
Is the fuel tap on? Unless you're 100% sure that there's plenty of fuel, set it to reserve.
Crank the bike.
Remove the spark plug. You'll need a deep socket - there may be one in your bike's tool kit.
Sniff the tip - do you smell fuel. Look at the colour of the tip and compare it to this chart.
https://kereta.info/wp-content/uploads/2009/07/spark-plug-colour.jpg
Re-attach the HT lead to the spark plug. Hold the plug firmly against the engine using insulated pliers (I don't think it goes without saying in this case).
https://0.tqn.com/d/autorepair/1/0/0/5/-/-/coiltest-sprk.jpg
Crank the engine again. Look for a spark at the end of the plug.
Sniff the plug hole. Can you smell fuel?
Bet it's the kill switch though. Wink
cb1rocket
PostPosted: 13:28 - 01 May 2012    Post subject: Reply with quote
battery on the way out?
Fuel tank got petrol?
Check for spark as others have said, you have to work in a logical fashion!
truslack
PostPosted: 15:04 - 01 May 2012    Post subject: Reply with quote
Or just hold the plug cap instead of the metal?
PostPosted: 15:53 - 01 May 2012    Post subject: Reply with quote
As sir likes, but I've been shocked by complacency and a dodgy cap before. Now I used insulated pliers - or at least rubberised gloves - on the cap.
Given the tone of the OP's post, I'd rather that he was over- rather than under-cautious - remember, there's something wrong with the bike.
The last post was made 14 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 61.55 Kb
