Run out of fuel grrr
pendulum
PostPosted: 17:09 - 10 May 2012    Post subject: Run out of fuel grrr Reply with quote
Spent hour and a half waiting for the AA to come, I'd run out of fuel Thumbs Down
Felt engine running lumpy and thought it was low fuel, so for the first time ever I reached down and turned the tap to Reserve (or at least I think I did, see below) but nope, no help.
Two possibilities. The tap doesn't work properly, or I've been a twat and been setting it to run on Reserve ever since I've owned the bike thinking it was main tank
So can anyone confirm the status of the fuel guage (on my CG125) in this pic:
https://ccgi.pendulum.plus.com/fuel.jpg
I've been thinking that's main tank, and to get Reserve I have to turn it down fully, with off being "in the middle" (handle horizontal)
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
moppy
PostPosted: 17:12 - 10 May 2012    Post subject: Reply with quote
Pointing up is usually reserve, down is normal. I think.
pendulum
PostPosted: 17:13 - 10 May 2012    Post subject: Reply with quote
Rolling Eyes What a twat I've been if that's true.
Muscle Bike Rider
PostPosted: 17:18 - 10 May 2012    Post subject: Reply with quote
Up = reserve
Down = main Tank
Laughing Laughing Laughing Laughing Laughing Laughing
your not the first and wont be the last!
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
pendulum
PostPosted: 18:17 - 10 May 2012    Post subject: Reply with quote
*sighs*, well I won't make that mistake again.
Thanks.
bikertomm
PostPosted: 20:10 - 10 May 2012    Post subject: Reply with quote
Yep, your just on normal 'fuel on' from the main tank, a turn to the left would be 'fuel off' and then up is reserve Thumbs Up
MattJ
PostPosted: 20:15 - 10 May 2012    Post subject: Reply with quote
What Chris said. The pointy bit of the tap (at the bottom on that pic) is the bit that points to what position it is in. In that picture it is pointing down and is in the 'Res' position, a 90 degree turn anti-clockwise would turn it to 'Off' and a further 90 degree turn anti-clockwise would turn it to 'On'.
bikertomm
PostPosted: 20:25 - 10 May 2012    Post subject: Reply with quote
Thinking On my xr 125, which is similar, the down position is fuel on, just like the one in the picture.
bikertomm
PostPosted: 20:29 - 10 May 2012    Post subject: Reply with quote
https://i1145.photobucket.com/albums/o520/bikerrtomm/014-1.jpg
https://i1145.photobucket.com/albums/o520/bikerrtomm/016-1.jpg
tbourner
PostPosted: 20:34 - 10 May 2012    Post subject: Reply with quote
Should have a little picture on it, point the arrow to the picture of the bowl that's full of fluid, on the bottom of the tap should be a bowl with only a little bit of fluid in it which is reserve.
Trev, now a biker?
Looking for first big bike.
MattJ
PostPosted: 20:36 - 10 May 2012    Post subject: Reply with quote
On my CG there were no pictures. Just as I described:
Down - Res
Middle - Off
Up - On
It's really that simple.
johnsmith222
PostPosted: 21:25 - 10 May 2012    Post subject: Reply with quote
I think people in this thread need to remember that fuel taps can be either way. The RXS is the opposite layout to my CG125.
Chris is right. Thumbs Up
bikertomm
PostPosted: 21:51 - 10 May 2012    Post subject: Reply with quote
Ahh I see Thumbs Up
I would have thought they would all be fairly similar, even across makes and models! Obviously not.
Bomberman
PostPosted: 23:01 - 10 May 2012    Post subject: Reply with quote
Fairly similar, but not the same... Wink
tomh
PostPosted: 18:55 - 11 May 2012    Post subject: Reply with quote
If you shine a torch onto the tap it says the positions on it.
On my 2001 CG it's
Fuel
Off
Res
Turning the tap anti-clockwise will put the tank on.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0542.jpg?t=1336762029
Turning the tap clockwise will put the tank onto reserve.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0538.jpg?t=1336762066
If you've used all your fuel up then you should check and clean the fuel filter by turning the tap to off and then undoing the bolt on the bottom of the tap.
While you have the filter out try the tap in both positions to check if the reserve/main pipe is blocked. (assuming you now have petrol in the bike).
pendulum
PostPosted: 20:21 - 11 May 2012    Post subject: Reply with quote
Thanks all, especially TomH, I will check the fuel filter and tap in the morning. I did try looking closely for markings on the fuel tap whilst trying to keep myself amused for 2 hours at the side of the road but unfortunately mine's too old & grubby to really make the markings out, perhaps if I cleaned it well I might be able to see! But those pics are really helpful and confirm what I've been doing wrong Laughing
blurredman
PostPosted: 20:36 - 11 May 2012    Post subject: Reply with quote
Yup, up is on.
Jim Mc
PostPosted: 07:01 - 12 May 2012    Post subject: Reply with quote
Strange that the CBR125 doesn't have a reserve, same engine isn't it? Just no tap that I've ever seen.
Bit fkin pointless if it's drawing fuel from the same tank, it's like a Blonde's accessory.
tbourner
PostPosted: 07:09 - 12 May 2012    Post subject: Reply with quote
Fuel injected models don't have one?
Trev, now a biker?
Jim Mc
PostPosted: 11:47 - 12 May 2012    Post subject: Reply with quote
No it was 2004 model, had a carb and was gravity/vacuum fed.
Scythe
PostPosted: 12:27 - 12 May 2012    Post subject: Reply with quote
Does it have a fuel gauge / light? If you have a gauge or a light, you don't really need a tap.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Moxey
PostPosted: 13:34 - 12 May 2012    Post subject: Reply with quote
If talking about the CG and the CBR no the engines are different one is an air cooled push rod engine the other water cooled SOHC, anyway the Japs seem to enjoy making minor alterations that seemingly yield no practical benefit.
Oh and I do believe the CBR 125 has a fuel tap.
Bomberman
PostPosted: 13:56 - 12 May 2012    Post subject: Reply with quote
I don't think any bikes actually have a separate reserve tank... It's to let you know you're low on fuel, not to actually switch tanks.
The last post was made 13 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 117.39 Kb
