CLOSED bought CHAIN
McfcChris94
PostPosted: 09:25 - 15 May 2012    Post subject: CLOSED bought CHAIN Reply with quote
Hi, got all my gear and now need a lock Smile
I can't pay too much, preferably £20 but 30 at a push, but In the future this would definitely get upgraded Smile
Iv been looking on amazon because I have a voucher I can use,
What do you guys suggest?
Quite a few ones that are 2.5KG but about 1 metre
What you think?
CBT Passed; 13/05/2012
Current; Honda CG 125
DrDonnyBrago
PostPosted: 09:36 - 15 May 2012    Post subject: Re: Good and Heavy Lock/Chain Reply with quote
At that sort of money the chain will be a deterrent to the casual thief rather than a game stopper for the professionals (TBH all chains are to an extent - better ones are just harder to hand crop, can still be cut other ways).
In which case, you just want to get the one with the thickest links you can find. 12mm+ thick links look substantial, below 10mm or so looks comically thin to be securing a motorcycle with.
However, if I only had £30 to spend on a chain and lock I'd buy some grade 80/100 load chain on gayBay. It is impossible to get a tougher motorcycle chain for the same price.
This stuff is £20 a metre, has 16mm toughened links and will be an utter ball ache/impossible to crop by hand:
https://www.ebay.co.uk/itm/16mm-Tested-Chain-Grade-80-BS-EN818-WLL-8000kgs-/310291128595?pt=UK_Lifting_Moving_Equipment&hash=item483ecae113#ht_643wt_908
SLightly thinner (13mm) and cheaper (£17/m):
https://www.ebay.co.uk/itm/13mm-Tested-Chain-Grade-80-BS-EN818-WLL-5300kgs-/250763590827?pt=UK_Lifting_Moving_Equipment&hash=item3a62acbcab#ht_643wt_908
If you can find it second hand then it will be peanuts/free as it is essentially scrap metal to industry after a period of use.
Sload
PostPosted: 09:39 - 15 May 2012    Post subject: Reply with quote
That looks similar to the lifting chains we use at work, pretty strong stuff
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
McfcChris94
PostPosted: 09:46 - 15 May 2012    Post subject: Reply with quote
Then find a strong padlock Smile
McfcChris94
PostPosted: 09:49 - 15 May 2012    Post subject: Reply with quote
What does this look like
https://www.amazon.co.uk/gp/aw/d/B001DI4JUK/ref=aw_d_detail?pd=1&qid=1337071671&sr=8-7
DrDonnyBrago
PostPosted: 10:28 - 15 May 2012    Post subject: Reply with quote
Shit.
EazyDuz
PostPosted: 10:29 - 15 May 2012    Post subject: Reply with quote
To be fair the chain is only as good as the lock holding it together, so you will need to spend a lot of money for a good quality lock...
I think an alarmed disk lock would be a better investment, and a cheap thinner chain just as a visual deterrant
McfcChris94
PostPosted: 10:33 - 15 May 2012    Post subject: Reply with quote
The CG is on a drum brake not disk
EazyDuz
PostPosted: 10:44 - 15 May 2012    Post subject: Reply with quote
What front and rear brakes are drums? Ok, you can get alarmed padlocks, thats what i use on mine. Sirens if it gets moved
Alpha-9
PostPosted: 11:47 - 15 May 2012    Post subject: Reply with quote
Yep.
And yeah you've got the gear...but have you got a bike yet? Rolling Eyes
Just make one decision on your own, just once, you might like it, who knows Razz
Personally I used a £40 "mammoth" chain alike the one you linked actually, it's heavy and the lock seems good quality but the chain isn't that amazing, you can see the weld 'creases' on the links but I think it'd stop most nubs, but I think my kryptonite bicycle lock is better
and a kryptonite bicycle D-lock
The d-lock is great because its hardcore and easy to carry around, I just attach it to my top box rack thing
Fzr-600 1999
McfcChris94
PostPosted: 11:52 - 15 May 2012    Post subject: Reply with quote
The d-lock is great because its hardcore and easy to carry around, I just attach it to my top box rack thing[/quote]
Iv made 4 solo decisions now Razz
Jacket I got
Gloves
Helmet
Where to do CBT Wink
It's a toss up between Oxford HD or a bright green mammoth one (it's £50)
snikks
PostPosted: 12:00 - 15 May 2012    Post subject: Reply with quote
As everyone here has said it's possible to get some good quality chain within your budget, but probably not with a decent lock as well.
Personally I have an alarm, a cheap chain and padlock, and a disc-lock, and just accept that if a professional thief should decide they're desperate for my bike - it will be going along with them. The security should hopefully enough to deter scrotes and casuals, which is all any security can really do, although some may do it more effectively.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
DrSnoosnoo
PostPosted: 13:44 - 15 May 2012    Post subject: Reply with quote
I bought a disk lock (bright yellow with bright yellow minder) for £20 and a chain and lock for about £40 from J&S to make it "look" secure. It's got a cheap-ish alarm on the bike too which makes a noise to try and deter the robbin' AR$£ bandits. We also found out yesterday my mate's car exhaust can set the alarm off so it's quite sensitive!
McfcChris94
PostPosted: 13:50 - 15 May 2012    Post subject: Reply with quote
Might get a mammoth lock for £45
Alpha-9
PostPosted: 13:56 - 15 May 2012    Post subject: Reply with quote
It looks better than it is I think
Heavy and massive and a cunt to carry around too, I have to carry a backpack with it in when I plan to use it, my mate wears his lock around his shoulder lol, wouldnt fancy coming off a bike with a chain wrapped round me Thumbs Down
Better than nowt, but useless without something to anchor it too, they cna just pick it up!
A good tip I heard on hear somewhere is to chain up the front wheel if you only have the one chain, it's apparently easier to lift the bike from the back and roll it on the front wheel than the other way around
Disc locks highly recommended though, not that I have one
Fzr-600 1999
McfcChris94
PostPosted: 15:14 - 15 May 2012    Post subject: Reply with quote
So maybe a cheap Oxford plus something else to go with it?
PostPosted: 15:49 - 15 May 2012    Post subject: Reply with quote
You've bought a bike? Pictures!
GrumpyGuts
PostPosted: 15:53 - 15 May 2012    Post subject: Reply with quote
NOW!!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Alpha-9
PostPosted: 15:54 - 15 May 2012    Post subject: Reply with quote
It's a hypothetical CG Wink
Fzr-600 1999
GrumpyGuts
PostPosted: 15:58 - 15 May 2012    Post subject: Reply with quote
Oh...so he is getting a lock based on a CG that doesn't exist?
recman
PostPosted: 16:01 - 15 May 2012    Post subject: Reply with quote
If you can do it, go for this and get this free. Thumbs Up
EazyDuz
PostPosted: 16:27 - 15 May 2012    Post subject: Reply with quote
you may as well get this:
https://www.ebay.co.uk/itm/MOTORCYCLE-MOTORBIKE-BIKE-SECURITY-CHAIN-DISC-LOCK-1M-/270496036571?pt=UK_Motorcycle_Parts&hash=item3efad1f6db
Any chain is a visual deterrant, and that one has sold loads on ebay
McfcChris94
PostPosted: 17:04 - 15 May 2012    Post subject: Reply with quote
Should have it by weekend, the owner is someone off the forums Razz
He needs to sort the twisted subframe first Wink
EazyDuz
PostPosted: 17:06 - 15 May 2012    Post subject: Reply with quote
Serious?
McfcChris94
PostPosted: 17:29 - 15 May 2012    Post subject: Reply with quote
Its Tongue in cheek, hence the - Wink - face
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 131.31 Kb
