Can chains go bad in a few days?
hazza
PostPosted: 07:09 - 17 May 2012    Post subject: Can chains go bad in a few days? Reply with quote
Hi,
My bandit chain seems to have gone from being OK to worn out in two days. I parked it up friday, adjusted the chain and lubed it as i do every week (lube not adjust!) come to use the bike monday and it seems a bit vibey, when slowing down it chugs!. Turning the wheel on the centre stand there seems to be a really tight area of the chain. I was aware I had a couple of tight links but its never made this horrible noise before!
Is it worth slackening off the chain, winding the adjusters all the way in and starting again before buying a new chain? Could I really have got the adjustment that off centre to cause this? Ive never had any problems adjusting a chain before!
Thanks
Harry.
Sload
PostPosted: 07:21 - 17 May 2012    Post subject: Reply with quote
Redo your adjustment and checks and go from there.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
defblade
PostPosted: 07:23 - 17 May 2012    Post subject: Reply with quote
Sounds like it's siezed up in during the 2 days stood... tight links always seeem to get worse for me, no matter what I do, so they've probably just reached that "too much" point.
I'd say save time and possibly further wear and tear and just get a new chain on there.
hazza
PostPosted: 07:55 - 17 May 2012    Post subject: Reply with quote
Its very annoying as i clean and lube the chain every week (ish) i cant understand why its gone from fine to bust it 2 days! I will first try and check the adjustments again but as i say it has a spot in its rotation that is very very tight (few cm play at the most ) and rotating past this i have a few inches! Obviously it jumps around like a good 'un when riding.
AndyB1989
PostPosted: 09:48 - 17 May 2012    Post subject: Reply with quote
lube and manipulate the tight spot and try to free it off as best you can ?
doggone
PostPosted: 10:00 - 17 May 2012    Post subject: Reply with quote
They do go downhill very fast towards the end, I imagine once one or two link pivots have started to fail internally, it puts far more stress on the adjacent ones.
Jefr0
PostPosted: 10:35 - 17 May 2012    Post subject: Reply with quote
Glad it wasn't just me!
I lube and adjust my chain weekly, always looking after it and now I have a tight spot as normal but the rest is loose.
Guess it's new chain time!
I had a gold X ring chain on there, thought it was a good one, is there any particular ones to get or do they all do this eventually?
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
c_dug
PostPosted: 10:54 - 17 May 2012    Post subject: Reply with quote
Lifes a bitch, at the most I lube my chain once a month, which is a little over 1000 miles.
No stiff links, not stretching at all, very rarely needs adjusting. Done nearly 10,000 miles with it so far.
Wish you were me? Razz
nisp
PostPosted: 12:12 - 17 May 2012    Post subject: Reply with quote
If it sounds like a 50's bus. Just by a new chain they all go eventualy
if you buy a new chain don't over tighten the soft link...
can over tighten them and create can be a tight spot making it not so bendy... and making you need a new chain/link.
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
hazza
PostPosted: 12:15 - 17 May 2012    Post subject: Reply with quote
Its a split link! Its just annoying as theres no point changing the chain without the sprockets so it looks like an £80 bill for me Shocked
O well such is life.
Mrjoolz
PostPosted: 12:17 - 17 May 2012    Post subject: Reply with quote
Make sure that when you adjust chain, you do this at the tightest point. Else if you choose the slacker area and adjust, then the tightest part will be so tight and could well make noises you mention
just a though
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
nisp
PostPosted: 12:18 - 17 May 2012    Post subject: Reply with quote
shaft drive........ Mr. Green
I paid £120 for a chain and sprockets. so you should feel smug Crying or Very sad
The last post was made 13 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 72.33 Kb
