| Harley |
 Harley Two Stroke Sniffer
 Posted: 00:14 - 15 May 2012 Post subject: First build custom Honda cm and Yamaha xj 400 |
So this is my first post and also my first build, I have been riding bikes since I was about 14 and have so far had 5 bikes on the road ( Legally ) Why is this relevant you say? Well I have been vary unlucky and some could say naive with buying bikes as I am only 18, leading me to have lots of broken bikes laying around the place. A month ago I was donated a 1983 honda cm which had been sitting rotting in a boat yard for years. Try as I might I could not get the thing to run so I called in some help from my friend who has a job in welding.
The initial plan was to get the thing working with the wiring harness and controls in their factory positions, however this was not the case. We pulled the bike to pieces and got it down to the bare frame revealing a hideous re weld through the main section of frame so we decides to make our own frame and build our own bike.
Currently the bike is a combination of the Honda and a 1993 Yamaha xj 400 diversion ( my first big bike which hydrolocked and died ) The frame has been build enterily by me and my friend the engine is of the Honda, folks, wheels, swingarm, footrests, and bars are the yamahas.
Any advice, criticism or ideas would be amazing. Like I said this is our first build and we need a little guidance and support.
https://i231.photobucket.com/albums/ee172/harlston_harley/swingarmandshock.jpg
https://i231.photobucket.com/albums/ee172/harlston_harley/justaboutrolling.jpg
https://i231.photobucket.com/albums/ee172/harlston_harley/IMG_5182.jpg
here are some photos that I took today, as you can see its not there yet but progress has been made, the sub frame needs be measured up and welded, along with the front engine mount.
However finally managed to get the engine fired up today and not only that but had a decent amount of back pressure. one of the pistons doesnt seem to be putting out as much power as the other, and I am not sure why, possible lack of fuel going through the carbs ( as one carb feeds the other rather than direct feed ) or a dodgy spark?
https://i231.photobucket.com/albums/ee172/harlston_harley/IMG_5188.jpg
as you can see the bracket for the front engine mount is yet to be finalised. This photo is just to show how we have attached the box section of the frame to the head tube of the Yamaha xj.
https://i231.photobucket.com/albums/ee172/harlston_harley/IMG_5187.jpg
https://i231.photobucket.com/albums/ee172/harlston_harley/IMG_5184.jpg
here is how we have attached the swingarm and rear shock of the xj, the geometry is slightly off and the angle needs to be slightely further forward as the shock compresses at a rather acute angle causing the ride to be a little hard also putting the frame under extra un needed stress.
https://i231.photobucket.com/albums/ee172/harlston_harley/IMG_5186.jpg
this is our bodge job fuel cap, we are needing a suzuki gt250 cap but they are very expensive, if anyone knows of one... would be great?
| adiec |
 adiec Two Stroke Sniffer
 Posted: 18:33 - 16 May 2012 Post subject: |
That looks fookin' A!!! If the geometry is right and it rides well, could you be the next UK bike manufacturer!!! |
| Harley |
| hazza |
 hazza World Chat Champion
| Harley |
 Posted: 17:26 - 25 May 2012 Post subject: |
well the reason its all made of steel is because of our jobs and money. I am currently waiting to start my precision engineering job so untill then I dont have any good welders or money but when I start getting in the money I will be making a new frame with better shape and lighter piping! what would you change about the body work to make it more aesthetically pleasing? |
| Pete. |
 Pete. Super Spammer
 Posted: 17:56 - 25 May 2012 Post subject: |
Not to my taste but top marks for having a go. At least the frame should be strong enough that you don't have to worry about using the engine as a stressed member when Honda didn't see fit to.
Forks look a bit banana-ish, or is it a trick of the camera? ____________________ a.k.a 'Geri'
| hazza |
| Harley |
| garth |
 garth World Chat Champion
| Harley |
 Posted: 08:17 - 26 May 2012 Post subject: |
Kenco have really outdone them selves in terms of qaulity, this fuel cap is literally a perfect fit and one of the best I have used! compliments to kenco. Also for you racers on here, saves weight too  |
| pepperami |
 pepperami Super Spammer
 Posted: 08:57 - 26 May 2012 Post subject: |
10 out of 10 to you for having a go and getting so far
Constructive critism : F*ck me that is one serious frame you`ve made there, .
Could you not attatch the rear mudguard to the swinging-arm?
Keep up the good work.  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Harley |
 Posted: 09:34 - 26 May 2012 Post subject: |
the rear mudgaurd? we havnt put one on it yet... the ominous black shape is a pit bike fuel tank to hold the seat in place so you can see the shape of the bike a little more. However the mud gaurd will be attached to the wingarm  |
| orac |
 orac World Chat Champion
| Harley |
| orac |
| Harley |
 Posted: 10:09 - 29 May 2012 Post subject: |
Nice one mate. doest seem too hard I will give the dvla a call and see where they stand on the matter, I need to know what kinda requirements I have to meet really.... |
| CHR15 |
 CHR15 Turbo nutter bastard
| Shaft |
 Shaft World Chat Champion
 Posted: 22:58 - 30 May 2012 Post subject: |
I don't know if this would work today, but the old trick would be to use the headstock from the CM, because that's the bit with the VIN number.
Then all you need is a friendly MOT man and all you've got is a Honda with a simple monoshock conversion  ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Harley |
 Posted: 08:48 - 31 May 2012 Post subject: |
Bigger than the yellow pages as you can see I have not thought this out, maybe this can be a slow un racey, track bike.... or not.
also about headstock, this may be a stupid question, but could I just print on the number to the new one? |
| nisp |
 nisp Scooby Slapper
| Nope. |
 Nope. World Chat Champion
 Posted: 12:16 - 31 May 2012 Post subject: |
| Harley wrote: | also about headstock, this may be a stupid question, but could I just print on the number to the new one? |
You could, but if the police where to stop you then you'd be in for a world of pain (Mis registered vehicle etc. resulting in confiscation and a fine running into the thousands). BTW, the process of transferring one vehicles ID onto another vehicle is called Ringing.
With regards to the MSVA, the amount of work you'll have to do to get it through will be astronomical. I've done car IVA's before and they're a pain in the butt. Never done a bike one but I've heard that they're just as painful. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| orac |
| Nope. |
 Posted: 15:52 - 31 May 2012 Post subject: |
| orac wrote: | these difficulties may be the reason that you dont see kit bikes any where as often as you do kit cars.
i ahve always wondered about self built bikes, hense why i had a good idea wehre to get info on it. been trying to fine a copy of the MSVA manual. |
To be honest, putting a kit car through an IVA is much more of a pain then it used to be. (The SVA was a little easier, and of course before that they pretty much just gave you a reg. number). I can't imagine putting a bike through an MSVA is any harder then putting a car through an IVA, its just that 99.9% of people cant be bothered and would rather buy a bike thats already built to handle well/run well/look cool and modify it a bit then spend 4 times as much building one themselves. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| Harley |
| Drake |
 Drake World Chat Champion
 Posted: 21:01 - 31 May 2012 Post subject: |
paper weight? ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
The last post was made 14 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
