| Jim Mc |
 Jim Mc Nearly there...
| mentalboy |
 mentalboy World Chat Champion
 ..... Quote Me Happy
| yen_powell |
 Posted: 17:29 - 02 Jun 2012 Post subject: |
| Jim Mc |
 Posted: 17:38 - 02 Jun 2012 Post subject: |
Thanks. I was thinking of using a dowel but sometimes you just need pointed in the right direction and see how others do it.  |
 Posted: 17:40 - 02 Jun 2012 Post subject: |
Lay the wheel on an old tyre or something because it's very easy to bend the disc carriers. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| mentalboy |
| Casper |
 Casper World Chat Champion
| Raffles |
 Raffles World Chat Champion
| Vincent |
 Vincent Banned
| mentalboy |
| kestrel |
 kestrel Nearly there...
| Frodo |
 Frodo Derestricted Danger
 Posted: 12:12 - 03 Jun 2012 Post subject: |
Won't work for a pair of wheel bearings with spacer tube between though will it. ____________________ a.k.a 'Geri'
| Frodo |
 Posted: 14:02 - 03 Jun 2012 Post subject: |
If you put a socket on one end the same size as the outer bearing shell and then a wider socket on the other side that'll stay solid on the wheel it should
Works on the same principal as the usual bearing presses  |
 Posted: 15:04 - 03 Jun 2012 Post subject: |
No, it won't. On a bike wheel, the bearings pull out in opposite directions, and press in against a seat. If you pull through the left bearing to remove the right, all you'll do is pull the left bearing hard against the seat and the right will move no more than the difference of the distance between the two seats and the length of the spacer tube - probably no more than 2mm.
You can put them in that way, but you cannot use it to remove them. ____________________ a.k.a 'Geri'
| Frodo |
 Posted: 16:34 - 03 Jun 2012 Post subject: |
Aww sorry didn't know they were in that way  |
The last post was made 14 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
