Bearing puller
Jim Mc
PostPosted: 17:09 - 02 Jun 2012    Post subject: Bearing puller Reply with quote
Blind bearing pullers seem to be quite expensive so can anyone recommend a tool or a DIY method to pop out the bearings from a front wheel? I never changed mine in the end but may wish to in future, was going to invest in one but the majority are pricey. Thanks.
mentalboy
PostPosted: 17:15 - 02 Jun 2012    Post subject: Reply with quote
Use a long drift from the other side of the wheel. Make sure it's got a very clean edge as you'll probably only have a tiny bit of the bearing accessible to clout. Work round the bearing 12 o'clock, 6 o'clock, 3 o'clock, 9 o'clock and so on so it doesn't drift out at an angle.
I use an old rear wheel axle bolt as you get plenty of length, but because it's soft material you do have to keep the end well dressed
Make mine a Corona.
Quote Me Happy
PostPosted: 17:16 - 02 Jun 2012    Post subject: Reply with quote
Can't you just knock them out from the other side?
yen_powell
PostPosted: 17:29 - 02 Jun 2012    Post subject: Reply with quote
https://i19.photobucket.com/albums/b165/yen_powell/P1010712.jpg
https://i19.photobucket.com/albums/b165/yen_powell/P1010713.jpg
XT1200Z and a DR350 in bits
Jim Mc
PostPosted: 17:38 - 02 Jun 2012    Post subject: Reply with quote
Thanks. I was thinking of using a dowel but sometimes you just need pointed in the right direction and see how others do it. Thumbs Up
PostPosted: 17:40 - 02 Jun 2012    Post subject: Reply with quote
Lay the wheel on an old tyre or something because it's very easy to bend the disc carriers.
mentalboy
PostPosted: 23:27 - 02 Jun 2012    Post subject: Reply with quote
And it's best to use a copper headed hammer rather than something like that beastly great lump hammer shown in the pics!
Make mine a Corona.
Casper
PostPosted: 23:31 - 02 Jun 2012    Post subject: Reply with quote
Vincent wrote:
And, if you're using a drift, only move one half of the bearing at a time - a small amount. You don't want to distort the carrier. It is also possible to make a puller from a length of threaded bar and the right sized washers and nuts.
How does that work to get the first one out?
Buy a slide hammer then get the attachments. Slide hammers have 100's of uses.
Raffles
PostPosted: 00:11 - 03 Jun 2012    Post subject: Reply with quote
Why so?
mentalboy
PostPosted: 10:32 - 03 Jun 2012    Post subject: Reply with quote
Raffles wrote:
Why so?
When drifting anything out of an item that you wish to perform well when you finished beasting it, it is always better to err on the cautious side and a soft headed hammer will produce a less harsh striking force on whatever is being hit - or so I've been led to believe.
In a lot of motorcycle applications you will find steel fixing/parts that are housed in alloy casings, alloys tend to be light but are more likely to crack/break before the steels you are trying to get out.
A light heating is usually a good starting point with this type of situation before getting heavy with a walloping stick.
Make mine a Corona.
kestrel
PostPosted: 10:40 - 03 Jun 2012    Post subject: Reply with quote
If you wish to produce a smaller striking force then use a smaller hammer. Copper faced hammers and mallets are used to prevent damage to the surface you are striking and are not for use with drifts, chisels, punches etc.
Isle of Man.........Road Racing Capital Of The World
Frodo
PostPosted: 11:31 - 03 Jun 2012    Post subject: Reply with quote
The threaded shaft idea works
Have a look on YouTube, seen a few for doing bushes but would do a bearing just as well. Was made out of the shaft from a car scissor jack
PostPosted: 12:12 - 03 Jun 2012    Post subject: Reply with quote
Won't work for a pair of wheel bearings with spacer tube between though will it.
Frodo
PostPosted: 14:02 - 03 Jun 2012    Post subject: Reply with quote
If you put a socket on one end the same size as the outer bearing shell and then a wider socket on the other side that'll stay solid on the wheel it should
Works on the same principal as the usual bearing presses Thumbs Up
PostPosted: 15:04 - 03 Jun 2012    Post subject: Reply with quote
No, it won't. On a bike wheel, the bearings pull out in opposite directions, and press in against a seat. If you pull through the left bearing to remove the right, all you'll do is pull the left bearing hard against the seat and the right will move no more than the difference of the distance between the two seats and the length of the spacer tube - probably no more than 2mm.
You can put them in that way, but you cannot use it to remove them.
Frodo
PostPosted: 16:34 - 03 Jun 2012    Post subject: Reply with quote
Aww sorry didn't know they were in that way Embarassed
The last post was made 14 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 16 - Page Size: 101.16 Kb
