I need some help diagnosing a problem.
Tuffers
PostPosted: 13:20 - 06 Jun 2012    Post subject: I need some help diagnosing a problem. Reply with quote
So this morning i set of to work like every other normal morning on my honda nxr 125but after about a mile and a half it seemed to bog down and loose power. Then at a set of traffic lights it cut out and wouldnt kick up, so i bump started it and it seems to be missfiring and only running when i put on full throttle and whilst this is happening it throws some blueish smoke out the back. If i let go of the throttle it will stall. My first thought was that a gasket might have gone but upon phoning my mechanic (step-dad =p) he said the crank shaft might have gone.
The engine is a CG variant.
Any ideas as to what you guys think it would be is welcome as it is my only way to get to work from home.
PostPosted: 13:32 - 06 Jun 2012    Post subject: Reply with quote
Well...he sounds like a fantastic mechanic. Wink
Checked your spark plug and oil recently?
Tuffers
PostPosted: 14:01 - 06 Jun 2012    Post subject: Reply with quote
The oil has been changed about 2 weeks ago the spark plug was cleaned on the same day. Hes a great wanabe mechanic;)
Nope.
PostPosted: 14:15 - 06 Jun 2012    Post subject: Reply with quote
tuffers wrote:
The oil has been changed about 2 weeks ago)
Don't give a monkies when it was last changed, has the level dropped? Blue smoke generally indicates that the engine is burning oil.
Stick a compression tester on it and check what the compression is. Remember to hold the throttle open.
Also:
Are you serious? More to the point, is HE serious? Make sure to never EVER let him near your bike. You'll probably return after an hour and it'll be in bits on the floor with him sitting there saying "it done brokeded"
Tuffers
PostPosted: 14:45 - 06 Jun 2012    Post subject: Reply with quote
Who am i to question a 50 year old mechanic hehe Wink
i cleaned the spark plug and put it back in, the bike started after 2 kicks but only lasted about 5 seconds. The whole time black smoke pouring out the exhaust. The spark plug seems to be getting wet.
Also i dont have a compresion tester.
PostPosted: 15:09 - 06 Jun 2012    Post subject: Reply with quote
Is the plug black as fuck?
Compression test on the cheap, remove spark plug and put thumb over the hole. Get someone to kick start it with ignition off and it should try and blow your finger away from the hole.
Its its black smoke (I'm guessing blue really) then its probably burning oil, which means compression will be a little low.
Get that checked, also get valves checked.
If you are close to Maidstone in Kent, I'm more than happy to have a look.
Tuffers
PostPosted: 15:29 - 06 Jun 2012    Post subject: Reply with quote
Yeah it was black before i cleaned it. iv just checked the compression with my thumb and it blows air out through the hole no matter how tight i press down. the first time i checked i accidentally left my ignition on and a fireball flew up my arm :S.
Unfortunately i live in Huddersfield, Yorkshire.
Nope.
PostPosted: 16:20 - 06 Jun 2012    Post subject: Reply with quote
Won't really tell you much, all it'll tell you is that there isn't a huge gaping hole in the piston which we had already proved by the fact that it runs.
You really need to buy/borrow/scrounge a compression tester. You must have a friend or a local garage that has one you can borrow. How black was the spark plug when you removed it? Have you checked the oil level?
I mean, ideally you need to do a leak down test but if you don't have a compression tester then I seriously doubt you have to kit to do a leak down test.
Once you've done a compression test then (provided its low) you ideally need to whip the head off and take a peek at the bore and see if its scored. My bet is that it will be, and you'll need either a re-bore and an oversize piston or you could just buy a cheap chinese cylinder and piston kit off of ebay. Probably around £80.
Stonefly
PostPosted: 16:39 - 06 Jun 2012    Post subject: Reply with quote
Sounds like a burned out valve to me
Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250
Tuffers
PostPosted: 16:44 - 06 Jun 2012    Post subject: Reply with quote
The only tools/equipment that i have is a big socket set, toolkit that came with the bike, some feeler gauges and a spark plug brush :/
To add insult to injury it broke down 100 yards from my local bike shop which is shut on Wednesdays :S
The oil has burnt down about a quarter of the way down the dip stick in 2 weeks.
nightshaddow
PostPosted: 17:19 - 06 Jun 2012    Post subject: Reply with quote
+1
if there is compression on the cylinder valves would be the likely suspect
Usher4566
PostPosted: 17:24 - 06 Jun 2012    Post subject: Reply with quote
Rings gone .do compresstion test .get them halfords ,motospares,eBay ( cheapest).or whip head off and take a look because I think we can confirm from the smoke thY its ducked
New cd200 benly owner
Tuffers
PostPosted: 18:17 - 06 Jun 2012    Post subject: Reply with quote
so whatever it is, im going to have to somehow get a lift to work this week cause its not going to be sorted tonight xD
Johnser
PostPosted: 19:35 - 06 Jun 2012    Post subject: Reply with quote
probably one of the above issues but just check your choke isnt jammed on or that the airfilter hasn't disintegrated into the carb.
Ariel Badger
PostPosted: 22:00 - 06 Jun 2012    Post subject: Reply with quote
Clean the carb. White smoke oil, blue smoke fuel.
bodger
PostPosted: 08:41 - 07 Jun 2012    Post subject: Reply with quote
As Ariel Badger says-
If the smoke is black and the plug is wet is sounds like rich mixture, so the carb needs strippng and the fuel cutoff valve checking.
If the bike was running alright previously its very unlikely you have a problem with the engine.
Nope.
PostPosted: 09:08 - 07 Jun 2012    Post subject: Reply with quote
lolwut. If that were true then no bike would ever have engine problems, as they're all running fine when they come out of the dealers brand new.
Robby
Dirty Old Man
PostPosted: 10:25 - 07 Jun 2012    Post subject: Reply with quote
I like how everyone is instantly jumping on the engine rebuild bandwagon, without considering the alternatively.
It has oil in the engine, and has had oil in the engine the whole time. Rings don't suddenly wear out - they either go very gradually over tens of thousands of miles, or they snap. Snapping a ring is unlikely.
Likewise, burning out an exhaust valve is unlikely.
Simple things first:
1. Make sure it has fuel.
2. Make sure the spark plug hasn't unscrewed itself.
3. Charge the battery.
If none of these things help, then clean the carburettor.
These are the cheap fixes that don't require buying tools. A possibly problem going by the symptoms could be a sticking float or a bit of shit stuck on the needle valve, leading to a very rich mixture.
Nope.
PostPosted: 11:54 - 07 Jun 2012    Post subject: Reply with quote
We don't know that, he hasn't told us.
It's chinese. Anything is possible. See that thread recently with half the piston melted to the head?
A compression tester isn't exactly expensive, and is always a handy thing to have around. It's easier and quicker to do a compression test then it is to charge up the battery!
Tuffers
PostPosted: 13:14 - 07 Jun 2012    Post subject: Reply with quote
The bike is made by Hero Moto-Corp of Brazil. Yes there has been oil in the engine the whole time, but it has either lost or burnt down a 3rd of it in the last 2 weeks since i last checked it.
The bike was running perfectly before it stopped, if anything it was running better than usual with not so much as a caugh. The spark plug was the first thing i checked, it was jet black and very wet but after a clean it had a nice bright spark after testing it.
Also when it stopped running it felt alot like it ran out of fuel, so i put it onto reserve just incase which made no difference (it has 3/4 of a tank full)
nightshaddow
PostPosted: 17:16 - 07 Jun 2012    Post subject: Reply with quote
the engine has burnt apoximatly 400ml of oil in 2 weeks?
my cb (26 years old ) and the por (chinese crosser with cg rip off engine) havent lost that much since i owned them even with the cb's oil leak,
if it is a knock off cg engine the chances are no matter where branded it will be chinese with the engine number prefix of 156/157 fmi
i would remove the rocker cover (3x 10mm bolts) and look at the 2 valves maybe even post a pic of what you see, the engines (of which i have had 3 with no trouble) are renowned for dropping valves
Tuffers
PostPosted: 18:02 - 07 Jun 2012    Post subject: Reply with quote
The bike is a Brazilian Honda made by Hero Moto-Corp which works/worked for Honda. As for as i know though Honda supplied the engine as it is the Brazilian made XR125. Il take a look under the rocker cover and inform you of what i find.
Tuffers
PostPosted: 18:32 - 07 Jun 2012    Post subject: Reply with quote
just took off the rocker cover and everything seems to be fine, valve spaces are to the correct tolerances, nothing is cracked/broken and it is all full of oil, so its either the carb or the piston?
Also if i am to check the barrel, is there any guide for a CG engine for taking it apart properly? and do i have to loosen the valves to do so as i dont want to ruin any timings.
bodger
PostPosted: 08:42 - 08 Jun 2012    Post subject: Reply with quote
Unless you were caning the bike on your way to work I cant see how you could have damaged the the engine
Dont start stripping the engine before you check the basic things first. Such as stripping and cleaning the carb.
Tuffers
PostPosted: 12:55 - 08 Jun 2012    Post subject: Reply with quote
I had just set off from some traffic lights and was slowing down with the traffic, at max i was at half revs which is why its so confusing to me, it looked like it ran out of petrol but it wouldnt run unless i bumped it and what would have caused the blue smoke if it is the carb :s
The last post was made 14 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 132.62 Kb
