| Tuffers |
 Tuffers Scooby Slapper
| P.addy |
 P.addy Red Rocket
 Posted: 13:32 - 06 Jun 2012 Post subject: |
Well...he sounds like a fantastic mechanic.
Checked your spark plug and oil recently? |
| Tuffers |
| Nope. |
 Nope. World Chat Champion
| Tuffers |
 Posted: 14:45 - 06 Jun 2012 Post subject: |
Who am i to question a 50 year old mechanic hehe
i cleaned the spark plug and put it back in, the bike started after 2 kicks but only lasted about 5 seconds. The whole time black smoke pouring out the exhaust. The spark plug seems to be getting wet.
Also i dont have a compresion tester. |
| P.addy |
 P.addy Red Rocket
| Tuffers |
| Nope. |
 Posted: 16:20 - 06 Jun 2012 Post subject: |
| ##Paddy## wrote: |
Compression test on the cheap, remove spark plug and put thumb over the hole. Get someone to kick start it with ignition off and it should try and blow your finger away from the hole.
Won't really tell you much, all it'll tell you is that there isn't a huge gaping hole in the piston which we had already proved by the fact that it runs.
You really need to buy/borrow/scrounge a compression tester. You must have a friend or a local garage that has one you can borrow. How black was the spark plug when you removed it? Have you checked the oil level?
I mean, ideally you need to do a leak down test but if you don't have a compression tester then I seriously doubt you have to kit to do a leak down test.
Once you've done a compression test then (provided its low) you ideally need to whip the head off and take a peek at the bore and see if its scored. My bet is that it will be, and you'll need either a re-bore and an oversize piston or you could just buy a cheap chinese cylinder and piston kit off of ebay. Probably around £80. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| Stonefly |
 Stonefly Scooby Slapper
 Posted: 16:39 - 06 Jun 2012 Post subject: |
Sounds like a burned out valve to me ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
| Tuffers |
| nightshaddow |
 nightshaddow Nearly there...
| Usher4566 |
 Usher4566 Spanner Monkey
| Tuffers |
| Johnser |
 Johnser Renault 5 Driver
| Ariel Badger |
 Ariel Badger Super Spammer
| bodger |
 bodger Nova Slayer
| Nope. |
| Robby |
 Robby Dirty Old Man
| Nope. |
 Posted: 11:54 - 07 Jun 2012 Post subject: |
| Robby wrote: |
It has oil in the engine, and has had oil in the engine the whole time.
We don't know that, he hasn't told us.
| Robby wrote: |
Rings don't suddenly wear out - they either go very gradually over tens of thousands of miles, or they snap. Snapping a ring is unlikely.
Likewise, burning out an exhaust valve is unlikely.
It's chinese. Anything is possible. See that thread recently with half the piston melted to the head?
| Robby wrote: |
These are the cheap fixes that don't require buying tools. |
A compression tester isn't exactly expensive, and is always a handy thing to have around. It's easier and quicker to do a compression test then it is to charge up the battery! ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| Tuffers |
| nightshaddow |
 Posted: 17:16 - 07 Jun 2012 Post subject: |
the engine has burnt apoximatly 400ml of oil in 2 weeks?
my cb (26 years old ) and the por (chinese crosser with cg rip off engine) havent lost that much since i owned them even with the cb's oil leak,
if it is a knock off cg engine the chances are no matter where branded it will be chinese with the engine number prefix of 156/157 fmi
i would remove the rocker cover (3x 10mm bolts) and look at the 2 valves maybe even post a pic of what you see, the engines (of which i have had 3 with no trouble) are renowned for dropping valves ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Tuffers |
| Tuffers |
| bodger |
 bodger Nova Slayer
| Tuffers |
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
