Kawk KH100
Kawksam
PostPosted: 20:14 - 07 Jun 2012    Post subject: Kawk KH100 Reply with quote
Getting a Kawasaki kh100 and need to sort points out, what's the procedure for setting point gap and the the gap measurement.
It's got new points and coil which is a bonus.
PostPosted: 20:45 - 07 Jun 2012    Post subject: Reply with quote
I dunno what the gap should be but I'd guess about 0.4mm, you set it using a brass feeler gauge to stop the feeler being caught by the rotor magnets.
cb1rocket
hard to explain without going into detail.
basically its this extract from a Honda, the same pretty much applies.
scroll down for the extract from the manual.
Although your wire colour will be different. You will see the what colour wire as it comes off the contact breaker assembly
https://www.bikechatforums.com/viewtopic.php?t=193662
cb1rocket
PostPosted: 20:47 - 07 Jun 2012    Post subject: Reply with quote
sorry went a step too far but Pete is right and the procedure to see if it fires up the time is in the link
Kawksam
PostPosted: 22:23 - 07 Jun 2012    Post subject: Reply with quote
Thanks for that, might get local mechanic to do it for first time and get it right.
PostPosted: 22:26 - 07 Jun 2012    Post subject: Reply with quote
If you've no experience it might be best. Try to find an old boy though, because many mechanics nowadays won't have even seen a set of points.
I'm wondering though - if it's fitted with new points, what makes you think they need adjusting?
PostPosted: 22:41 - 07 Jun 2012    Post subject: Reply with quote
The gap and the timing are directly related. If you alter the gap, the ignition timing changes. That's why you do the gap first (to set the dwell), then the timing. Weird that they should say there is no adjustment.
Kawksam
PostPosted: 22:44 - 07 Jun 2012    Post subject: Reply with quote
The person I am buying it off says it could do with them adjusting, I know a good person who can sort it and give it a check over.
If ring up a Kawasaki dealership do you think they can give me the point gap measurement.
PostPosted: 22:55 - 07 Jun 2012    Post subject: Reply with quote
I guess if the ramp angle of the points cam was quite steep, it wouldn't make a whole lot of difference to the dwell what the gap was.
karthead
PostPosted: 09:38 - 08 Jun 2012    Post subject: Reply with quote
OOOH OOOOOOOOHHHH I HAVE SOMETHING TO ADD!
Let me start off with this: i have a KE125 engine, similar to kh100. And if the magnetos are the same, then i have something to tell you that will get it running awesomely.
Okay, so the magneto has two slots in it, correct? okay. i was told the point gap for my KE125 is .35mm, dunno if the same applies to your bike. when i finished putting it all together, it fired up, but was a bitch to start. so i took it apart. one thing that you need to know that the points need to open 3mm from tdc (top dead centre). when i slowly rotated the magneto, the i could see through the slots of the magneto exactly when the points opened in relation to the position of the piston, and it was too early. close the gap to make it open later, open the gap to make it open earlier. so i shoved in the .3mm feeler gauge (i think thats the size) and it looked perfect to me, although i havent started it up yet.
moral of the story: make it .35mm as a start, look at the position of the piston when the points open, and then if need be, adjust the gap untill it looks right to you.
i hope this helps
karthead
PostPosted: 10:26 - 08 Jun 2012    Post subject: Reply with quote
Vincent wrote:
Andre, according to the WM, you can only adjust when the points start to open. Normal points have two sets of adjusting pegs, these only have one that positions the stator plate. You need to be careful, sometimes advancing the ignition will give you more power, but it can also cause a meltdown Exclamation 2.52mm BTDC is where you want the points to open on the 125, if you get yerself a dial gauge, (you can get them with a spark plug thread adapter), you'll get it bang on.
Also, take note of what I say above about early models having TWO timing marks, one is actually to let you know where the woodruff key is positioned as it's not visible when you replace the flywheel mag..
yeah i was worried about not knowing where the woodruff key was, but turns out i could just see it with the flywheel on. when you say advancing the ignition, do you mean making it spark earlier? do you consider 3mm btdc too early? what difference does it make? well this is important to know, thanks for the heads up Thumbs Up
cb1rocket
PostPosted: 10:46 - 08 Jun 2012    Post subject: Reply with quote
https://www.thumpertalk.com/topic/930347-test-your-timing-for-only-15-dial-gauge-dial-indictor-ignition-timing/
make your own tool. you can buy the kit buts its so expensive!
karthead
PostPosted: 11:00 - 08 Jun 2012    Post subject: Reply with quote
Vincent wrote:
Oh, and yes, 3mm is "advancing the ignition" as you are setting it to fire 0.75 before it should. "retarding" the ignition would be having it fire after it should. the idea is to get the cylinder to fire just at the right time. You'd think the best time would be at Top Dead Centre but, as the combustion takes time, (tiny though it is), the big bang comes just after the plug has sparked so the piston is still moving up the cylinder until max power from the combustion is reached, (see "squish"). If it fires too early, it will try and push the piston back the other way. Too late and you have lost the opportunity for max efficiency. There is also the variant of how fast the engine is running to add into the equation, tuned two strokes are timed to fire at the best position at high revs.
I think that's right Smile
hth
okay, great, ill make sure to actually measure it this time (with a ruler, not a dial gauge because ive already raped the budged for my project!) and incase your wondering how the hell i fit a ruler through the spark plug hole, im going to take the head off to measure it. so, would you say roughly no more then 2.5mm, and somewhere between 2.5-2.0 to be safe? ill try and get it spot on if i can, but i dont think there is enough sizes on my feeler gauge to get the gap at the exact measurement to produce 2.52mm btdc..
karthead
PostPosted: 11:37 - 08 Jun 2012    Post subject: Reply with quote
Vincent wrote:
A ruler won't cut it I'm afraid. If you're short of tools, you can either use a multi meter or even just a 12V light bulb and the timing marks. You might be able to pick a strobe up quite cheap but the engine needs to be running to use it. Wherabouts are you?
OH Brilliant! you will fly over to australia?! Laughing dont worry about it, i have a couple of people to help who know what they're doing.. so you're saying i cant measure how far the piston is from tdc when the points open using a ruler? i have heard about the light bulb trick, i dont have patience to do that tho..
Kawksam
PostPosted: 11:48 - 08 Jun 2012    Post subject: Reply with quote
Think I will get garage to do it, it's abit technical for me lol.
cb1rocket
PostPosted: 11:52 - 08 Jun 2012    Post subject: Reply with quote
I would do it for you if your near, piss easy once you know what your doing
Kawksam
PostPosted: 12:08 - 08 Jun 2012    Post subject: Reply with quote
I'll get a book for it, haven't picked best day to pick a bike up pissing down with rain,
Can I check the crank shaft seals by sniffing gear box oil see if it smells of petrol Wink
karthead
PostPosted: 12:20 - 08 Jun 2012    Post subject: Reply with quote
A little tip to check seals. while its running, spray a highly explosive spray at the seal, and if it revs higher the seal is no good.
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 134.43 Kb
