Changing a fuel tank + Clocks
Alpha-9
PostPosted: 22:14 - 12 Jun 2012    Post subject: Changing a fuel tank + Clocks Reply with quote
Anyone know how to change the fuel tank on a YBR? I've got as far as the side panels and seat off, and undone the main bolt holding the fuel tank in, but then it's like stuck with weird foam stuff at the other side? what is this?
And what is the best way to disconnect the pipes?
there is like a circle thing with lots of very small and pretty rusty allen key looking bolts around it looking like they are holding the whole thing to the tank, but i'm not really sure
I've actually looked in the manual online and there's barely anything about changing the fuel tank, theres hardly a mention of it at all
And I can't find any other tuts on it
It's the FI model 2009
Thanks Thumbs Up
Fzr-600 1999
Alpha-9
PostPosted: 08:07 - 13 Jun 2012    Post subject: Reply with quote
pls BCF
Fzr-600 1999
fraggie
PostPosted: 10:20 - 13 Jun 2012    Post subject: Reply with quote
Might help if you put up some pictures?
btw, those allen bolts may hold your fuel gauge in the tank..
PostPosted: 12:05 - 13 Jun 2012    Post subject: Reply with quote
Undo bolts holding tank to frame.
Wiggle backwards.
Do not unbolt the circle bit at the bottom. Fuel will come out, its the pump.
Alpha-9
PostPosted: 18:28 - 13 Jun 2012    Post subject: Reply with quote
Yeah I really didn't feel good about those, had a feeling they shouldn't be fucked with
I tried that Paddy but it wouldn't budge and I didn't want to yank it, it feels like some sort of filler foam is holding it in, I cant take a picture really as its in an awkward place and don't have a flash camera
If it is just some sort of anti-shock foam so the tank and bounce or something, what's it called so I can get some?
Or has it been bodged on by the mechanics Thinking
I'll have another go this weekend. Actually in the week some time, think i'm in london.
Will try to take pics.
Any clues or help appreciated! There's no foam things on the new tank just like, metal bits
https://s17.postimage.org/imxycfi67/35508.jpg
is a picture of a tank, the bit circled is where its got foam type stuff
The main hole with the little holes around it are the little allen key things, surely i'll need to take these out to change the pumps over to the new tank??
Best way to ciphon the fuel out? Laughing
How about clocks, they hard to wire up lol? Wink
Fzr-600 1999
map
Mr Calendar
PostPosted: 19:15 - 13 Jun 2012    Post subject: Reply with quote
Alpha-9 wrote:
...There's no foam things on the new tank just like, metal bits
The bits you have circled are normal on tanks.
They are 2 C shaped lugs.
These should fit into 2 large rubber washer type things near the headstock. They hold the tank in place and provide the cushioning. They are usually just slid on peg like lugs. So they fall off when tank removed and can be lost.
I am thinking maybe lost in the past and tank bodged on. Tanks like this should normally come off by releasing the rear fixing, lifting at the back and pulling backwards, maybe with a little side to side wriggling of the tank as you pull back.
HTH Thumbs Up
Alpha-9
PostPosted: 19:19 - 13 Jun 2012    Post subject: Reply with quote
HTH Thumbs Up
Incredibly helpful, thank you, pictures make everything better.
I'm fairly certain it didn't feel like rubber, I could actually feel like a crack in the foam from it moving around (probably from me trying to get it out)
Are these buyable, if so what would they be called? (The rubber bits)
Bodge DIY crafty solution also appreciated
Many thanks Thumbs Up
Also, bodge ass mechanic then?! Twisted Evil
Maybe they weren't there originally, I guess, but fuck, why not put them in D:
Fzr-600 1999
map
Mr Calendar
PostPosted: 19:28 - 13 Jun 2012    Post subject: Reply with quote
Alpha-9 wrote:
map wrote:
...should fit into 2 large rubber washer type things near the headstock...
...Are these buyable, if so what would they be called? (The rubber bits)...
Looked on eBay.
Maybe these are what you want?
Searched for motorcycle rubber ybr
I'd pull the tank off first just to see if they are.
Alpha-9
PostPosted: 22:09 - 13 Jun 2012    Post subject: Reply with quote
Thumbs Up Karma
Now I see, I think you're right, thanks Thumbs Up
Once the tank is loose and off, what then? Razz
Fzr-600 1999
map
Mr Calendar
PostPosted: 10:11 - 14 Jun 2012    Post subject: Reply with quote
Alpha-9 wrote:
...Once the tank is loose and off, what then? Razz
As they say in all the best manuals reassemble is the reverse of disassembly.
Do whatever you had to do for the reason for taking the tank off. I'd check and tidy up under the tank and replace tank mounting rubbers if that is the issue. If can't get via eBay or breakers then as last resort Yam dealer will be able to order.
Then just put back on making sure you don't trap any hoses or cables running under the tank. As said should just slide onto mounting rubbers. May take a little wriggling and getting the angle right. You should feel when it's ok. Then just bolt back down. Job done.
HTH Thumbs Up
PostPosted: 16:23 - 14 Jun 2012    Post subject: Reply with quote
map wrote:
Looked on eBay.
I never understand why people use ebay as the first source for parts.
https://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?ModelID=11328&pageID=22&m=YAMAHA+YBR125ED+TANK&uid=0
Genuine brand new ones for about 30% of the price of the ones you listed, they be sightly cheaper if you walk into a main dealer.
map
Mr Calendar
PostPosted: 16:35 - 14 Jun 2012    Post subject: Reply with quote
chris-red wrote:
map wrote:
Looked on eBay.
In my defence I did say I just looked. Had it open as a tab in my browser for other stuff so was a quick search rather than go through google results (I don't have a need to look for Yamaha parts).
Good link, will be using that if only for the fiche images.
Alpha-9
PostPosted: 07:26 - 15 Jun 2012    Post subject: Reply with quote
Already bought those ones for a fiver, free delivery, good enough for me Thumbs Up
Mother of god a diagram, nice Drooling
My clocks are also here, how easy/hard are they to do? Razz
Fzr-600 1999
flumpy7
PostPosted: 08:07 - 15 Jun 2012    Post subject: Reply with quote
Plug and play mate, not got a ybr so dont know how they are mounted but its gotta be easy as theres no front fairing is there?
2012 Sinnis apache
PostPosted: 12:05 - 15 Jun 2012    Post subject: Reply with quote
You could have walked into any Yamaha dealers and got them for about 60p each.
U_W v2.0
PostPosted: 15:54 - 15 Jun 2012    Post subject: Reply with quote
those dampers are always falling off my bike. as i have the tank off for a respray and dent removal its on and off alot, so i just got some glue from my hot glue gun, dabbed a bit into the damper hole and stuck em onto the lug poles.
its crappy enough glue that when/if the dampers need changing the glue will come off with a little bit of force releasing the damper
Alpha-9
PostPosted: 09:07 - 19 Jun 2012    Post subject: Reply with quote
Oh well, I'll bare it in mind in future Thumbs Up
So far i've got my clocks on, kinda dodgily, the bracket seems shit and like it'd wobble around and break, and i've got no decent bolts so the ones that are in it are barely grabbing the thread
Got late last night and everything was shut, even BnQ Thumbs Down
Got my speedo going and fuel gauge and back lights, but for some reason the simple connectors wouldn't work properly, I didn't crimp them but put them in just to debug and make sure it all works, there seems to be more connectors from the clocks than there are in the loom to take them?
I'll take pics later if I get stuck, it was getting dark so couldn't really sort it
Also electric start magically died whilst riding, was fine when I pulled off Rolling Eyes
Fzr-600 1999
stocksmenace
PostPosted: 09:31 - 19 Jun 2012    Post subject: Reply with quote
when you took the tank off, did you leave any of the wires loose near the engine, happened to me once, forgot to tuck it up and it meltend onto the engine ....quick fix....but it threw me lol
Triumph Sprint 900..Prev-ZZR600-Derbi terra-Mz251-Hyo Aquila
Alpha-9
PostPosted: 09:35 - 20 Jun 2012    Post subject: Reply with quote
Huzzah I did it all!
New tank on and clocks on, all working and fine, it was awkward and a pain and took most the night but it was worth it Laughing
Didn't expect to pull a big thing with wires and a float out my tank, that was weird
Got no neutral light indicator, seems to have ran out of wires, couldn't see any more to plug in anyway, and everyhting seemed attached well enough
electric start was just loose, seems okayish now, but sometimes it doesnt work, it's pretty touchy, thankful for my bonus kickstart Thumbs Up
Now I have a black tank and blue mudguard and sidepanels
Fzr-600 1999
Alpha-9
PostPosted: 18:46 - 20 Jun 2012    Post subject: Reply with quote
https://s9.postimage.org/qclpt6j5r/GOPR0173.jpg
Still a better fuel tank than Twilight
Fzr-600 1999
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 118.23 Kb
