| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 21:14 - 12 Jun 2012 Post subject: Changing a fuel tank + Clocks |
Anyone know how to change the fuel tank on a YBR? I've got as far as the side panels and seat off, and undone the main bolt holding the fuel tank in, but then it's like stuck with weird foam stuff at the other side? what is this?
And what is the best way to disconnect the pipes?
there is like a circle thing with lots of very small and pretty rusty allen key looking bolts around it looking like they are holding the whole thing to the tank, but i'm not really sure
I've actually looked in the manual online and there's barely anything about changing the fuel tank, theres hardly a mention of it at all
And I can't find any other tuts on it
It's the FI model 2009
Thanks  ____________________ Fzr-600 1999
| Alpha-9 |
| fraggie |
 fraggie Two Stroke Sniffer
| P. |
 P. Red Rocket
| Alpha-9 |
 Posted: 17:28 - 13 Jun 2012 Post subject: |
Yeah I really didn't feel good about those, had a feeling they shouldn't be fucked with
I tried that Paddy but it wouldn't budge and I didn't want to yank it, it feels like some sort of filler foam is holding it in, I cant take a picture really as its in an awkward place and don't have a flash camera
If it is just some sort of anti-shock foam so the tank and bounce or something, what's it called so I can get some?
Or has it been bodged on by the mechanics
I'll have another go this weekend. Actually in the week some time, think i'm in london.
Will try to take pics.
Any clues or help appreciated! There's no foam things on the new tank just like, metal bits
https://s17.postimage.org/imxycfi67/35508.jpg
is a picture of a tank, the bit circled is where its got foam type stuff
The main hole with the little holes around it are the little allen key things, surely i'll need to take these out to change the pumps over to the new tank??
Best way to ciphon the fuel out?
How about clocks, they hard to wire up lol?  ____________________ Fzr-600 1999 |
| map |
 map Mr Calendar
 Posted: 18:15 - 13 Jun 2012 Post subject: |
The bits you have circled are normal on tanks.
They are 2 C shaped lugs.
These should fit into 2 large rubber washer type things near the headstock. They hold the tank in place and provide the cushioning. They are usually just slid on peg like lugs. So they fall off when tank removed and can be lost.
I am thinking maybe lost in the past and tank bodged on. Tanks like this should normally come off by releasing the rear fixing, lifting at the back and pulling backwards, maybe with a little side to side wriggling of the tank as you pull back.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Alpha-9 |
 Posted: 18:19 - 13 Jun 2012 Post subject: |
| map wrote: |
HTH  |
Incredibly helpful, thank you, pictures make everything better.
I'm fairly certain it didn't feel like rubber, I could actually feel like a crack in the foam from it moving around (probably from me trying to get it out)
Are these buyable, if so what would they be called? (The rubber bits)
Bodge DIY crafty solution also appreciated
Many thanks
Also, bodge ass mechanic then?!
Maybe they weren't there originally, I guess, but fuck, why not put them in D: ____________________ Fzr-600 1999 |
| map |
 map Mr Calendar
| Alpha-9 |
 Posted: 21:09 - 13 Jun 2012 Post subject: |
Now I see, I think you're right, thanks
Once the tank is loose and off, what then?  ____________________ Fzr-600 1999 |
| map |
 map Mr Calendar
 Posted: 09:11 - 14 Jun 2012 Post subject: |
| chris-red |
| map |
 map Mr Calendar
 Posted: 15:35 - 14 Jun 2012 Post subject: |
In my defence I did say I just looked. Had it open as a tab in my browser for other stuff so was a quick search rather than go through google results (I don't have a need to look for Yamaha parts).
Good link, will be using that if only for the fiche images. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Alpha-9 |
 Posted: 06:26 - 15 Jun 2012 Post subject: |
Already bought those ones for a fiver, free delivery, good enough for me
Mother of god a diagram, nice
My clocks are also here, how easy/hard are they to do?  ____________________ Fzr-600 1999 |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| chris-red |
 Posted: 11:05 - 15 Jun 2012 Post subject: |
| Alpha-9 wrote: |
My clocks are also here, how easy/hard are they to do?  |
You could have walked into any Yamaha dealers and got them for about 60p each. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| Alpha-9 |
 Posted: 08:07 - 19 Jun 2012 Post subject: |
| chris-red wrote: |
You could have walked into any Yamaha dealers and got them for about 60p each. |
Oh well, I'll bare it in mind in future
So far i've got my clocks on, kinda dodgily, the bracket seems shit and like it'd wobble around and break, and i've got no decent bolts so the ones that are in it are barely grabbing the thread
Got late last night and everything was shut, even BnQ
Got my speedo going and fuel gauge and back lights, but for some reason the simple connectors wouldn't work properly, I didn't crimp them but put them in just to debug and make sure it all works, there seems to be more connectors from the clocks than there are in the loom to take them?
I'll take pics later if I get stuck, it was getting dark so couldn't really sort it
Also electric start magically died whilst riding, was fine when I pulled off  ____________________ Fzr-600 1999 |
| stocksmenace |
 stocksmenace Scooby Slapper
| Alpha-9 |
 Posted: 08:35 - 20 Jun 2012 Post subject: |
Huzzah I did it all!
New tank on and clocks on, all working and fine, it was awkward and a pain and took most the night but it was worth it
Didn't expect to pull a big thing with wires and a float out my tank, that was weird
Got no neutral light indicator, seems to have ran out of wires, couldn't see any more to plug in anyway, and everyhting seemed attached well enough
electric start was just loose, seems okayish now, but sometimes it doesnt work, it's pretty touchy, thankful for my bonus kickstart
Now I have a black tank and blue mudguard and sidepanels
| Alpha-9 |
The last post was made 13 years, 191 days ago. Instead of replying here, would creating a new thread be more useful? |
