Honda CG 125 carb settings?
tallturtle
PostPosted: 22:08 - 18 Jul 2005    Post subject: Honda CG 125 carb settings? Reply with quote
Just bought a CG125 for the other half to practice on before taking her test. Unfortunately it runs badly and missfires at high revs. Really need to know what the carb settings should be for the idle, accelerator pump etc so I can confirm its set ok before I try anything else. Really need this info, but haven't been able to get a manual yet
knockout_bar
PostPosted: 10:29 - 19 Jul 2005    Post subject: Re: Honda CG 125 carb settings? Reply with quote
Sounds to me like the timing could be out. If the timing isn't out, try this;
Start the bike up, and ride it around till the engine is warm (running temperature). Then find the mixture screw on the carb. Make a note of where it is, and while the engine is running, turn the screw. I would suggest probably about 1/8 of a turn. First clockwise, then ride it around to see if there's any difference. If not, or if it's worse. Turn it back to where it was and try it in the opposite direction (anti-clockwise). If you can feel a slight difference (improvement) in performance, but not perfect, turn it a bit more in the direction that showed signs of performance increase.
Hope this helps!
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
tallturtle
PostPosted: 20:40 - 19 Jul 2005    Post subject: Reply with quote
Thanks for that Smile Thing is, when I bought it, it revved out perfectly.... BUT the throttle would stick open (never much fun especially as the brakes didn't work very well either Shocked ). As a consequence I took the carb apart and cleaned it out etc. This cured the alarming tendancy of the bike to refuse to slow down Wink but I obviously didn't take enough care in noting how far the jets were turned in Embarassed There's the added complication of the accelerator pump setup which I also had to disturb to get the carb apart. I've tried the trial and error method, but various attempts at adjusting in and out haven't really made a difference, which is why I need the proper settings to give me somewhere to start from. I take your point about the timing and it could probably do with an adjustment but as I said, it ran (and ran) ok when I first got it.
knockout_bar
PostPosted: 17:02 - 20 Jul 2005    Post subject: Reply with quote
Take the carb off and check the jets. Make sure they are clear and have no blockages.
The throttle on my friends CG sticks open. What you do to remedy it is; losen the screws that hold the grip twist (throttle) asembley to the handle bars, and slide the asembley to the right. Only a little bit. This should allow the throttle to spring back to idle.
tallturtle
PostPosted: 21:32 - 21 Jul 2005    Post subject: Reply with quote
Cheers m8
Got myself a Haynes manual. Adjusted carb to correct settings. Now runs much much better. Will have a look at the timing just to make sure everything is as it should be.
The throttle problem seems to be at the carb end, as at the handlebar end it returns with a nice snap.
I guess bearing in mind the age that things aren't too bad. As long as it helps the missus pass her test, it would have been money well spent
There is a gap of 3 years, 113 days between these two posts...
RazorModz
PostPosted: 20:35 - 11 Nov 2008    Post subject: Reply with quote
tallturtle wrote:
Cheers m8
Hi There, what are the correct settings for the carb, mine needs doing badly after i took it to pieces to clean it out. I also had to disturb the accelerator pump so I need to know how to set that back up aswell. Any help you could give me would be great!!
Politicians and nappies both need changing for the same reason!!!
luke27
PostPosted: 21:50 - 11 Nov 2008    Post subject: Reply with quote
RazorModz wrote:
tallturtle wrote:
Cheers m8
You have just opened a thread thats been dead for over 3 years!
Not many people have a Honda CG125 for that long and I would not expect them to keep the Haynes manual.
What year is your bike?
Have you looked for the Haynes manual in Halfords motorbike section?
You can often read it in store.
There is a gap of 3 years, 224 days between these two posts...
G0gu
PostPosted: 01:02 - 23 Jun 2012    Post subject: honda CG 125 1996 Reply with quote
I know this is an old post i'm replying to but i cannot find what i'm after in other posts and cant for the life of me seem to find the button to start new posts? Shocked
Anyway, i have a honda cg 125 1996, i took the carb off today to clean it and put it back on, seemed ok, but then i turned the key kick started it and it just revved its tits off, so i turned the key off, as i didnt want to damage anything tried about ten different times to fix the problem cant seem to figure out whats wrong with it, i'm no expert with bikes but if someone can let me know if they think they know whats wrong with it i would appriciate it,
also i noticed, when the bike was off i was checking if the accelerator (like the twist grip) and as i revved(while the engine was off) it didnt snap back?
if anyone could help me i would greatly appriciate it Very Happy thanks
Ps, if anyone can tell me how to start new posts that would be great too, haha
cheers
Casper
PostPosted: 01:58 - 23 Jun 2012    Post subject: Reply with quote
New topic is the button you want. Top right.
Was the bike OK before you started to clean the carb? If so it could be you have turned the tickover knob up to much or sticky slider. If non CV carbs you may have put the cable back wrong. Some sliders have a notch so you have to have it a certain way round. Take it apart again and re asemble how the book says.
Usher4566
PostPosted: 07:16 - 23 Jun 2012    Post subject: Reply with quote
You need to check throttle cable not sticking and is routed properly ,then check throttle spring .then check you have got your throttle slide right way round in jet .unscrew top of carb and had a spring and little shuttle with needle on make sure its not back to front if all checked and still does it look at float needle make sure itsfree moving
New cd200 benly owner
U_W v2.0
PostPosted: 13:50 - 23 Jun 2012    Post subject: Reply with quote
hit this button in the forum pages
https://cdn.bikechatforums.com/templates/standard/images/lang_english/post.gif
G0gu
PostPosted: 09:01 - 27 Jun 2012    Post subject: Reply with quote
Thanks for your help guys, it was sticking accelerator cable, my girlfriends dad came and helped me sort it, there was old grease in there gone all hard jamming it up, just my luck that it happens to fully jam up when i'd cleaned the carb, first big piece of work i'd done on the bike (big to me Very Happy ) and i thought i'd messed it up, turns out i did it ok, whahey! cheers for your help and thanks for replying on an old post Very Happy
If any one is interested or runs in to the same problem as i did i'll give a "brief" overview of what was done:
Take accellerator hand bar grip fully off, well not fully off, just enough so you can get to the wire, unclip the wire, similar to brakes on a pedal bike, then we put wd40 down to clear the old grease, then dripped oil down the wire until it came out the other end and then took the top bit of carb off with the spring in it, stretched the spring so it would spring back to place, then put it back together.
i know its not the most detailed overview but i'm no mechanic, hope this helps someone else in the future, with the beast Rolling Eyes that it CG haha
There is a gap of 4 years, 141 days between these two posts...
MOTOEXPERT This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 9 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 80.41 Kb
