| tallturtle |
 tallturtle L Plate Warrior
| knockout_bar |
 knockout_bar Scooby Slapper
 Posted: 10:29 - 19 Jul 2005 Post subject: Re: Honda CG 125 carb settings? |
| tallturtle wrote: | Just bought a CG125 for the other half to practice on before taking her test. Unfortunately it runs badly and missfires at high revs. Really need to know what the carb settings should be for the idle, accelerator pump etc so I can confirm its set ok before I try anything else. Really need this info, but haven't been able to get a manual yet
Cheers |
Sounds to me like the timing could be out. If the timing isn't out, try this;
Start the bike up, and ride it around till the engine is warm (running temperature). Then find the mixture screw on the carb. Make a note of where it is, and while the engine is running, turn the screw. I would suggest probably about 1/8 of a turn. First clockwise, then ride it around to see if there's any difference. If not, or if it's worse. Turn it back to where it was and try it in the opposite direction (anti-clockwise). If you can feel a slight difference (improvement) in performance, but not perfect, turn it a bit more in the direction that showed signs of performance increase.
Hope this helps! ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee)  |
| tallturtle |
 Posted: 20:40 - 19 Jul 2005 Post subject: |
Thanks for that Thing is, when I bought it, it revved out perfectly.... BUT the throttle would stick open (never much fun especially as the brakes didn't work very well either ). As a consequence I took the carb apart and cleaned it out etc. This cured the alarming tendancy of the bike to refuse to slow down but I obviously didn't take enough care in noting how far the jets were turned in There's the added complication of the accelerator pump setup which I also had to disturb to get the carb apart. I've tried the trial and error method, but various attempts at adjusting in and out haven't really made a difference, which is why I need the proper settings to give me somewhere to start from. I take your point about the timing and it could probably do with an adjustment but as I said, it ran (and ran) ok when I first got it.
Cheers |
| knockout_bar |
 Posted: 17:02 - 20 Jul 2005 Post subject: |
Take the carb off and check the jets. Make sure they are clear and have no blockages.
The throttle on my friends CG sticks open. What you do to remedy it is; losen the screws that hold the grip twist (throttle) asembley to the handle bars, and slide the asembley to the right. Only a little bit. This should allow the throttle to spring back to idle. ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
| tallturtle |
There is a gap of 3 years, 113 days between these two posts... |
| RazorModz |
 RazorModz L Plate Warrior
| luke27 |
 luke27 Nova Slayer
There is a gap of 3 years, 224 days between these two posts... |
| G0gu |
 G0gu L Plate Warrior
 Posted: 01:02 - 23 Jun 2012 Post subject: honda CG 125 1996 |
I know this is an old post i'm replying to but i cannot find what i'm after in other posts and cant for the life of me seem to find the button to start new posts?
Anyway, i have a honda cg 125 1996, i took the carb off today to clean it and put it back on, seemed ok, but then i turned the key kick started it and it just revved its tits off, so i turned the key off, as i didnt want to damage anything tried about ten different times to fix the problem cant seem to figure out whats wrong with it, i'm no expert with bikes but if someone can let me know if they think they know whats wrong with it i would appriciate it,
also i noticed, when the bike was off i was checking if the accelerator (like the twist grip) and as i revved(while the engine was off) it didnt snap back?
if anyone could help me i would greatly appriciate it thanks
Ps, if anyone can tell me how to start new posts that would be great too, haha
cheers |
| Casper |
 Casper World Chat Champion
| Usher4566 |
 Usher4566 Spanner Monkey
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| G0gu |
 Posted: 09:01 - 27 Jun 2012 Post subject: |
Thanks for your help guys, it was sticking accelerator cable, my girlfriends dad came and helped me sort it, there was old grease in there gone all hard jamming it up, just my luck that it happens to fully jam up when i'd cleaned the carb, first big piece of work i'd done on the bike (big to me ) and i thought i'd messed it up, turns out i did it ok, whahey! cheers for your help and thanks for replying on an old post
If any one is interested or runs in to the same problem as i did i'll give a "brief" overview of what was done:
Take accellerator hand bar grip fully off, well not fully off, just enough so you can get to the wire, unclip the wire, similar to brakes on a pedal bike, then we put wd40 down to clear the old grease, then dripped oil down the wire until it came out the other end and then took the top bit of carb off with the spring in it, stretched the spring so it would spring back to place, then put it back together.
i know its not the most detailed overview but i'm no mechanic, hope this helps someone else in the future, with the beast that it CG haha |
There is a gap of 4 years, 141 days between these two posts... |
| MOTOEXPERT |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 MOTOEXPERT L Plate Warrior
The last post was made 9 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
