| roundaboutkin... |
 roundaboutkin... Derestricted Danger
| tribal_tiger |
 tribal_tiger World Chat Champion
| roundaboutkin... |
| Nb |
 Nb World Chat Champion
 Posted: 22:21 - 17 Jan 2006 Post subject: |
Try a haynes manual ? You will probably use it for something else once you've bought it. Is your cg red? I saw one on the h3 the other day being ragged across a roundabout.  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
 Posted: 22:44 - 17 Jan 2006 Post subject: |
You need a manual, there are pictures and everything.
Basically, you want the points to be JUST opening as the 'T' mark on the flywheel lines up with the timing mark. You do this by losening the screw that holds the 'fixed' (non-moving) part of the points and nudging the points gap open or closed so they will grip a cigarette paper before the timing mark and are open enough so they won't conduct electricity to a bulb as you hit the timing mark.
Then check the gap is within tolerance. As I remember, there is no way of adjusting both the timing and the points gap on a CG125. Set the timing and if the gap is too big, buy new points.
As such, static timing should be good enough. I don't see the point of using a timing strobe on a CG as the timing and gap are a compromise as it is. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| roundaboutkin... |
 Posted: 22:54 - 17 Jan 2006 Post subject: |
thank you and yes my bikes red and yes it probably was me i got it bac few days ago  |
There is a gap of 6 years, 196 days between these two posts... |
| v6413 |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
 v6413 L Plate Warrior
| DMCpro |
 DMCpro Traffic Copper
| recman |
 recman World Chat Champion
 Posted: 22:00 - 31 Jul 2012 Post subject: |
Is the op still here?  |
| kotachi |
 kotachi Traffic Copper
The last post was made 13 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
