points on a cg125!
roundaboutkin...
PostPosted: 21:35 - 17 Jan 2006    Post subject: points on a cg125! Reply with quote
how do i set the points right on my cg125 its driving me mad because its not running properly!
tribal_tiger
PostPosted: 21:52 - 17 Jan 2006    Post subject: Reply with quote
I thought from the title you'd got done for speeding!!
For all of two seconds you were my hero.
But now your not
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
roundaboutkin...
PostPosted: 21:54 - 17 Jan 2006    Post subject: Reply with quote
no ive been done i have three points on my provisional its sucks and im £60 poorer ! lol
Nb
PostPosted: 22:21 - 17 Jan 2006    Post subject: Reply with quote
Try a haynes manual ? You will probably use it for something else once you've bought it. Is your cg red? I saw one on the h3 the other day being ragged across a roundabout. Laughing
PostPosted: 22:44 - 17 Jan 2006    Post subject: Reply with quote
You need a manual, there are pictures and everything.
Basically, you want the points to be JUST opening as the 'T' mark on the flywheel lines up with the timing mark. You do this by losening the screw that holds the 'fixed' (non-moving) part of the points and nudging the points gap open or closed so they will grip a cigarette paper before the timing mark and are open enough so they won't conduct electricity to a bulb as you hit the timing mark.
Then check the gap is within tolerance. As I remember, there is no way of adjusting both the timing and the points gap on a CG125. Set the timing and if the gap is too big, buy new points.
As such, static timing should be good enough. I don't see the point of using a timing strobe on a CG as the timing and gap are a compromise as it is.
roundaboutkin...
PostPosted: 22:54 - 17 Jan 2006    Post subject: Reply with quote
thank you and yes my bikes red and yes it probably was me i got it bac few days ago Smile
There is a gap of 6 years, 196 days between these two posts...
v6413 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
DMCpro
PostPosted: 18:18 - 31 Jul 2012    Post subject: Reply with quote
v6413 wrote:
make sure your magnet is ok check ..for the governer and cam..within magnet....to set the point take it too a highly qualified mechanic who uses the proper equipment like "ignition timer" ,"timing light"...
Well done, you bumped a 6 year old thread
Honda CB-1, TS125X
VW Golf Estate
recman
PostPosted: 22:00 - 31 Jul 2012    Post subject: Reply with quote
Is the op still here? Laughing
kotachi
PostPosted: 22:16 - 31 Jul 2012    Post subject: Reply with quote
Almost certainly not! But I did love it, saw the thread name and thought the same thing as tribal_.. I was about to start hero-worshipping
CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money."
The last post was made 13 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 3.73 - MySQL Queries: 13 - Page Size: 62.8 Kb
