Battery Charging
starstruck
PostPosted: 14:42 - 19 Aug 2012    Post subject: Battery Charging Reply with quote
Hi,
Im trying to charge the battery for
a honda innova 125
the charger I have has the following options
6 volt or 12 volt
4 amp, 2 amp or 1 amp
the charge wires are black and red
do I connect black wire to the negative on the battery ?
Hope someone can tell me the right options
also how long should I leave the battery on charge ?
Skudd
PostPosted: 15:00 - 19 Aug 2012    Post subject: Reply with quote
Blak to neg red to pos................ usually, is it a 12 volt battery or a 6v battery? it should say on the battery.
4 amp= quick charge
2amp= slow charge
1amp=tricle charge
very flat put on 4 amp
down a bit and needs a boost 2 amp
just keeping it topped up 1 amp.
starstruck
PostPosted: 15:09 - 19 Aug 2012    Post subject: Reply with quote
Thanks a lot for that advice,
would 12 hours charge do it ?
PostPosted: 15:21 - 19 Aug 2012    Post subject: Reply with quote
Lower amps = slower charge = better for the battery.
If it has removable caps in the top, take them out and check the electrolyte level is between the max and min marks (don't get any on you, it's sulphuric acid). If it is low on electrolyte, top it up with de-ionised water before you try to charge it.
Leave the caps off while charging, especially if you use the higher charge rates because they can start producing hydrogen gas inside them.
starstruck
PostPosted: 15:39 - 19 Aug 2012    Post subject: Reply with quote
Its definitely a 12 volt battery
it looks to be sealed, theres no way I can
put water in
Ive started the charge at 12 volts,
1 amp.
Ill charge it overnight.... say 14 hours .
starstruck
PostPosted: 15:42 - 19 Aug 2012    Post subject: Reply with quote
The innova is a press button start honda
but Ive been kicking it for the past year.
You d think the mileage Ive done would be charging up the battery but it does nt seem to.
Maybe the euro rules that we have to have the front headlight on at all times stops me getting the batt charged up ?
PostPosted: 15:49 - 19 Aug 2012    Post subject: Reply with quote
If it's been starting and running then the reg/rec is probably fine, but the battery is stuffed. You might be able to recover it with a decent 'smart' charger that will send pulses into it to try and break up the Bad Juju.
Just to check, do you have any electrics at all before you kick start it? If not, have you checked that the main fuse from the battery +ve isn't blown?
starstruck
PostPosted: 16:22 - 19 Aug 2012    Post subject: Reply with quote
SOMETIMES a light comes on to let me know what gear Im in, sometimes the dial is blank.
after a mile or two the lights... and the speedo usually come back on again.
The battery is prob very flat ( though its only 2 years old ) and I cant think that the bike is recharging it.
I did about 100 miles one day and the next day the battery was still pretty flat, no press button start.
Anyway, now Ive found a charger, I might as well give it a go and see if that brings the battery to life.
( Have just checked the battery in my smoke alarm.......... just to be safe !)
cb1rocket
PostPosted: 22:15 - 19 Aug 2012    Post subject: Reply with quote
what is the battery spec? Guessing how long to charge isnt going to help
Skudd
PostPosted: 08:50 - 20 Aug 2012    Post subject: Reply with quote
It does sound like a dud battery and you need a new one.
matto
PostPosted: 11:12 - 20 Aug 2012    Post subject: Reply with quote
I've also had one good result with some careful* dropping of a battery and two that were too far gone.
*I really do mean careful
starstruck
PostPosted: 17:46 - 20 Aug 2012    Post subject: Reply with quote
the only spec I can see
electrolyte filled
non spillable
12 v
6 ah /10HR
Ive decided to give it another o nite
charge at 12 volts and 2 amps
cb1rocket
PostPosted: 18:24 - 20 Aug 2012    Post subject: Reply with quote
no! You have probably just gone and cooked the battery
6 amps / 2amps = 3 hrs charge and that is considered a very fast charge.
I know you have been trying to recharge it previously but that has it mate, get a new battery
starstruck
PostPosted: 19:17 - 20 Aug 2012    Post subject: Reply with quote
If there s no life in it tomorrow, Ill order a
new battery, the MOT is due 1st sep
The last post was made 13 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 79.27 Kb
