| starstruck |
 starstruck L Plate Warrior
| Skudd |
 Skudd Super Spammer
| starstruck |
| stinkwheel |
 Posted: 15:21 - 19 Aug 2012 Post subject: |
Lower amps = slower charge = better for the battery.
If it has removable caps in the top, take them out and check the electrolyte level is between the max and min marks (don't get any on you, it's sulphuric acid). If it is low on electrolyte, top it up with de-ionised water before you try to charge it.
Leave the caps off while charging, especially if you use the higher charge rates because they can start producing hydrogen gas inside them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| starstruck |
| starstruck |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:49 - 19 Aug 2012 Post subject: |
If it's been starting and running then the reg/rec is probably fine, but the battery is stuffed. You might be able to recover it with a decent 'smart' charger that will send pulses into it to try and break up the Bad Juju.
Just to check, do you have any electrics at all before you kick start it? If not, have you checked that the main fuse from the battery +ve isn't blown? ____________________ Biking is 1/20th as dangerous as horse riding.
| starstruck |
| cb1rocket |
 cb1rocket World Chat Champion
| Skudd |
 Skudd Super Spammer
| matto |
 matto Crazy Courier
| starstruck |
| cb1rocket |
| starstruck |
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
