Heat pad for bottom of saddlebag?
EazyDuz
PostPosted: 09:54 - 19 Aug 2012    Post subject: Heat pad for bottom of saddlebag? Reply with quote
I was wondering what can be stuck at the bottom of a leather saddlebag to protect it from exhaust heat either by radient or direct contact.
Would something like this work:
https://www.ebay.co.uk/itm/Black-Heat-Resistant-Flat-Mat-For-GHD-Hair-Straightener-/170859884756?pt=UK_Health_Beauty_Hair_Care_Hair_Straighteners_PP&hash=item27c80af0d4
Or this
https://www.ebay.co.uk/itm/Zing-Silicon-Black-Trivet-Heat-Resistant-Pot-Pan-Mat-17-x-17-cm-/140799671560?pt=UK_Kitchen_Accessories&hash=item20c8507d08
It just has to be stuck on the bottom of the bag. Would either of these do it?
janner_10
PostPosted: 11:57 - 19 Aug 2012    Post subject: Reply with quote
For less than a fiver, order one and try it?
drzsta
PostPosted: 12:14 - 19 Aug 2012    Post subject: Reply with quote
+1
EazyDuz
PostPosted: 17:30 - 19 Aug 2012    Post subject: Reply with quote
Thats good but if it fails i lose £50 worth of saddlebag.
I thought there might be some well known biker trick on the best thing to use
Aff
PostPosted: 17:40 - 19 Aug 2012    Post subject: Reply with quote
Depends how close it is the the exhaust, the end can will get to about 250-300C, I think hair straighteners are about 200C and that heat mat thing has no useful info. Obviously if its a fair way from the exhaust then they will probably be fine.
Electric Bike Project
PostPosted: 20:19 - 19 Aug 2012    Post subject: Reply with quote
I have a silicone mat from lakeland that sits in the bottom of my oven all the time to catch anything that boils over.
Best thing is a carbon exhaust because they don't get hot enough to melt the fabric but that won't work well on a virago.
The silicone will stop the saddlebag melting if it touches the exhaust but it WILL eventually conduct the heat through to the contents of the bag if the bag is resting on it.
That said, looking at pictures of 535s, the panniers should finish up behind where the exhaust finishes anyway.
sibbo1
PostPosted: 20:50 - 19 Aug 2012    Post subject: Reply with quote
you could try heat reflective foil that they line the underside of motorcross bike fuel tanks ???? would make em look bling ??? to boot
cheers
EazyDuz
PostPosted: 21:50 - 19 Aug 2012    Post subject: Reply with quote
Hmm some good ideas, ill try something out. As long as silicone wont burn and bubble onto the exhaust...
hedgehugger
PostPosted: 22:37 - 19 Aug 2012    Post subject: Reply with quote
I use silicon baking pans/trays in the oven. No idea how hot an exhaust gets but the oven does at least 220 degrees and no hint of my silicon going floppy or bubbling Smile
Should be ok for an exhaust shield.
stuartt
PostPosted: 22:38 - 19 Aug 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Plumbing-Plumbers-Heat-Resistant-Mat-300-x-250mm-633540-/230729323237?pt=UK_DIY_Materials_Plumbing_MJ&hash=item35b88a12e5#ht_2012wt_1000
DMCpro
PostPosted: 23:49 - 19 Aug 2012    Post subject: Reply with quote
if your that worried heat wrap your exhaust!
Honda CB-1, TS125X
VW Golf Estate
EazyDuz
PostPosted: 10:11 - 20 Aug 2012    Post subject: Reply with quote
How would i stick it to the bottom, would clear silicone sealant work, or resin or something?
PostPosted: 11:21 - 20 Aug 2012    Post subject: Reply with quote
I'd give the cleap silicone a try first. If it does stick the stuff, it's VERY heat resistant (I've used it to seal header pipes before) and will peel off if you want to remove it at a later date.
Alternatively, you could always wrap it round the exhaust and hold it in place with a couple of jubilee clips when you have the panniers on.
The last post was made 13 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 75.88 Kb
