RF 900 R damaged
hollowgod89
PostPosted: 08:48 - 20 Aug 2012    Post subject: RF 900 R damaged Reply with quote
Right, not my bike,
just wondering if you can point my brother in right direction
Recently, Brothers Chain snapped while riding.
Admittidly he was being a Pleb on the thing for a 'cool' photo.. Lid'less Shocked
Its been stood mayhaps a month now any yesterday we pulled the side fairing to see the actually damage. Where there chain has snapped its torn into some wiring and cracked a hole the size of my thumb into the thing.
First.. This hole. Its pretty much where the water pump mounts, sproket side bolt hole, is it a dry hollow that he can risk filling, or are there bits that may 'interfere' with that thought.. he is a rough arse
Second, There seems to be two wires running from above the engine somewhere down by the sproket. 'This was infact, wound around said sproket and torn' These wires are Black, and lime green/racing green .. into female connecter block, we cant find any trace of a male side down the bike anywhere.. Generator wiring is alot further forward. nuetral light still working fine, Side stand wiring intact. Is there anything else that should run that way?? Only ask as though the bikes turning over, its no longer firing..
third.. why is it impossible to find a haynes manual for these things?
Honda CG125 (died a noble death)- Honda CB125TD (modified and converted into.....) - Honda CB200 Benley Cafe (Burnt to cinders by idiots)- Honda CB500 (training for test) - Honda CB600F Hornet (damn laws changed/ passed test on)- Honda Shadow 750 Trike (borrowed for a month while bike was under service CBR--->)- Honda CBR600 F2 - (The only bike I've know to be a 'He') - Suzuki RF900R (borrowing on a mid-long term basis) - Yamaha XJ600 Diversion (oil rings locked up and seized engime of a f*cking motorway) - Honda CBR1000F hurricane ( Aye she's a fast 'un)
Nick 50
PostPosted: 09:08 - 20 Aug 2012    Post subject: Reply with quote
There is a manual online if it is any help:
https://www.scribd.com/doc/50602570/RF900R-93-98
Also have you got pics of the offending damage?
hollowgod89
PostPosted: 09:57 - 20 Aug 2012    Post subject: Reply with quote
Il have a look and pass it onto bro, Il see if i can get him to snap a few shots off and il get them up here. tried to be as descriptive as i can. Il see if my phone can hold a decent photo, but, i doubt it
hollowgod89
PostPosted: 10:14 - 20 Aug 2012    Post subject: Reply with quote
Okay, some pics of damage. not the best i admit
PostPosted: 11:34 - 20 Aug 2012    Post subject: Reply with quote
Look at the state of that sprocket, no wonder the chain snapped it must be more stretched than Lisa Riley's knicker elastic.
hollowgod89
PostPosted: 12:29 - 20 Aug 2012    Post subject: Reply with quote
No shit. you should see the chain...
Basically, his lack of forsight, he has learnt; 1 the value of replacing sprocket and chain, 2 learnt to replace them both at once
RichieZX6R
PostPosted: 12:47 - 20 Aug 2012    Post subject: Re: RF 900 R damaged Reply with quote
hollowgod89 wrote:
/Snippet
stab in the dark here but could this be for the speedo? some have a speedo that works from the sprocket rather than the wheel..
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
hollowgod89
PostPosted: 13:21 - 20 Aug 2012    Post subject: Re: RF 900 R damaged Reply with quote
RichieZX6R wrote:
hollowgod89 wrote:
/Snippet
30 second glance. Speedo is run from Front wheel on cable, thanks for the suggestion though
Casper
PostPosted: 16:50 - 20 Aug 2012    Post subject: Reply with quote
If the wires go down to sprocket it should either be nutral light switch or oil pressure switch.
Ichy
PostPosted: 18:03 - 20 Aug 2012    Post subject: Reply with quote
From a very poor memory the green is for the neutral and sidestand switch feeding into the interlock circuit. It would explain why it doesn't work but certainly doesn't explain why you think the sidestand switch is working. Confused
hollowgod89
PostPosted: 18:58 - 20 Aug 2012    Post subject: Reply with quote
Neutral light is fine. ie in neutral, light comes on
outa neutral light off..
Why i think it isnt the side stand wiring? been under the bike. Wire runs undamaged from the side stand up the frame and across to the other side of the bike into the loom, unscathed.
Oil pressure light. Not sure. Where would the wiring originate from?
What i have is the female side that runs down to this part of the bike 'from' The loom.
looking for the male connector side and where it runs into the engine
Welding, covering that hole? Are we agreed there are no direct movng parts within that hollow? is it just a dead space?
raak
PostPosted: 20:01 - 20 Aug 2012    Post subject: Re: RF 900 R damaged Reply with quote
aint one out there mate... Sad
best chance is for brother to download manual or sometimes workshop manuals come up on ebay.
best bet is to visit RFOC
most helpful when bike goes tits up.
here i wiring diagram, if thats of any help
https://img.photobucket.com/albums/v471/fastfitter/RF%20Electrical/RFwiringdiagramcoloured.jpg
one guy had similar issue chain snap, and he stripped bike to do other works while off road.
here is pic of his wiring.
https://i874.photobucket.com/albums/ab310/illmor/rf900/Resto/skladanie/DSC_5558-1.jpg
see green/black wire is marked ign (ignition).
( green box cover is starter relay by left side of battery )
https://www.bikechatforums.com/download.php?id=85394
if i read schematic right it is the wire to signal generator.
no expert so may be well wrong.
https://www.alpha-sports.com/spst/1996%20RF900R/55.gif
best ask at the owners club, imho
Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900
Ichy
PostPosted: 20:05 - 20 Aug 2012    Post subject: Reply with quote
Ok so it must be the wire to the signal generator.
Yeah I know it is on the opposite side of the engine but the chain 'might' have caught it, pulled it out and then fed it around the sprocket.
Well you never know Wink
https://ricksmotorcycles.com/shop/images/products/detail_392_08-17_039.JPG
Hahaha while I was looking for a photo someone else posted. See, wasn't such a dumb idea.
hollowgod89
PostPosted: 20:39 - 20 Aug 2012    Post subject: Reply with quote
Raak And Marki .
thank you
Looks like you might have found one of my problems for me, its a bit dark it the garage now, but first light il see where it goes
Now just the hole
raak
PostPosted: 21:05 - 20 Aug 2012    Post subject: Reply with quote
i do really recommend your bruv deffo checks out the owners club
not sure what that area contains or what problems it may cause,
but i guarantee you someone on there will... Thumbs Up
all the best fixing it.
Ichy
PostPosted: 21:08 - 20 Aug 2012    Post subject: Reply with quote
I would take the water pump off and take a look.
The last post was made 13 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.84 - MySQL Queries: 13 - Page Size: 103.06 Kb
