Yamaha XJR 400 carburettor issues - Update!
Leodbroga
PostPosted: 23:39 - 25 Aug 2012    Post subject: Yamaha XJR 400 carburettor issues - Update! Reply with quote
Hey, got myself my first big bike almost two weeks ago, a Yamaha XJR 400 and guess what? It's giving me jip. Bear with me here, because it's pretty confusing.
When I got the bike, it wouldn't idle properly; either at 2.5K - 3k revs or just below 1k, now this problem has been partially solved by getting the carbs balanced today. It now idles around 1.5k revs, which is perfect.
But my issue is that once warm, the revs get 'stuck' at around 2.5K still, so at lights and junctions it's a nightmare to do a smooth pull away. It may sound trivial but I know it isn't right, and to make it even more confusing if I slightly let the clutch out and labour the engine, it can sometimes return to normal idle.
Now, I've asked a few mates, and I think it's either the clutch, which is also very rumble-y and I suppose worn... Or it's the throttle cable getting stuck. I can't see how it would be the carbs seeing as they've been taken apart and were not dirty and are in balance.
So, denizens of BCF, any suggestions? I'm at a loss here.
Yamaha SR125; Yamaha XJR 400; Suzuki GS500E
Rob W
PostPosted: 07:46 - 26 Aug 2012    Post subject: Reply with quote
You may well have an air leak somewhere. Were the carb rubbers in good condition?
Budgetboy
PostPosted: 09:08 - 26 Aug 2012    Post subject: Reply with quote
This ^^ check the vac hoses and carb rubbers for leaks or damage.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Leodbroga
PostPosted: 17:34 - 26 Aug 2012    Post subject: Reply with quote
I took it to a garage so don't have a clue. Probably should have asked I guess!
Where about are these rubbers and hoses? I assume under the tank and connecting to the carburettor?
Thanks for the help, I will try and fix this myself and avoid getting mugged by a garage.
Leodbroga
PostPosted: 00:31 - 04 Sep 2012    Post subject: Reply with quote
Finally got round to taking the tank off and having a look. I think I've found the culprit:
https://cdn.bikechatforums.com/files/223995_4537046545631_763409687_n.jpg
Pretty impressed I got the tank off by myself, especially considering a couple months ago a simple oil change scared me. Thanks Rob, Budgetboy and Dumball! Karma heading your way. Thumbs Up
I noticed that cylinder 2 wasn't running as hot as the other 3, and checking the spark plug it looked hardly used in comparison. Took me a while to put two and two together but obviously it's been running incredibly lean due to the massive air leak. I'm hoping this will stop my idle creep finally.
Any suggestions where I can source a new vacuum hose?
janner_10
PostPosted: 02:18 - 04 Sep 2012    Post subject: Reply with quote
If you have the slack - just cut the last inch off. Failing that as Iain said try a breakers, as long as its in good condition and the same ID you can cut to suit, it doesn't have to come from a bike.
PostPosted: 10:32 - 04 Sep 2012    Post subject: Reply with quote
Measure the OD and ID and look on ebay Thumbs Up
ZaphodBeeble
PostPosted: 15:17 - 04 Sep 2012    Post subject: Reply with quote
That's possibly just a breather for the float bowls. Unlikely to affect the idle if it is.
It's likely that you have worn throttle valve shafts, I've seen this before on an XJR400. They can allow air in and will make it hard to balance the throttles.
EDIT: I'm going blind I think, I can clearly see the bloody vacuum nipple now.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
The last post was made 14 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 68.38 Kb
