Honda CB 125 RS
caferacer
PostPosted: 18:02 - 09 Sep 2012    Post subject: Honda CB 125 RS Reply with quote
Hi everyone,
Bought myself an old CB 125 RS having recently passed my CBT. No mechanical knowledge of motorbikes and without a haynes manual for this bike, I'm having a go at 'winging it'.
I know there are a lot of people who are very knowledgeable on the various honda 125s so it makes sense for me to share my questions on here.
https://desmond.imageshack.us/Himg855/scaled.php?server=855&filename=3gedc1348.jpg&res=landing
https://desmond.imageshack.us/Himg856/scaled.php?server=856&filename=4gedc1355.jpg&res=landing
TheSmiler
PostPosted: 18:09 - 09 Sep 2012    Post subject: Reply with quote
Admire determination but can't see this ending well .. you could of got this amazing looking cg and been on the road.
https://www.ebay.co.uk/itm/290768737967?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
caferacer
PostPosted: 18:25 - 09 Sep 2012    Post subject: Work so far... Reply with quote
Suspension
Replaced rear shocks with some pretty tidy second hand ones, done the araldite trick on the front pitted stantions and replaced the seals. Waiting for original owners manual in post to find out oil capacity.
Brakes
Replaced front disc brake cylinder and seals as old one was pitted and leaking. Had the rear drum apart to 'loosen' off the cam with a hammer.
Electrics
Well it's been running so the battery is clearly not as pants as I thought it would be! Indicators are dodgy, got the brake lights working, front lamp is dim but on, no horn and no tacho reading so all that needs fixing pre MOT. The most I've done on electrics really so far is to renew the ductape holding a rear indicator on.
To do list
Sort electrics
New tubes & tyres
Fill front forks with oil (and air???)
Teflon-Mike
tl;dr
PostPosted: 00:38 - 19 Sep 2012    Post subject: Re: Work so far... Reply with quote
caferacer wrote:
What do you think now?
Err.. £100 for bike, £300 OTR... so £200 for all works...
I suspect you may be being a tad optimistic there.... but... we'll see.
Tyres... yup... good start... but old rusty wire-spoke-rims, I'd want to get them apart and be sure they were worth mounting anything else to before I bought the rubber.... MOT men like the 'excessive rust on wheel spokes' clause to fail something they aren't too happy with..... and steel rims rot from the inside.
But, after lots of patience with solvol and brush, you could get them looking OK, and may be lucky.
If not you will be hunting hard to find something to replace them with, trying to avoid around £30 for a new rim, £25 for a spoke set, and fretting whether you can DIY lace your own wheels, and keep it to £110.. or paying for a pro-build & true, that would, with rims & spokes cost around £150 a wheel or more.
Not going to mention wheel bearings or seals... we hope for the best and a pot of grease......
BUT, pair of 'Decent' tyres for that, will be something like a Mitchelin M45's, which with tubes and rim tape, will set you back about £100, probably a tad more.
So IF your wheels are good, JUST a decent set of tyres will rob half your budget..... £30 for an MOT and £15 for tax, will rob half of whats left...... so it doens't leave you much 'margin' for anything else to need attension... like the odd £10 for a new flasher unit, or a pair of fork gaiters, or any paint....
You might save a few pennies opting for budget rubber.... but you wont save a lot. Cheng-Shits or similar easter brands, in the sizes for that are around the £50-60 mark, for tyres only.... add your tubes and rim tape, you'll only be saving £30 or so.... which wont go very far to cover any as yet to be discovered nasties like hooked sprockets or a rusty tank that wont clean up and constantly gives you silty red petrol and clogged jets.
NOT trying to set you back, knock you down or put you off... BUT... dont get carried away in your optimism, and make sure them mechanicals are solid before spending any real money, and get them electrics de-niggled before presuming anything.
SO many projects die, in a pique of spaghetti, after engines been got running, but electrics wont play ball!
I did a Yam DT last winter.... (did a 125 Super-Dream winter before... I'm no newb to this game!) I stripped it to the frame in three days; dealing with all the stubborn rusty screws along the way. Major bits went to powder coaters; while I stripped and painted the pretty bits. That took me three weeks, and when the bits came back from the powder coaters, I had something that LOOKED like a freshly restored bike, back in one piece within a day....... Took three more months with it living in my living room to sort out all the niggly little bits and rewire the thing so that it had a full compliment of working 'equipment' for an MOT.....
The 'big' things... taking it all to bits, or putting it all back together, getting an engine running.... the things that get you exited and FEEL like you have accomplished something, usually aren't that difficult or time consuming.... it bogs down in the nitty gritty niggly stuff, where it goes slow, and you seem to get so little to show for it, and you start to find costs starting to escalate... and you have barely scratched the surface yet!
Old rule of thumb.... double the amount of time, space, money and hassle you think it will cost, double it again; and you MAY be close to what it will REALLY take....
Your initial hit list seems to put stuff in good order... does it run, look at the brakes, make sure it'll stop, look at the suspension, make sure it'll keep wheels on ground, and make sure them wheels have good tyres.... so promicing... but I do think the budget a tad optimistic, and your a little ambitiouse.
Otherwise... interesting.
SnowTigeress
PostPosted: 00:50 - 19 Sep 2012    Post subject: Re: Work so far... Reply with quote
caferacer wrote:
Thanks for the confidence boost smiler!
Ill be watching this, cool little project Thumbs Up Very Happy Thumbs Up
teffer i want another project Crying or Very sad
ignore smiler,because he could not fix his bike Twisted Evil
I did this project
https://www.bikechatforums.com/viewtopic.php?t=199042
wont say the cost Rolling Eyes
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
Teflon-Mike
tl;dr
PostPosted: 01:02 - 19 Sep 2012    Post subject: Re: Work so far... Reply with quote
You dont KNOW what it cost!
I don't know what it cost!
I'm still in denial of how much it bludy cost!
Microsoft Excell Cant Add Up!
Now... lets see... when you started 'The Pup' on 31st May 2010.. I reckoned it would cost 'about' a grand.... and YOU reckoned that it would take about a weekend to pull it to bits, a week to 'service'; the brakes and stuff..... couple of weeks to scrub up and paint, and then another week to get it all back together and working.... an Month? Wasn;t that how quick you THOUGHT you'd have it done?
Where's that post? What day was it MOT'd on? May 23rd was it, 50 weeks one day after you started? With costs that had gone at LEAST double anticipated budget?
And space.... yes... you thought you could do it all in about twelve square feet of patio under a gazibo..... Reminds me... would you like to go remove your petrol tap from the bath-room windowsill and re-unite it with the strainer and the tank before they get lost!
Hmmm...... TIP for you Cafe.... you could probably save a couple of months off Snowie's project time...... FREEZER BAGS, good marker pen and being ORGANISED, so you know what bits what, where it came from and where it is!
SnowTigeress
PostPosted: 05:46 - 19 Sep 2012    Post subject: Re: Work so far... Reply with quote
Oi i did that just lost a few bits and masking tape fell off most of the parts,anyway he has not got 5 of them slowly coming to bits unlike when i did the pup......I had taking them to bits Twisted Evil
caferacer
PostPosted: 16:21 - 21 Sep 2012    Post subject: Update Reply with quote
Thanks for your responses SnowTigeress and Teflon-Mike!!! I have literally read both your threads the whole way through - sad I know but they really inspired me to have a go myself.
The bike is running nicely at the moment. Suspension is great, brakes working nicely after a bit of work and the electrics are pretty much there now.
Yeah, that budget has gone out the window - surprise! but I'm keeping it as low as I can because I know this is an old bike.
I've fitted some nice old clocks and a round headlamp and I'm looking for bullet indicators for it and a smaller tail light. Just not sure how well the lower seat would really work on such a small bike!
Considering painting the wheels.
At the moment the air filter box is off as I was considering fitting an after-market and making a new bracket for the battery. I really like having the gap in the bike there.
HONDA CB750F; HONDA CB125RS
Matt-
PostPosted: 18:07 - 21 Sep 2012    Post subject: Re: Work so far... Reply with quote
optimistic isn't the word
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
blurredman
PostPosted: 19:35 - 21 Sep 2012    Post subject: Reply with quote
Yay for the 205!
janner_10
PostPosted: 20:17 - 21 Sep 2012    Post subject: Reply with quote
That look likes 1 big bag of sh!t!!
Hear me out though, you will learn so much about your bike and bikes in general rebuilding that, doesn't really matter (within reason) what it costs to get it working again - sense of satisfaction will be enormous.
Best of luck with the project, keep the thread updated. Thumbs Up Thumbs Up
caferacer
PostPosted: 20:19 - 21 Sep 2012    Post subject: Re: Work so far... Reply with quote
Well, costs so far:
Rear Shocks £20
Front Brake £20
Fresh Battery £50
Tyres, tubes & ribbons £75
Headlight £30
Speedo £30
So that's £225 so far...
I'm expecting to spend up to £25 on indicators, and probably the same on a classic style tail light. So that's £275, plus £30 MOT and £15 tax makes it up to £320 which is actually better than I was anticipating!
caferacer
PostPosted: 20:28 - 21 Sep 2012    Post subject: Update Reply with quote
I wish I'd taken more photos of the bits I've done now, if anyone needs any help I'm probably the wrong person to ask but I'd be more than willing to try and help in any way I can.
As I think I mentioned above - another cost was the £10 I forked out for the original owners manual. I couldn't believe the lack of info on the web - owners of the RS are clearly tight as Exclamation! so I've got all the wiring diagrams and specs for the bike if anyone needs them - just ask and I'll upload.
SnowTigeress
PostPosted: 13:09 - 22 Sep 2012    Post subject: Re: Update Reply with quote
caferacer wrote:
The wheels are my last big concern - I've bought some budget tyres, inner tubes and replacement ribbons.
what tyres did you get?
I got michelin m45 for £70, with inner tubes and ribbons it was a £100 or slightly over
caferacer
PostPosted: 22:03 - 22 Sep 2012    Post subject: Update Reply with quote
Haha, ashamed to admit they are 'Cougar' tyres... budget to say the least!
Here's about a million photos to make up for failure to update thread.
https://farm9.staticflickr.com/81175/8013160372_9116bb38db_z.jpg
https://farm9.staticflickr.com/83110/8013160438_c699810d7a_z.jpg
https://farm9.staticflickr.com/80132/8013157479_fe5c343688_z.jpg
https://farm9.staticflickr.com/83113/8013157615_471b8738cc_z.jpg
https://farm9.staticflickr.com/84153/8013157731_a2a00922f2_z.jpg
https://farm9.staticflickr.com/81029/8013160958_5335f3fa02_z.jpg
https://farm9.staticflickr.com/81443/8013161066_4e4949e558_z.jpg
symonh2000
PostPosted: 22:33 - 22 Sep 2012    Post subject: Reply with quote
Should be quite a nice bike when it is done.
I would put money on it being faster than most 4 stroke learners that you buy today as well.
Four strokes is two strokes too many.
caferacer
PostPosted: 23:50 - 22 Sep 2012    Post subject: Reply with quote
Damn straight it will!
In terms of styling left on my list is some sort of cafe seat, black bullet indicators and mounting the headlamp (a little higher than in the photo). Also to decide what to do with the air filter.
Anyone know if the cg indicator/headlight fork mounts would fit it - I assume not as the forks are 31mm and I have a feeling the cg's are smaller?
Peace out
Teflon-Mike
tl;dr
PostPosted: 02:36 - 24 Sep 2012    Post subject: Reply with quote
Honda - CB 125 RS
1983-1986
https://www.motorbikespecs.net/images/Honda/CB_125_RS_83-86/CB_125_RS_83-86_1.jpg
Brakes
Front: Disc
Rear: Drum
Dimensions
Length: 1,960 mm (77.2 in)
Width: 745 mm (29.3 in)
Height: 1,070 mm (42.1 in)
Wheelbase: 1,285 mm (50.6 in)
Dry Weight: 100 kg (220 lbs
Fuel Capacity: 11.0 litre
Electrics
Voltage 12v
Spark Plugs (Iridium) NGK DR8EIX
Engine
Type Air Cooled 4 Stroke SOHC Single
Bore x Stroke 56.5 x 49.5 mm (2.224 x 4.335 in)
Compression Ratio 9.2 : 1
Displacement 124 cm2 (7.53 cu in)
Lubrication System 0.8 litre
Transmission
Sprocket front 16
Sprocket rear 36
Chain Number of Links 108
Misc.
Motorcycle Style ROADSTER
Tyres
Front: 275-18 Tubed
Rear: 300-18 Tubed
Bike was a revamp of the earlier CB125S & CB125J of the mid '70's, using the faithful little Overhead cam single, which had been deemed rather 'fragile' tuned to the extent it was in the early drum braked 125S, to deliver 12bhp. The 'Street-Scrabler' variant of the 125S, the SL was slightly de-tuned to 11bhp and provided the basis for the later, 'bullet-proof' as long as they got thier oil changed XL125 Dirt-Bike, from which Honda took the engine to motorvate the CB125RS.
Its related to the CG125, in as far as that was essentially the original 125S, fitted with retro-tech push-rod engine, delivering 10bhp, for 'developing' markets.
But the 125RS was a 'little gem'. More powerful throughout the rev range, and lugging 15-25Kg less mass than a CG (depending on variant), was a very much more 'spritely' little device with slightly more composed suspension.
The 125 Super-Dream only had slightly more power, but was lugging around 25Kg more mass to get it. It was the 'faster' bike, though point to point there would not be much between them on anything but a fast sweeping A-Road. Super-Dream with more sophisticated mono-shock suspension, more powerful twin piston front brake, and that howling 12,ooo rpm motor would be a little more 'composed' doing it.... while a CG would need a brave or stupid rider to try and keep them in sight, his engine lacking the 'urgency' hauling out of corners, and wheezing when stretched to higher speeds, and getting VERY bouncy through corners..... Only time a CG was likely to go past either the 125RS or 'Duper-Dream was on the way into a corner..... with smoke coming off the inefectual front drum brake.....
A 125 Super-Dream, in decent state is good for a genuine, 70+mph. I have had one up to 70 two-up, and 75, solo, on GPS snail-trails.
The 125RS is probably only a couple of points off for top speed. Its certainly a 70mph motorcycle.
The CG125, is really only 'good' for 65, and favorable conditions that would see it much beyond that, would also benefit a125Rs or 'Dream.
The genuine article Honda CG125, is probably slightly quicker than any of the (chinese) copies it has spawned, and they PROBABLY are in the majority of modern 4-stroke bikes on offer today.......
Which really only leaves a handful of Japanese or European four-strokes for it to square up to.
Yamaha YBR125? Pretty good comparison. Yamaha's answer to the CG125, with its overhead cam SR engine..... 11bhp, claimed 70mph top speed, and 125Kg......
Its actually 'faster' at least on paper than the Honda CBF, which with a claimed 12bhp only manages a claimed 65mph.
The Water-Cooled, four valve CBR125, boasts more power, and a little more speed. On paper the full A1 complient compliment of 14.5bhp, and 72mph...... but carrying as much mass as the old CB125 Super-Dream.
The CBR on paper is within a smidgin of the Yamah YZF-R125, and that powers the Riaju, Derbi & Aprillia four strokes I believe.
There ISN'T a HUGE difference between any of them for performance, and that 70mph top speed, is all VERY condition dependent.... condition of the bike, AND road conditions!
That little 125RS.... its got the 'potential' to cut it with the modern kiddie-go-kwik bikes......
The 'old' Super-Dream, certainly has, and point to point, applying 30 odd years of experience to the job, have left some 'young-turks' on plastic-fantastics shrinking in my mirrors down the lanes.....
On the public road.... the differences in rider skill or stupidity, will almost always be FAR greater than the differences in bikes capability. A complete nutter on a 250 Super-Dream can go faster than Mr Cautiouse on a Hyabusa, for as long as he don't come off!
But between the four-stroke 125's, the capabilities are SO close you don't need to have THAT big a disparity in rider ability or prudence!
That little 125RS? specs are enough to put it at the table for sure. It may not have the bigger power number, but it does have a relatively big advantage in that VERY low weight.
But missing the point, this bike was ALWAYS about cheap thrills.....
Super-Dream was built to match the two-stroke sports bikes on performance and beat them on sophistication.
CG125 was built to match the two-stroke commuters for low cost, total utilitarian transport.
CB125RS was built to deliver a compromise between the two.
Nearly thirty years on? It's a pretty good place to start a project. That twin-shock rear suspension is simple and durable and easy to overhaul. The single piston brake, likewise useful. Forks conventional. Motor, rugged, and easy to work on.
And CafeRacer is starting in the right place tackling the bits that matter most, making sure it will stop, steer and handle.
If the motor hasn't got gummed rings or need a rebore, or a flat cam, or hammered tappets.... little fettling ought to see it find its old sparkle well enough, and the ingredients are all there, for it to have the potential to do its job, and offer a LOT of fun for not a lot of dosh.
Certainly more fun thrashing an old bike you have built, to within an inch of its life, thinking "Whey-Hey! I made it do this!.... I hope it doesn't blow up! What the HECK.... I can rebuild it if it does!" and taking another handful of throttle stretching the cable a bit more tryng to find some extra go.....
Than..... sitting on a plastic fantastic, going into a corner a bit hot, and thinking "Oh PLEASE dont let me drop it! PLEASE dont let me drop it! I CANT AFFORD to DROP IT!"
And of course.... sods law says... you thrash that little single, waiting for it to go 'pop'... it will keep on going..... terrified of cracking the plastic on an R125? Well, Murphey ENT going to let THAT opportunity for mischief pass him by very long!
I really want to see this bike on the road.... another derelict finding redemption. Another owner discovering the joy of creating what they ride.
Cafe? Indicators & stuff? much of a much, usually one bolt fitting, and where there's a will there's a way!
Front forks & headlamp stays? Universal ones can usually be packed out with strips of rubber cut from the old inner tunes you take out of them old tyres!
BUT here and now, multimeter, get the wiring all buzed out, clean all the contacts and connectors in the switches and everything; make sure your flasher is working, and that earths are earthing....
That is where the attension to detail will pay off, and reliability is most likely to be found. Wiring is a nif-naff niggling ball-ache that takes lots of time, and sees little progress, but well worth the effort.
If it has the Super-Dream tail lamp.... plastic casing with metal tube bulb holder.... DRILL through the casing, and put an M4 bolt through to make a direct earthing point, and solder it in place. Original earting arrangement is an ABORTION!
DONT be tempted to use generic crimp connectors for halfords ANYWHERE.... on old oxidised wire, its a recipe for faults and failures and the connector force is so often greater than the crimp force that they pull straight back off the wire anyway!
Go to Vehicle Wiring Products and order a couple of bags of 'Japanese standard' bullet connectors and sockets, and the insulation for them; get a good butane soldering iron and SOLDER them on where needed to get good electrical AND mechanical joints.
Get a roll of green wire and some ring terminals too, to make up 'garanteed' earth returns to the battery, from the common earthing point in the head-lamp, the chassis earth, and the 'one wire' components like the indicators... just saves answering SO many silly questions later!
symonh2000
PostPosted: 08:25 - 24 Sep 2012    Post subject: Reply with quote
Hahadumbarse wrote:
no...
Wait and see. Wink
Most modern bikes are less or similar power but are quite a bit heavier.
caferacer
PostPosted: 21:47 - 24 Sep 2012    Post subject: Thanks :) Reply with quote
WOW!!! Amazing post, thanks Teflon-Mike!!!!!!!
I was just thinking it's getting cold, I should really install some form of heating in my house.. but you have reminded me why the bike is in the living room!!! This is more important right? Please explain this to my gf!
Will definitely be following your advice. I want to do as much as I can to get the bike clean and reliable - the cafe style is cool but not the be all and end all, just prefer it to the square original plastic look.
Quick shot in the dark - does anyone have a shell for a CG 5.5" Headlight unit? The one that came with mine is cracked and I can't find one online!
Teflon-Mike
tl;dr
PostPosted: 23:06 - 24 Sep 2012    Post subject: Re: Thanks :) Reply with quote
Dear Miss CafeRacer's Girlfreind,
In response to above.
In winter, bikes belong in the living room. Look:-
https://i1177.photobucket.com/albums/x349/snowtigeress/odds%20and%20sods/Bike293.jpg
If you get cold, you can start the engine, and warm your hands on the cylinder!
https://i1177.photobucket.com/albums/x349/snowtigeress/Lights%20and%20wiring/104_0028.jpg
But it is ESPECIALLY important if you are working on electrics, as metal density changes with temperature, and this effects all the resistance readings you get, if they are out-side being wind-chilled.
https://s1177.photobucket.com/albums/x349/snowtigeress/Suspension/imag1659.jpg
And Painted parts DO have to be hung in the KITCHEN... where you can put the oven on to help keep them warm and cure the paint properly.... you will appreciate this, especially if you have no central heating!
https://i1177.photobucket.com/albums/x349/snowtigeress/plastics%20and%20tank/104_0225.jpg
It is also quite convenient, to be able to just pic up a part and be able to fettle it in the comfort of your own living room, without having to dress for the occassion.
https://i1177.photobucket.com/albums/x349/snowtigeress/Brakes/imag1044.jpg
The dining room table is also a most excellent work top for those more intricate little jobs, like reconditioning a speedo assembly, overhauling a drum brake, or fitting new seals to a brake caliper. Its clean, its flat, its well lit and close to power sockets.
You NEED to appreciate these things. They are important, and NOT in any way 'unusual'.
And lets be honest here; he's a bloke. If he has to mess around, I'm sure you would MUCH rather have him messing around with motorbikes than anything else.
BUT IN THE LIVING ROOM!
Ah! Hold on a second... think about it! Its for YOUR convenience NOT his!
Where else would he mess around with his motorbike?
At his mums? In the shed at the bottom of the garden? Round his mates?
In the living room, you have 100% supervision and complete 'Nag' access! You can SEE what he's up to and have no need to be suspiciouse that when he tells you he's JUST trying to sort out his big end... he really is..... and isn't knocking back a couple more pints with Steve, down the pub!
You KNOW it makes sense!
Though you MAY like to take note that the person playing with bits of old Honda 125 in all these 'photos.... is a woman.
You see... messing with motorbikes ISN'T just for boys. girls CAN play too!
So, you dont have to grumble you aren't spending enough time together... he's RIGHT THERE... where you can see him.... getting in the way.....
And rather than moaning that you never DO anything together... you can just pick up a spanner and 'help'.
Snowie is a WONDERFUL 'help'..... she took my 750 to bits!
I didn't actually WANT it taking to bits... but hey, its the thought that counts, isn't it!
And no, you dont have to ride on the back of 'That THING' when he's done... its not very comfy, and he'll probably be on L-Plates anyway..... but, well....
When it's done, the living room will seem VERY empty...... so, opportunity for YOU to get a little project like this, and help HIM.....
Then you will BOTH have little bikes, and you can keep an eye on him even when he's 'out for a ride'......
See, it ALL makes sense. There is a certain 'order' to the universe, and within that order, MOTORBIKES definitely BELONG in the LIVING ROOM!
Yours sincerely,
Teflon Mike
_____________________________________________________
Hows that Caf? Do the trick?
Well...... If you shift a Super-Dream engine, can always make a bed up in my caravan.... its got a heater..... just might need some gas! Laughing
caferacer wrote:
Quick shot in the dark - does anyone have a shell for a CG 5.5" Headlight unit?[/b] The one that came with mine is cracked and I can't find one online!
Repair the crack! Plastic or metal? If plastic - plastic weld. If metal, see if you can get it brazed.
caferacer
PostPosted: 21:44 - 27 Sep 2012    Post subject: Reply with quote
It's plastic and I may have already tried to fix it... and just made it worse! Spent too much money trying to sort it out already - ebay is gay - so just want it sorted now!!!!
TheSmiler
PostPosted: 07:31 - 28 Sep 2012    Post subject: Re: Work so far... Reply with quote
https://farm9.staticflickr.com/8029/8013160958_5335f3fa02_z.jpg
caferacer wrote:
To be honest that is looking better than I though IMHO opinion though it would look better with the side panels, new thinner seat, new exhaust and some exhaust wrapping. The no mechanical knowledge was the part that put me in doubts, but so far you have shown great kudos.
https://www.gbsalpine.com/image/collection_part/header_wrap/h_wrap_img.jpg
The last post was made 13 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 164.54 Kb
