random fire extinguisher question.
mysterious_rider
PostPosted: 17:04 - 08 Oct 2012    Post subject: random fire extinguisher question. Reply with quote
Ok this is random, but why are the tanks only classed as '6Litres' When they are like twice the size of a jerry can, and look capable of taking about 12 easily.
Is half of it not used or something?
planning on using one as a tank. Cheers.
oldpink
PostPosted: 17:16 - 08 Oct 2012    Post subject: Reply with quote
normally the top half of the cylinder is where theres a charge that expands to pressurise the contents
I remember stripping the ones in our work to have the charges replaced years ago, something like this
https://www.subcomone.com/images/Inside_of_extinguisher.jpg
mysterious_rider
PostPosted: 17:24 - 08 Oct 2012    Post subject: Reply with quote
Ah damnit. I appreciate the info though! Thumbs Up
If I did choose these as a tank, It won't be easy. I'll have to nip the top off, and run some drill holes around that plating so fuel can go through and make use of all of the space.
Then just reweld it all.
Cheers.
oldpink
PostPosted: 17:30 - 08 Oct 2012    Post subject: Reply with quote
it can be done, I seen one used as a tank on a biker build
they took an extinguisher and made a petrol tank from it
groovylee
PostPosted: 17:57 - 08 Oct 2012    Post subject: Reply with quote
dude,just get an AFFF extinguisher (9 litre one should be big enough) the bottle itself is pretty much the same inside as out, no funny workings inside Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
mysterious_rider
PostPosted: 19:01 - 08 Oct 2012    Post subject: Reply with quote
Hm Couldnt find any cheap of those afff ones, so got myself some water extinguishers.
It has to be cut and welded anyway, so I'll just buy a long drill piece attachment and just put a load of holes in the plate in the middle.
Will also remove the gas canister. I wonder how its held in there... Welded?
hardest part will be welding it all up afterwards!! Laughing
panrider_uk
PostPosted: 22:11 - 08 Oct 2012    Post subject: Reply with quote
The charge is just screwed in i think so they can be serviced/recharged every few years
Mark
Im-a-Ridah
PostPosted: 23:56 - 08 Oct 2012    Post subject: Reply with quote
Can you do pics of the completed item? Would be interesting to see!
oldpink
PostPosted: 00:35 - 09 Oct 2012    Post subject: Reply with quote
Mark
yes they are, AFAIK they are replaced every 2 years thats why I had to unscrew the tops and remove the charge
a guy from CHUBB came around and swapped them out and topped up the extinguisher component if needed (only ever seen water and CO2 being topped up)
screwed them up and signed the service tag on the bottle Thumbs Up
mysterious_rider
PostPosted: 10:11 - 09 Oct 2012    Post subject: Reply with quote
^ Fantastic. I'll unscrew the top and run various drill holes through that plate. Pretty unfortunate that stupid canister will be taking up space, I will try and remove/puncture however.
Plan of action is cut a hole in the top for a cap, if the tanks are alloy, I shall cut up a pitbike tank, and use the top half with the cap and pop rivet it into the tank with an O ring to seal it. And two universal taps underneath (normal and reserve).
If tank is steel I should imagine I'll get it welded, but I want rat style so pop rivets sounds good. Laughing
I'll be running two of these side by side.
Cheers for the help. (I'll be throwing up a project thread with pics in soon anyway)
roadracejoe
PostPosted: 10:39 - 09 Oct 2012    Post subject: Reply with quote
My extinguisher looks very similar to that one, but having took it apart, theres no gas cannister in there. Always thought they were charged with compressed air, but i cant find any valve on it Confused
mysterious_rider
PostPosted: 10:43 - 09 Oct 2012    Post subject: Reply with quote
what type is yours? Water?co2?foam? Or powder?
roadracejoe
PostPosted: 11:04 - 09 Oct 2012    Post subject: Reply with quote
Its powder
groovylee
PostPosted: 00:50 - 10 Oct 2012    Post subject: Reply with quote
the AFFF ones we used on ships were simply hollow bottles, with a long pick up screwed in the top. just below the handle there was a 'tyre' valve which we pressurised to 10 bar with a diving cylinder. bloody brilliant when someone had cross threaded the top and went to pressurise it Smile frosty the snowman anyone? Laughing
syl
PostPosted: 13:32 - 12 Oct 2012    Post subject: Reply with quote
If you're serious about fire, fit one of these to your garage:
https://www.youtube.com/watch?v=wYAOHYKBYas
Current bike: Kawasaki Z750S
The last post was made 13 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 86.6 Kb
