cb125 rebuild - Bit upset
supra3turbo
PostPosted: 20:50 - 11 Nov 2012    Post subject: cb125 rebuild - Bit upset Reply with quote
Hi all,
I received my parts from wemoto, and am disappointed really.
I would have thought that a piston kit, being bought for a twin would come with both pistons, it did not. Now the site isn't showing the 0.75 oversize pistons for sale anymore, and im sat here with one piston??
Also still need to know what parts to buy for the rear suspension linkage, or ill end up buying the wrong bits no doubt.
Is there any downpipes going for sale at all for a cb125 i could really do with some Smile
My carb rubbers are also shot to hell, but i know i cant get these, so ill have to try and find something similar.
Thanks all - Joe
Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
Current Project Suzuki RG125 Cafe Racer
nightshaddow
PostPosted: 22:07 - 11 Nov 2012    Post subject: Reply with quote
https://www.mandp.co.uk/productinfo/580509/Exhausts/Exhaust-Systems-and-Silencers/On-Two-Wheels
exhausts
mike will be along soon for suspension linkage parts i need them myself.....
as for piston kits
https://www.bitzforbikes.co.uk/.75_O--Size_Piston_Kit_%2844.75mm%29-ref-61-2117-52.html
used paul smeeton before a bit on the pricy side but good service from them
i have also looked into carb rubbers there are a few possibilitys of potential matches but cb ones are like rocking horse 5h1t
lozza59
PostPosted: 01:59 - 12 Nov 2012    Post subject: Reply with quote
the image of that exhaust on the link is for the earlier 't' model cb125 the superdream exhaust is slightly shorter (i think) and is slightly upswept in appearance.
if your looking for some downpipes for a 2-1 motad system i have 2 sets for sale Wink im NOT a fan of the 2-1 systems and will be going for some chinese 2-2 exhausts when im near completion Laughing
https://www.ebay.co.uk/itm/HONDA-CB125TD-CB-125-TD-SUPERDREAM-EXHAUST-LEFT-HAND-SIDE-/400332630637?pt=UK_Motorcycle_Parts&hash=item5d35af2a6d
as for INLET RUBBERS make that 3 of us looking ...... so far.
i actually have a mint set on the one bike and a not so bad set on the one im building, then i have 2 sets that are fooked
i might be able to help with the rear linkage issues but depends who gets there first Shocked
https://www.ebay.co.uk/itm/JIALING-JH125-33-REAR-SHOCK-ABSORBER-CONNECTING-ROD-/300617519375?pt=UK_Motorcycle_Parts&hash=item45fe33510f
AND
https://www.ebay.co.uk/itm/JIALING-JH125-33-REAR-SHOCK-CONNECTING-LINK-/330636219198?pt=UK_Motorcycle_Parts&hash=item4cfb74533e
they are jialing chinese parts but i have bought and fitted a set myself to my cb125 and am very pleased with them.
you do HOWEVER have to buy BOTH parts as they only fit one and other. i bought some swingarm sleeves too and they fitted.
if you check through the jh 125 33 parts from 'brooksbarn' they give measurements on most parts so you can check and compare your honda parts.
supra3turbo
PostPosted: 20:45 - 12 Nov 2012    Post subject: Reply with quote
Thanks for the help people Smile
Very interested in the down pipes, PM me with price if you could.
Thanks for the piston info, ill get one as soon as this payment comes through.
Just for a laugh, this is what im dealing with for carb rubbers, its been like this for 2000 miles, and i have to re repair it nearly every week now, its painfull starting it in a morning, but once its been repaired it does work for a while, then suddenly just opens right back up again lol
https://i1158.photobucket.com/albums/p615/supra3turbo/DSC_6674.jpg
I know all my problems stem from the exhaust and rubbers being fooked, but i also know that when i got it the rings and pistons looked ok, but as i said, one side the rings were seized in the piston, i freed them off and made do, but seeing as i have the money, thought id slap a new set in there, with nice fresh gaskets.
Another "problem" is the head gasket i bought last time required me to take some metal lugs out to fit it, it said so in the instructions, do i go for the same type of gasket, honda genuine i think it was Smile
Thanks all Smile
supra3turbo
PostPosted: 09:39 - 13 Nov 2012    Post subject: Reply with quote
Im wondering if something like this will do instead?
https://www.ebay.co.uk/itm/Yamaha-TD2-Pattern-Carb-Rubber-34mm-New-/360509714975?pt=UK_Motorcycle_Parts&hash=item53f00db21f
Teflon-Mike
tl;dr
PostPosted: 15:45 - 13 Nov 2012    Post subject: Reply with quote
supra3turbo wrote:
https://i.ebayimg.com/t/Yamaha-TD2-Pattern-Carb-Rubber-34mm-New-/00/s/MTIwMFgxNjAw/$T2eC16NHJGoE9nuQeS6bBP2FhsWCD!~~60_58.JPG
That's the bit your linked to.
https://i178.photobucket.com/albums/w269/teflons-torque/XX-Forum%20Posts/c-flang.jpg
This is the flange of the carb it has to bolt to.
Note that there are three non co-incident centre lines. The stud holes are off-set from the main body centre by about 6mm. The actual carb-bore (on PD24) is off-set about another 6mm beneath that.
This is the 'trouble'. There are many carb-manifolds out there, but the PD series all have this stud-flange off-set, so you have to look for rubbers that mount to Keihin's and the PD series specifically.
Then you have the niggle that on the CB you have two-banked carbs, and the carbs are attached to individual manifolds on two piece manfolds comprising, the isolation rubbers and inlket 'stubb'.
Most instalations bolt a single carb to a one piece inlet manifold.
Trouble here then is first he mounting angle; Super-Dream's carbs are angled quite significantly 'in' from the engine, even the earlier T-Shock's stubs aren't compatible, angling the carbs 'out'. Then there is the small difficulty of fitting them, one manifold will always mask access to the inner nuts to attach the other! And they will lack balence ports.
Maybe if enough of us get together we could find a rubber moulding Co to make a batch of replacements?!?
PostPosted: 16:50 - 13 Nov 2012    Post subject: Reply with quote
A CB125 TDC carburates perfectly if you ditch the airbox and fit just one of the carbs using a CM125 2-1 inlet manifold and a pod filter.
Not as quick as standard but much quicker and smoother than trying to run with two old, buggered carbs and leaky inlet manifolds.
Can't do it with a twinshock, carb fouls the frame.
supra3turbo
PostPosted: 17:19 - 13 Nov 2012    Post subject: Reply with quote
Thanks for your replies, that sounds a pain in the ass, im stuck... BUT
ive just spoken to a guy who's willing to sell me a Honda cb250n engine, twin, for £200 and he said if it wont run with the 125 cdi and what not, then we'll work our way round that as well, i.e he gives me the cdi's off it, and or wiring loom, but he thinks it should run it???
Im sure teff and others have a BATCH of reasons why this wont work LOL, but what do you think in general, i'm not sure what to do...
Thanks all - Joe
Teflon-Mike
tl;dr
PostPosted: 12:45 - 14 Nov 2012    Post subject: Reply with quote
See other thread.
CB Two-Fifty engine will drop straight in. Needs the ignition diddling via a Y-Piece to fire both CDi's off one inductor, other-wise pretty straight foreward, other than loosing the air-boxes to run single carb.
CB250N 'Super-Dream' is a totally different animal. Counter-Balenced - 'Big-Block' twin, with tripple valve heads. Actually a 400 sleeved down to 250, its a BIG lump, and shares no common mountings. Lots of met-fab to make it fit in the frame, then you are on your own as far as hybridising wiring, fiddling carbs and sorting exhausts etc.
After buying all the bits to do an engine rebuild too..... I'd stick with the original engine. I have a couple of two-into one manifolds knocking about if you want to give Stinks suggestion a go?
supra3turbo
PostPosted: 21:22 - 14 Nov 2012    Post subject: Reply with quote
Thanks teff,
He has both type engines there, the HUGE 250, 400 sleeved down, and the one im planning on getting, basically the same engine as mine but a 250.
It comes with a 2 into 1 manifold and a carb, its only done 20k odd miles and it starts first time.
I think ill try it, can you tell me more about the ignition/cdi y piece?
Thanks - Joe
nightshaddow
PostPosted: 22:56 - 14 Nov 2012    Post subject: Reply with quote
this is the junction i made to make sure the engine fired up on both cylinders correctly.
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/418544_10150662752978846_2114091779_n.jpg
and this is how i left the bike last night
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/429666_10150662752803846_1310482300_n.jpg
Of course i did start it and make sure it was firing first
https://www.youtube.com/watch?v=shcAnK4-0Jo&feature=channel
this is from my cb thread the engine i fitted was a cd engine (360 crank) and the wiring in the bike is the standard (180 crank) basicaly you need to have the triggers firing at the same time for the 360 crank
supra3turbo
PostPosted: 22:21 - 15 Nov 2012    Post subject: Reply with quote
Thanks for that mate, that makes a bit of sense to me, basically, rather than the bike firing every half turn, it makes it fire one complete turn? LOL
Ill get it i think, will be fun Smile
Thanks - Joe
The last post was made 13 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 84.3 Kb
