| supra3turbo |
 supra3turbo Nova Slayer
 Posted: 20:50 - 11 Nov 2012 Post subject: cb125 rebuild - Bit upset |
Hi all,
I received my parts from wemoto, and am disappointed really.
I would have thought that a piston kit, being bought for a twin would come with both pistons, it did not. Now the site isn't showing the 0.75 oversize pistons for sale anymore, and im sat here with one piston??
Also still need to know what parts to buy for the rear suspension linkage, or ill end up buying the wrong bits no doubt.
Is there any downpipes going for sale at all for a cb125 i could really do with some
My carb rubbers are also shot to hell, but i know i cant get these, so ill have to try and find something similar.
Thanks all - Joe ____________________ Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
Current Project Suzuki RG125 Cafe Racer |
| nightshaddow |
 nightshaddow Nearly there...
| lozza59 |
 lozza59 Nova Slayer
| supra3turbo |
 Posted: 20:45 - 12 Nov 2012 Post subject: |
Thanks for the help people
Very interested in the down pipes, PM me with price if you could.
Thanks for the piston info, ill get one as soon as this payment comes through.
Just for a laugh, this is what im dealing with for carb rubbers, its been like this for 2000 miles, and i have to re repair it nearly every week now, its painfull starting it in a morning, but once its been repaired it does work for a while, then suddenly just opens right back up again lol
https://i1158.photobucket.com/albums/p615/supra3turbo/DSC_6674.jpg
I know all my problems stem from the exhaust and rubbers being fooked, but i also know that when i got it the rings and pistons looked ok, but as i said, one side the rings were seized in the piston, i freed them off and made do, but seeing as i have the money, thought id slap a new set in there, with nice fresh gaskets.
Another "problem" is the head gasket i bought last time required me to take some metal lugs out to fit it, it said so in the instructions, do i go for the same type of gasket, honda genuine i think it was
Thanks all  ____________________ Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
| supra3turbo |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:45 - 13 Nov 2012 Post subject: |
https://i.ebayimg.com/t/Yamaha-TD2-Pattern-Carb-Rubber-34mm-New-/00/s/MTIwMFgxNjAw/$T2eC16NHJGoE9nuQeS6bBP2FhsWCD!~~60_58.JPG
That's the bit your linked to.
https://i178.photobucket.com/albums/w269/teflons-torque/XX-Forum%20Posts/c-flang.jpg
This is the flange of the carb it has to bolt to.
Note that there are three non co-incident centre lines. The stud holes are off-set from the main body centre by about 6mm. The actual carb-bore (on PD24) is off-set about another 6mm beneath that.
This is the 'trouble'. There are many carb-manifolds out there, but the PD series all have this stud-flange off-set, so you have to look for rubbers that mount to Keihin's and the PD series specifically.
Then you have the niggle that on the CB you have two-banked carbs, and the carbs are attached to individual manifolds on two piece manfolds comprising, the isolation rubbers and inlket 'stubb'.
Most instalations bolt a single carb to a one piece inlet manifold.
Trouble here then is first he mounting angle; Super-Dream's carbs are angled quite significantly 'in' from the engine, even the earlier T-Shock's stubs aren't compatible, angling the carbs 'out'. Then there is the small difficulty of fitting them, one manifold will always mask access to the inner nuts to attach the other! And they will lack balence ports.
Maybe if enough of us get together we could find a rubber moulding Co to make a batch of replacements?!? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
 Posted: 16:50 - 13 Nov 2012 Post subject: |
A CB125 TDC carburates perfectly if you ditch the airbox and fit just one of the carbs using a CM125 2-1 inlet manifold and a pod filter.
Not as quick as standard but much quicker and smoother than trying to run with two old, buggered carbs and leaky inlet manifolds.
Can't do it with a twinshock, carb fouls the frame. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| supra3turbo |
 Posted: 17:19 - 13 Nov 2012 Post subject: |
Thanks for your replies, that sounds a pain in the ass, im stuck... BUT
ive just spoken to a guy who's willing to sell me a Honda cb250n engine, twin, for £200 and he said if it wont run with the 125 cdi and what not, then we'll work our way round that as well, i.e he gives me the cdi's off it, and or wiring loom, but he thinks it should run it???
Im sure teff and others have a BATCH of reasons why this wont work LOL, but what do you think in general, i'm not sure what to do...
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:45 - 14 Nov 2012 Post subject: |
See other thread.
CB Two-Fifty engine will drop straight in. Needs the ignition diddling via a Y-Piece to fire both CDi's off one inductor, other-wise pretty straight foreward, other than loosing the air-boxes to run single carb.
CB250N 'Super-Dream' is a totally different animal. Counter-Balenced - 'Big-Block' twin, with tripple valve heads. Actually a 400 sleeved down to 250, its a BIG lump, and shares no common mountings. Lots of met-fab to make it fit in the frame, then you are on your own as far as hybridising wiring, fiddling carbs and sorting exhausts etc.
After buying all the bits to do an engine rebuild too..... I'd stick with the original engine. I have a couple of two-into one manifolds knocking about if you want to give Stinks suggestion a go? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| supra3turbo |
| nightshaddow |
 Posted: 22:56 - 14 Nov 2012 Post subject: |
this is from my cb thread the engine i fitted was a cd engine (360 crank) and the wiring in the bike is the standard (180 crank) basicaly you need to have the triggers firing at the same time for the 360 crank ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| supra3turbo |
 Posted: 22:21 - 15 Nov 2012 Post subject: |
Thanks for that mate, that makes a bit of sense to me, basically, rather than the bike firing every half turn, it makes it fire one complete turn? LOL
Ill get it i think, will be fun
Thanks - Joe ____________________ Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
The last post was made 13 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
