R6 exhaust - does it need a remap?
Blunet600
PostPosted: 14:38 - 12 Nov 2012    Post subject: R6 exhaust - does it need a remap? Reply with quote
My exhaust has akropovic exhaust on it, which is e marked. It makes some lovely back firing noise when coming off the throttle.
The bike get hot quite a lot too though.
Does the bike need remapping? It's a 53 r6.
I didn't think it would but saw something on another forum that mention these symptons are a result of bad air and fuel flow. Unbalanced.
Honda - Power of Dreams - NSR 125R - Hornet 600
Aff
PostPosted: 14:43 - 12 Nov 2012    Post subject: Reply with quote
The popping, etc. Will most likely be from the Pair Valve (or whatever Yamaha call their version), if you block this you will stop the popping.
AFAIK the 2003 r6 has FI? If it does, it should be able to cope with just a slip on, if you start modifying the air box/high flow filter as well you will probably need a chip/remap.
Electric Bike Project
Fizzer Thou
PostPosted: 15:49 - 12 Nov 2012    Post subject: Reply with quote
If you have a look at the spark plugs and if the centre core is white-ish then it is running slightly too lean.I am pretty sure that the bike is carbied so you could get away with richening out the air mixture screws by half a turn ie.if standard is two turns out,make it two and a half on all four carbs.
Always have a 'Plan B'
Aff
PostPosted: 15:52 - 12 Nov 2012    Post subject: Reply with quote
Fizzer Thou wrote:
I am pretty sure that the bike is carbied.
I thought 2003 > onwards were FI?
Fizzer Thou
PostPosted: 15:54 - 12 Nov 2012    Post subject: Reply with quote
My friends '53 plate R6 is carbied.
Aff
PostPosted: 16:01 - 12 Nov 2012    Post subject: Reply with quote
Just had a look on the interwebs and as far as I can see they introduced FI in 2003. Your friends must a be a late reg.
Fizzer Thou
PostPosted: 16:08 - 12 Nov 2012    Post subject: Reply with quote
As has been said,maybe my friend's R6 is a late reg according to this
https://www.cmsnl.com/yamaha-yzf-r6ppc-2002_model11118/partslist/B-08.html#results
https://www.cmsnl.com/yamaha-yzf-r6rrc-2003_model11251/partslist/B-05.html#results
Blunet600
PostPosted: 18:16 - 12 Nov 2012    Post subject: Reply with quote
Yeh my r6 is fuel injected... So is there anything that needs doing or do I just leave it as it is?
Thank you.
Blunet600
PostPosted: 19:53 - 14 Nov 2012    Post subject: Reply with quote
Anyone???
0l0dom0l0
PostPosted: 16:25 - 15 Nov 2012    Post subject: Reply with quote
Leave it as is. It will be fine.
If you want to get more power and a better power delivery then get it remapped, if not it won't melt the engine as is.
The last post was made 13 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 65.65 Kb
