zx10r stumbles below 3k when hot
Coxyzxr
PostPosted: 21:48 - 16 Nov 2012    Post subject: zx10r stumbles below 3k when hot Reply with quote
2005 model, love her,especially since my previous love my zxr750 has been written off.
Anyway, when it gets hot it really starts to stumble and pop a bit below 3k, makes riding through town a pig, from cold its fine. Sounds like its too rich? But its all stock including exhaust and has 13k.
Its geared too tall which doesnt help but any ideas??
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
nickerbelly
PostPosted: 22:13 - 16 Nov 2012    Post subject: Reply with quote
the only thing I can think of (and it's a bit clutching at straws) is that when she's hot and on a low fuelling maybe the fuel is partially vaporising in the delivery channel so you get snatchy fuelling as a result, the only other things that come to mind are if the injectors are a little dirty with age (unlikely but possible) or maybe the low fuelling/hot engine scenario causes the injectors to trigger erratically, or if there is a power commander fitted which alters the fuelling enough to cause problems under those particular conditions (again - unlikely though). Probably no help at all but it's all I can think of!! Very Happy
Afterthought - it might also be possible that one or more of the sensors is knacked or out of range, ie exhaust temp, airflow, coolant temp etc. also, as it runs a pressurised fuel system that could cause problems if the pressure switch is slightly out and it's running slightly high or low fuel pressures.
there is a fine line between madness and genius - I have a foot on each side!! Very Happy
Coxyzxr
PostPosted: 22:47 - 16 Nov 2012    Post subject: Reply with quote
WTF! See this is why I like carbs.
nickerbelly
PostPosted: 23:09 - 16 Nov 2012    Post subject: Reply with quote
Laughing me too mate - check my current baby, carbs the size of dustbins!! Very Happy - If I ever bought another bike it would have to have carbs too!! - so much easier to play with!
Fizzer Thou
PostPosted: 23:39 - 16 Nov 2012    Post subject: Reply with quote
When were the valve clearances last checked?
Or the spark plugs replaced?
Always have a 'Plan B'
Coxyzxr
PostPosted: 01:39 - 17 Nov 2012    Post subject: Reply with quote
About couple thousand ago
Fizzer Thou
PostPosted: 11:51 - 17 Nov 2012    Post subject: Reply with quote
What colour are the plugs?
Have you checked the fuel filter?
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 53.78 Kb
