| Coxyzxr |
 Coxyzxr Brolly Dolly
| nickerbelly |
 nickerbelly Derestricted Danger
 Posted: 22:13 - 16 Nov 2012 Post subject: |
the only thing I can think of (and it's a bit clutching at straws) is that when she's hot and on a low fuelling maybe the fuel is partially vaporising in the delivery channel so you get snatchy fuelling as a result, the only other things that come to mind are if the injectors are a little dirty with age (unlikely but possible) or maybe the low fuelling/hot engine scenario causes the injectors to trigger erratically, or if there is a power commander fitted which alters the fuelling enough to cause problems under those particular conditions (again - unlikely though). Probably no help at all but it's all I can think of!!
Afterthought - it might also be possible that one or more of the sensors is knacked or out of range, ie exhaust temp, airflow, coolant temp etc. also, as it runs a pressurised fuel system that could cause problems if the pressure switch is slightly out and it's running slightly high or low fuel pressures. ____________________ there is a fine line between madness and genius - I have a foot on each side!!  |
| Coxyzxr |
| nickerbelly |
 Posted: 23:09 - 16 Nov 2012 Post subject: |
| Fizzer Thou |
| Coxyzxr |
| Fizzer Thou |
The last post was made 13 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
