electrical problems
willybob1987
PostPosted: 05:38 - 14 Dec 2012    Post subject: electrical problems Reply with quote
hey guys i have a slight problem with my electrics on my cg125 copy.
when i put the lights on it seems to kill the battery and the indicators wont work but will do when the lights are off. also when the lights are on and i press the brakes, it dims the lights a hell of alot, almost to the point of nothing.
i thought this was the battery at first so i replaced it but it made no difference at all.
please tell me somebody here has some ideas for me because im really losing my temper with this bloody thing now.
thanks alot Thumbs Up
W, Mulvey
nightshaddow
PostPosted: 08:54 - 14 Dec 2012    Post subject: Reply with quote
sounds to me like a bad earth
Islander
PostPosted: 10:55 - 14 Dec 2012    Post subject: Reply with quote
Yep. This.
Check the main earth point where the black battery lead attaches to the frame.
dolly3900
PostPosted: 13:39 - 14 Dec 2012    Post subject: Reply with quote
Agree with the others, sounds like a dodgy earth in the lighting circuit somewhere.
What I would suggest is popping down to your local motor factors an getting a roll of black wire and some scotchlocks.
bit harsh, but chop the earth to each lamp and replace with new back to the battery (or daisy chain them if you are short on space).
Not a pretty solution, but one which will give you a good earth point for the lamps.
Mike
U_W v2.0
PostPosted: 14:11 - 14 Dec 2012    Post subject: Reply with quote
Mike
while thats acceptable it seems a bit extreme.
it could be something as simple as a bullet connector shaken loose or a bolt vibrated loose. in which case a pair of pliers to tighten the connector or a spanner and threadlock on the bolt.
Islander
PostPosted: 14:13 - 14 Dec 2012    Post subject: Reply with quote
Mike
Using scotchloks is never a good idea - they're terrible connectors and have no place in any decent autoelectric wiring setup!
If you have to splice wiring then use proper crimp connectors and a decent ratchet type crimp tool.
There really shouldn't be any need to hack the wiring about, all you're doing there is introducing future points of failure in the system. Just identify the bad connection and fix that. Thumbs Up
dolly3900
PostPosted: 14:29 - 14 Dec 2012    Post subject: Reply with quote
I would have suggested soldering the connections so as to ensure a great electrical connection, but being unsure of the level of skill of the OP, was not sure how good they were.
Suggested Scotchlocks as they are easy to find and use.
The crimp connections are in my opinion just as bad a connection type as them, but at least you don't need special tools for the original solution.
Islander
PostPosted: 14:33 - 14 Dec 2012    Post subject: Reply with quote
You're entitled to your opinion of course but scotchloks? Really? Laughing
Crimps are far more secure and far more reliable if correctly made. Thumbs Up
U_W v2.0
PostPosted: 14:42 - 14 Dec 2012    Post subject: Reply with quote
for what i've heard crimps are more secure and reliable even if done with a pair of pliers than scotchloks Laughing
AlexW
PostPosted: 15:13 - 14 Dec 2012    Post subject: Reply with quote
On the subject of scotch locks etc, Just look at what manufacturers use, They use proper crimp connectors that rarely fail. Scotch locks fail all the time.
Soldering is IMO a great option vs correctly used crimp connections (And I'm not talking about spade/bullet terminals and that kind of stuff).
Alpha-9
PostPosted: 15:24 - 14 Dec 2012    Post subject: Reply with quote
Mike
That's a terrible idea, don't do this Rolling Eyes
Fzr-600 1999
willybob1987
PostPosted: 10:55 - 16 Dec 2012    Post subject: Reply with quote
ok well when i replaced the battery i also replaced the earth cable that connects the negative terminal on the battery to the frame so i know its not that. is there any other earthing points that i can check?
thanks for the help guys
W, Mulvey
Efes123
PostPosted: 11:09 - 16 Dec 2012    Post subject: Reply with quote
Depending on how much of a copy it it, here's the wiring diagram (taking from the wiring thread https://www.bikechatforums.com/viewtopic.php?p=2322761#2322761 ) for the CG:
https://s574.beta.photobucket.com/user/hmmmnz1/media/Honda/rebelcmx25087-89.gif.html
Get yourself a multimeter and start checking all the lighting earths
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Alpha-9
PostPosted: 13:28 - 16 Dec 2012    Post subject: Reply with quote
Check ALL the wiring!
Get a multimeter, tests voltages when starting, when off, when lights are on etc compare and contrast
Maybe your gen isn't charging the battery and the lights suck it dry?
Then again I thought the lights were wired direct to the gen on CGs as it gets brighter with revs
Fzr-600 1999
willybob1987
PostPosted: 00:40 - 20 Dec 2012    Post subject: Reply with quote
thanks guys. when i get abit of time i will borrow a multimetre and get checking all my wiring. iv heard people talk about the "rectifier" when also taking about electrical problems in older posts. is this worth checking out aswell?
W, Mulvey
The last post was made 13 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.23 - MySQL Queries: 13 - Page Size: 88.79 Kb
