restricting bandit
Rubadub
PostPosted: 20:45 - 01 Jan 2013    Post subject: restricting bandit Reply with quote
I've an 04 GSF600, anyone know if it's the washers in the carbs to restrict this model - someone was telling me these were only used up until 2003.
Thanks
"and now turn of your indicator..." www.irishmotorcycletraining.com
SP1K3_BPsy_1st9
PostPosted: 20:49 - 01 Jan 2013    Post subject: Reply with quote
as far as i know it is i think you can get the kit cheap on ebay all you have to do is get a garage to fit it and sign the certificate
PostPosted: 20:51 - 01 Jan 2013    Post subject: Reply with quote
No you dont.
Fit the restrictors and ride.
You can use the ones in the carb no worries, you can use it all the way up to the 650cc models.
GrumpyGuts
PostPosted: 22:10 - 01 Jan 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Bandit-GSF-600-Restrictor-Kit-33-BHP-certificate-/321035175866?pt=UK_Motorcycle_Parts&hash=item4abf3007ba
Kick start engineering do restrictor plates for a number of bikes, including your Bandit and my Hornet.
All you do is remove the carbs, smear silicone sealant on both sides of the plate (not near the hole), place each plate with the tip of the triangle facing up into the inlet ports and off you go.
Comes with a certificate which needs to be signed by a mechanic, but to be honest I would not bother.
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
haroman666
PostPosted: 22:14 - 01 Jan 2013    Post subject: Reply with quote
As what Paddy said: Slap in whatever restriction you end up with and then ride.
No legalities revolve around the certificates at all.
Only your insurance company might ask for "proof" of restriction but if I remember rightly; Paddy you sent a MSpaint picture that said "My bike is restricted" and they accepted it.
PostPosted: 22:30 - 01 Jan 2013    Post subject: Reply with quote
They did indeed.
No law on it.
PostPosted: 22:32 - 01 Jan 2013    Post subject: Reply with quote
I wouldn't be putting silicone sealant in the intake tract.
GrumpyGuts
PostPosted: 22:34 - 01 Jan 2013    Post subject: Reply with quote
Funnily enough I thought the same, the instructions say you should, unless you only put a small smear where the plates rest against the intake but not past the part where is shows into the engine?
PostPosted: 22:43 - 01 Jan 2013    Post subject: Reply with quote
You can just push them in... They won't fall in.
The inlet gets narrower on the Bandit. Probably the same for other bikes.
SP1K3_BPsy_1st9
PostPosted: 18:35 - 02 Jan 2013    Post subject: Reply with quote
yup i stand corrected on the certificate part i asked my local garage when i went to pick up some parts i ordered and they said the same its just a case of putting in the washers and away you go
Rubadub
PostPosted: 22:01 - 02 Jan 2013    Post subject: Thanks Reply with quote
Thanks for clearing that up - do they go between the carbs and the engine house?
Sounds like it's a reasonably easy DIY Job?
PostPosted: 22:38 - 02 Jan 2013    Post subject: Reply with quote
Bandits aren't the easiest to chuck carbs into, royal PITA to remove them Laughing but yes. Thats where they go.
petechett
PostPosted: 14:18 - 04 Jan 2013    Post subject: Reply with quote
whats the bike like with a restriction? really slow & sluggish?
PostPosted: 14:20 - 04 Jan 2013    Post subject: Reply with quote
100mph-ish, loses most go go over 8-9k.
petechett
PostPosted: 14:22 - 04 Jan 2013    Post subject: Reply with quote
oh right, does it lose all the accerleration power i assume?
PostPosted: 14:31 - 04 Jan 2013    Post subject: Reply with quote
A little.
If it would bother you, don't restrict it.
petechett
PostPosted: 15:50 - 04 Jan 2013    Post subject: Reply with quote
##Paddy## wrote:
A little.
but what if you have a restricted licence and you forget to restrict it? Surprised
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 90.03 Kb
