Warm air blowing hand guards
c_dug
PostPosted: 13:27 - 18 Jan 2013    Post subject: Warm air blowing hand guards Reply with quote
I was riding home last night and think I had a good idea but I'm not sure if it would work? If it is terrible feel free to point and laugh.
I was thinking of buying some cheap second hand off-road style hand guards like this:
https://i01.i.aliimg.com/img/pb/573/160/380/380160573_039.jpg
And running some flexible hose (like a hoover pipe) from behind the engine block into the front of the guards so that it blows hot air onto my hands. I would either drill a hole and pop the pipe through or mold a flange and attach the pipe and cable tie it tight.
I'm unsure if the air would be hot enough to counter the minus eleventy temperatures we get at the peak of winter. I'm also unsure if the Venturi effect of the wind over the guards would create a sufficient drop in pressure to draw the air through the pipes? Assuming the air gets hot enough but doesn't suck through the pipes it would be easy enough to wire two small fans to the ends of the pipes. Though fans kind of defeat the object which is a heating method which can be fitted and removed in less than 10 minutes.
I work in a workshop now so I could actually put something together easily enough, probably a bit late for this year but certainly for next winter.
So, thoughts please?
PostPosted: 13:29 - 18 Jan 2013    Post subject: Reply with quote
Considered this morning. Wouldn't work. No heat was being blown from my engine at 70mph. Physically, it was too hot to touch, no air blowing though.
Muffs and heated grips are the best combination since cheese and marmite.
UnspeedySam
PostPosted: 13:30 - 18 Jan 2013    Post subject: Reply with quote
Don't know if it would be better than just getting muffs personally.
Yambabe has done something along the same lines: https://www.bikechatforums.com/viewtopic.php?p=1961068#1961068
PostPosted: 13:49 - 18 Jan 2013    Post subject: Reply with quote
It might work on a Buell where the fan under the seat blows hot air out. You'd need to start with a wide hose behind the radiator, and you'd need to then go down to a narrow hose to get enough speed in the air to transfer any heat to your hands. The handguards wouldn't keep a still enough air pocket behind them to keep your hands warm.
Hoover tubes, sealed at one end with small holes in by your hand might work if you had powerful enough fan to blow the air through the tubes and suck air through the rad. I'm not hopeful though, otherwise lots of other people would have done it.
Heated grips are probably more efficient.
c_dug
PostPosted: 14:59 - 18 Jan 2013    Post subject: Reply with quote
Hadn't seen that before, great minds Cool
Seems like it would works though.
PostPosted: 15:38 - 18 Jan 2013    Post subject: Reply with quote
Heated muffs?
Run some hose up from your radiator, bit of copper pipe running around inside muffs, leak, scalding water on your hands OMG IT BURNS IT BURNS IT- crash, giblets everywhere, pics.
https://rogerborg.dnsd.me/do-it-faggot.jpg
Moo.
PostPosted: 17:54 - 18 Jan 2013    Post subject: Reply with quote
Yambabe did make some Laughing Have a read of that
https://www.therevcounter.com/uk-motorbike-forum/26782-shonktastic-new-way-heating-grips.html
A2 Passed 18/6/10
thepuma
PostPosted: 18:16 - 18 Jan 2013    Post subject: Reply with quote
Im out.
https://i82.photobucket.com/albums/j273/spenspuma/dragon.png
https://i82.photobucket.com/albums/j273/spenspuma/mqdefault.jpg
https://i82.photobucket.com/albums/j273/spenspuma/theo-paphitis.jpg
https://i82.photobucket.com/albums/j273/spenspuma/0.jpg
https://i82.photobucket.com/albums/j273/spenspuma/hilary-devey.jpg
765 RS
mysterious_rider
PostPosted: 18:23 - 18 Jan 2013    Post subject: Reply with quote
ive got some handguards you can buy, BRAND new, with the metal brace running inside so really strong.
They are black, £15 posted if you want them..
KAWASAKIIIII
uberkron
PostPosted: 20:23 - 18 Jan 2013    Post subject: Reply with quote
I once made a bodge tastic hot air hand warmer for my first moped, a honda today. Being force air cooled it was easy to divert some hot wind, the tubing was swimming pool vacuum hose, and even at idle it was pleasant. The police thought i was attempting some kind of ram air set up so i removed it. On a bike the speeds are higher and areas of pressure and vacuum are not very easy to see without a wind tunnel.
I like the idea of using engine coolant to heat the bars, would definitely need a control valve on that though. It seems this would be cheaper to do in production than heated grips, but your bars would need a bleed nipple.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
stonesie
PostPosted: 21:33 - 18 Jan 2013    Post subject: Reply with quote
On a fared bike it could work if you took air from behind the radiator as most of it, including some heat from the headers comes out of the side vents. I can keep my left hand warm by dangling my digits near the vent, shame about the throttle hand.
Kawksam
PostPosted: 21:38 - 18 Jan 2013    Post subject: Reply with quote
German Army in second World war on the Eastern front with Russia on there BMW and Zunzapps they mounted a pipe off the exhaust going into handle bars effectively early heated grips.
uberkron
PostPosted: 02:19 - 19 Jan 2013    Post subject: Reply with quote
Walloper
PostPosted: 06:52 - 19 Jan 2013    Post subject: Reply with quote
I think you're in Cloud Cuckoo Land so I'm out!
trevor saxe-coburg-gotha
PostPosted: 07:06 - 19 Jan 2013    Post subject: Reply with quote
thepuma wrote:
I wonder if Deborah would ever let me knead 'em?
But seriously - I'd hit that shit. I know, I know. The Horror. I actually would though.
Walloper
PostPosted: 09:07 - 19 Jan 2013    Post subject: Reply with quote
I hear you man.
To quote the oft uttered Glaswegian colloquial, 'Yer hole's yer hole!'
PostPosted: 10:22 - 19 Jan 2013    Post subject: Reply with quote
*draws on cigar, swirls brandy tumbler and nods contemplatively*
MaybeGuy
PostPosted: 11:26 - 19 Jan 2013    Post subject: Reply with quote
If you wanted to put the effort in, water heating would probably work. Wrapping a load of copper piping around the exhaust, along with an electric pump.
https://www.ebay.co.uk/itm/DC-12V-Mini-Electric-Water-Coffee-Pump-24GPH-P-25A-UK-/251212851998?pt=Coffee_Machines_Makers&hash=item3a7d73eb1e
andym
PostPosted: 11:39 - 19 Jan 2013    Post subject: Reply with quote
without actually reading the whole thread, so I don't know if anyone has actually mentioned it, but would it not be a little simpler to run a small water pipe up to the hand guards (on water cooled bikes of course)...
For exaple if I was to add a T junction where possible then run a loop to each side of the handlebars, insulated (and hidden) where it's needed, then there would be a supply of warm water running up to the grips, which would radiate the heat because of the lack of air flow (possibly). Also since there would be no real modification it would be simple enough to take the pipes off and refit the old junctions.
Or just buy heated grips and muffs....
Edit, just read it's already been suggested, not sure how it would spray scalding water ovver you though.... all the pipes that's on the bike that could do that then Confused
recman
PostPosted: 11:42 - 19 Jan 2013    Post subject: Reply with quote
NSFW!!!
PostPosted: 11:49 - 19 Jan 2013    Post subject: Reply with quote
Not suitable for wanking?
mysterious_rider
PostPosted: 11:51 - 19 Jan 2013    Post subject: Reply with quote
Yet nobody has mentioned the possible extra pressure put onto the water pump at the bottom? Might break something.
Surely It'd be better to harvest the exhaust gases and run them through the bars? Only if you could weld mind..
KAWASAKIIIII
recman
That too.
andym
PostPosted: 12:02 - 19 Jan 2013    Post subject: Reply with quote
Would it really cause that much extra pressure on the pump? 3m of 5mm plastic pipe (roughly)... gravity would help out a bit with the water too, if there was more pipe running down than up then it would help ease the strain a bit.
I feel a bit of experimenting is needed Very Happy
The last post was made 13 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 131.33 Kb
