Trying to make a wheel balancer
Tim..
PostPosted: 12:33 - 19 Jan 2013    Post subject: Trying to make a wheel balancer Reply with quote
Decided what im going to make next is a wheel balancer.
I've bought some bearings already, for skateboard wheels.
Wouldnt mind a bit of input from you guys as to the general height and width it should be. Be nice to make it accomodate most types of motorbike.
What diameter are front motorcross wheels with tyres?
Widest rear wheel?
www.marshallracing.co.uk
PostPosted: 12:35 - 19 Jan 2013    Post subject: Re: Trying to make a wheel balancer Reply with quote
A motocross front isn't massive bigger than a enduro rear, as the tyre is much thinner. Probably about the same for motocross.
Afraid I don't have specific dimensions.
I find two chairs and a bit of rod does the job fine Smile.
Tim..
PostPosted: 19:05 - 19 Jan 2013    Post subject: Reply with quote
Cheers G Thumbs Up
Anyone able to throw a tape against a large off road wheel with tyre for me?
at106
PostPosted: 19:24 - 19 Jan 2013    Post subject: Reply with quote
Im not sure how helpful this is but ive just measured my dr350,
Rear
Width 12cm Diameter 65cm
Front
Width 10cm Diameter 70cm
Tim..
PostPosted: 19:28 - 19 Jan 2013    Post subject: Reply with quote
Cheers Thumbs Up Karma .
PostPosted: 19:35 - 19 Jan 2013    Post subject: Reply with quote
A quick look on google says 27.5" - so concurs with the 70cm above.
DrDonnyBrago
PostPosted: 19:40 - 19 Jan 2013    Post subject: Reply with quote
I made mine to bolt to the top of axle stands. Just two pieces of angle steel with a recess cut out, bolt two bearings to each. Height and width adjustable - work very well.
Tim..
PostPosted: 19:46 - 19 Jan 2013    Post subject: Reply with quote
I'm going to make one with a proper base.
Just looked a the talon site and they sell 21" rims which also ties in with the 70cm diameter. I will work to that dimension.
Just need the widest road wheel width now.
PostPosted: 19:49 - 19 Jan 2013    Post subject: Reply with quote
You can get tyres up to 300mm wide without being specially made.
But that's for poncey cruisers.
Think the Rocket III has a 240 section as standard.
Most normal bikes with tyres chosen for performance will be 200 or under - and then 200 only for the most powerful.
Though, I do have a 50cc with a standard (front!) tyre 210 wide, but that's a bit of an oddity (it's a quad bike tyre.)
Tim..
PostPosted: 20:15 - 19 Jan 2013    Post subject: Reply with quote
so a 40cm gap should accomodate any wheel and market available tyre (and the clamps either side for the wheel)
PostPosted: 20:17 - 19 Jan 2013    Post subject: Reply with quote
Seems unlikely you'd need near that - almost half a metre.
Could always make it on a sliding base if you want the option to do the really wide ones.
sickpup
Old Timer
PostPosted: 12:49 - 21 Jan 2013    Post subject: Reply with quote
It may well be cheaper to just buy one. Wheel balancer for £41.99 inc postage.
PostPosted: 13:16 - 21 Jan 2013    Post subject: Reply with quote
You could just prop the bike on a stand, remove the brake calliper and chain then do it in-situ.
Fizzer Thou
PostPosted: 13:35 - 21 Jan 2013    Post subject: Reply with quote
Lots of ideas here
https://beta.photobucket.com/images/wheel%20balancer
But if you want specific dimensions you can pop by as I have one that I use for the front wheel of the KTM and back wheels from the R1 (6" rim)
Always have a 'Plan B'
The last post was made 13 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 82.94 Kb
