Bought the wrong bulb... What is this?
stuarthouston
PostPosted: 22:21 - 24 Jan 2013    Post subject: Bought the wrong bulb... What is this? Reply with quote
Evening all.
The dipped beam on my CG stopped working the other day, so I duly ordered new bulbs online (BA20D fitment, on good authority). Like a div, I didn't check what was actually in there and it turns out that the BA20D is not what my bike takes. Neutral
Can anyone shed some light on what this bulb is called? Old one on the right, naturally.
https://i93.photobucket.com/albums/l78/stuarthouston/IMG_0215_zps2f11b2d5.jpg
https://i93.photobucket.com/albums/l78/stuarthouston/IMG_0213_zpsc704cb5d.jpg
Thanks in advance! Karma
Cyclingbiker
PostPosted: 22:28 - 24 Jan 2013    Post subject: Reply with quote
You have the same bulb that my CG takes. It is an obscure fitting called P15D-3.
You must have heard that the CG has the Bosch fit bulbs, which is likely true for the later models, but in fact the earlier models take these stupid bulbs. AFAIK they don't do halogen bulbs with this fitment so I have taken the step to replace the whole headlight so I can get a decent bulb in there!
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
nightshaddow
PostPosted: 22:33 - 24 Jan 2013    Post subject: Reply with quote
Thumbs Up this
is imho the best bet cg's have crappy lighting even the newer ones lots of replacements you can use
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Raffles
PostPosted: 22:56 - 24 Jan 2013    Post subject: Reply with quote
Had you visited your local bike shop then you would now be in possession of the correct bulb for your bike.
Peoples that choose to purchase from online ''Dell-Boys'' deserve all of the misfortune that they encounter.
stuarthouston
PostPosted: 23:57 - 24 Jan 2013    Post subject: Reply with quote
@Cyclingbiker/nightshadow: Thanks kindly, gents. Did I spy that it's a GS500 lamp you're going for, Cyclingbiker? Certainly something to consider in the future, but a cheap fix to get me back on the road will do for now. Thumbs Up
@Ollie1995: Likewise. Tried to fit it in; wouldn't go, only then did I offer it up to the old bulb and discover they were totally different! Rolling Eyes
@Raffles: You say this... Last time I visited my local bike shop for a sidelight bulb (right before my MOT) he said 'no worries pal, I'll stick it in for you too if you want?'. Excellent, says I. New bulb fitted, off to the MOT station, pass. Imagine my surprise when I got home to discover that my sidelight wasn't working. The 'professional' had put a 6V bulb into my 12V bike, which had subsequently gone pop! Note that I do not blame the seller for my misfortune, but myself for not checking first. Chances are, if I'd gone to the bike shop, I'd have said 'one BA20D 35/35W 12V please!' not let him fit it just to 'be sure I had the right thing' after last time and ended up with the same issue!
Perhaps, more accurately in this case, people who fail to compare old for new deserve all the misfortune they encounter. You live, you learn though, eh? Wink
TheSmiler
PostPosted: 02:17 - 25 Jan 2013    Post subject: Reply with quote
Personally think it would better to replace the normal with LED bulbs for the indicators/tail light and then HID headlight upgrade. Less strain on the battery and the motor then as well as providing better lighting quality.
Personally I'm deciding on whether to do it and save upgrading for the future.
Cyclingbiker
PostPosted: 23:21 - 25 Jan 2013    Post subject: Reply with quote
Just found this:
https://www.norbsa02.freeuk.com/goffybulbs.htm
https://www.norbsa02.freeuk.com/MiniPreFocus3lug.gif
Minature Pre-Focus P15D25.3
That should fit your headlight without any modification and give out more brightness so you can actually see what is in front of you.
Also found this:
https://www.wemoto.com/parts/picture/hl-770005/
Not sure but it could fit in the plastic holder inside the headlight in place of the current P15D one. It is just press-fit in there and may just be a straight swap so you can then put your new bulb in there. You will have email or call Wemoto to get the sizing of it so you can see if it will fit.
YBR Ric
PostPosted: 18:49 - 27 Jan 2013    Post subject: Reply with quote
B1235MPF3QH Rolling Eyes
stuarthouston
PostPosted: 11:58 - 29 Jan 2013    Post subject: Reply with quote
Karma to you, sir. Many thanks. Shall whip the bulb holder out tonight and get some measurements to send to WeMoto. If nothing else, it'd be useful to actually be able to use a more commonly available bulb!
bezzabsa
PostPosted: 15:18 - 29 Jan 2013    Post subject: Reply with quote
get down the local scrappy, and 'borrow; a H4 3 pin plug, and wire...plenty of room in the CG headlight to fit it just be careful of what wattage you put in there..
Cyclingbiker
PostPosted: 18:09 - 29 Jan 2013    Post subject: Reply with quote
Halfords do a H4 bulb holder for just over £3. Ideal for my new H4 headlight which is now fitted and running brilliantly.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_379545_langId_-1_categoryId_255229
I don't think the CG headlight will take a H4 bulb though. The lugs are quite wide and they locate in built-in slots on the reflector (at least they do on mine). The CG headlight has a plastic holder that in turn holds the bayonet fitting for the crappy bulb. It may be able to hold the BA20D fitting but I can't be sure.
The last post was made 13 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 74.98 Kb
