Moto Guzzi Cali - Marelli 441 ECU Help needed.
ZaphodBeeble
PostPosted: 14:00 - 25 Jan 2013    Post subject: Moto Guzzi Cali - Marelli 441 ECU Help needed. Reply with quote
Hey guys,
This is a tricky one. The bike is a 1997 Moto Guzzi California 1100 which has a Marelli 441 ECU. I need to identify the component in the below image which is attached to the ECU's PCB. I don't think it's activating the ignition coil relay which it should be doing. I would replace the ECU but I can't see any on ebay etc.
Any suggestions as to what it may be?
Cheers.
https://i.imgur.com/el6r1fI.jpg
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Codemonkey
PostPosted: 14:14 - 25 Jan 2013    Post subject: Reply with quote
Looks like a ceramic hybrid module (silicon die placed directly on the board and wirebonded then epoxy dipped) if you're referring to the big white thing. Could be almost anything. Is there a part number printed on the other side ?
Test Passed 10/05/2011 Current bike: XJ6-N
ZaphodBeeble
PostPosted: 15:08 - 25 Jan 2013    Post subject: Reply with quote
Yeah I'm referring to the 'big white thing' Smile I neglected to mention that in the OP.
I don't think it's a single silicon die placed onto it, there are a series of square and rectangular 'lumps' under the resin which are probably small form factor capacitors, resistors and/or transistors.
One of the outputs from this module feeds a Vcc line on a CA3262 power driver chip. I originally thought this chip had blown but I couldn't get any reading on the Vcc line. It should be 5V I believe. I'm wondering if the white blob thing is a bespoke circuit built for this ECU. Perhaps one part of it is a voltage regulator/converter to drop the 12V feed down to a 5V Vcc. Hmm dunno.
No part numbers unfortunately.
Codemonkey
PostPosted: 15:44 - 25 Jan 2013    Post subject: Reply with quote
Could be all sorts in there, quite possible multiple IC's (a multichip module, I work for a company that amongst many other things has produced a few, doubt we had anything to do with that one though).
Quite possible its custom made for the app especially if there are no markings, but there are a few off the shelf parts packaged like that. Maybe if you can work out what that part of the circuit is supposed to do it might help your search.
ZaphodBeeble
PostPosted: 16:11 - 25 Jan 2013    Post subject: Reply with quote
Ok thanks. I'll have another look at it later and try to work out what pins do what etc. Thumbs Up
ZaphodBeeble
PostPosted: 09:53 - 01 Feb 2013    Post subject: Reply with quote
I've removed the wax covering from the PCB to expose the circuitry. Some more images this time in album format:
https://imgur.com/a/gpE9D
Any ideas now? Smile
The last post was made 13 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 8.32 - MySQL Queries: 13 - Page Size: 48.45 Kb
