| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 14:00 - 25 Jan 2013 Post subject: Moto Guzzi Cali - Marelli 441 ECU Help needed. |
Hey guys,
This is a tricky one. The bike is a 1997 Moto Guzzi California 1100 which has a Marelli 441 ECU. I need to identify the component in the below image which is attached to the ECU's PCB. I don't think it's activating the ignition coil relay which it should be doing. I would replace the ECU but I can't see any on ebay etc.
Any suggestions as to what it may be?
Cheers.
https://i.imgur.com/el6r1fI.jpg ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Codemonkey |
 Codemonkey Crazy Courier
| ZaphodBeeble |
 Posted: 15:08 - 25 Jan 2013 Post subject: |
Yeah I'm referring to the 'big white thing' I neglected to mention that in the OP.
I don't think it's a single silicon die placed onto it, there are a series of square and rectangular 'lumps' under the resin which are probably small form factor capacitors, resistors and/or transistors.
One of the outputs from this module feeds a Vcc line on a CA3262 power driver chip. I originally thought this chip had blown but I couldn't get any reading on the Vcc line. It should be 5V I believe. I'm wondering if the white blob thing is a bespoke circuit built for this ECU. Perhaps one part of it is a voltage regulator/converter to drop the 12V feed down to a 5V Vcc. Hmm dunno.
No part numbers unfortunately. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Codemonkey |
| ZaphodBeeble |
 Posted: 16:11 - 25 Jan 2013 Post subject: |
Ok thanks. I'll have another look at it later and try to work out what pins do what etc.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| ZaphodBeeble |
 Posted: 09:53 - 01 Feb 2013 Post subject: |
I've removed the wax covering from the PCB to expose the circuitry. Some more images this time in album format:
https://imgur.com/a/gpE9D
Any ideas now?  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
The last post was made 13 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
