| FullOnFazer |
 FullOnFazer Two Stroke Sniffer
| AlexW |
 AlexW Spanner Monkey
| Copycat73 |
 Copycat73 World Chat Champion
| FullOnFazer |
 Posted: 18:19 - 28 Jan 2013 Post subject: Advice |
New seals due to arrive tomorrow - its just i dont see any way of getting the pistons out to put new seals in!
We're talking a good 2hrs of effort with various methods. Not tried the pneumatic method ive seen mentioned on here - Would a foot-pump be capable?
My other issue is if these calipers touch, there's no way in hell I'll seperate them again - will they fall out before touching or not?
Also, I've used carb cleaner to clear em up, then WD40 to lubricate trying to get pistons out.
Sorry for all the questions!
Thanks  ____________________ 33bhp Yamaha Fazer FZS - Thats how full on. |
| StevenF |
 StevenF World Chat Champion
 Posted: 18:50 - 28 Jan 2013 Post subject: |
A seized calliper will likely mean your piston is seized, if it's seized, it's not likely to come out easily! I removed the bleed nipple and inserted a car pump. Eventually the pressure built up and the piston came out. If you're using this method make sure to have your hands well clear of the caliper or use a peice of metal to stop it flying about.
If its still connected to the system you could try just splitting the caliper and pumping the break; the pressure from the fluid should force it out. ____________________ My Project - Honda CBR 600 F2/FM |
| 400t |
 400t L Plate Warrior
| bikenut |
 bikenut World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 19:53 - 29 Jan 2013 Post subject: |
Get a G Clamp to hold free piston in while you pump the stuck on out. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| GrumpyGuts |
 GrumpyGuts World Chat Champion
The last post was made 13 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
