De-restriction question for NS125R
Fallen Angel
Franny the Nanny
PostPosted: 21:47 - 12 Nov 2004    Post subject: De-restriction question for NS125R Reply with quote
Right, we've got the restrictor out of the exhaust and were looking for the one in the Air Intake, but not sure if there actually is one!! Confused Is it possible that the bike was only restricted by the exhaust or do the two normally come hand in hand?
Cheers in advance! Thumbs Up
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
alains
PostPosted: 22:04 - 12 Nov 2004    Post subject: Reply with quote
the restrictor is beetween the carburator and the cylinder . it's a flat piece of metal with a round hole in the middle . if you've got some money i would recommand to fit carbon reed . remember you probably also need to upjet your carb like main 145 idle 45 power 70 https://www.dellorto.co.uk (£2.95 ex VAT each jet) and mount a BR9EIX https://www.sparkplugs.co.uk . the valves opening can be also improved (especially for high revs)
Silver 0wl
PostPosted: 22:11 - 12 Nov 2004    Post subject: Reply with quote
but the question there was do the two restrictions (i.e. exhaust restrictor and air intake restrictor) come hand in hand, or do some bikes only have it restricted in place, i.e. can the bike be restricted just by the exhaust restrictor?
www.cliqueycuntsmcc.co.uk
Smoke them if you got them, if you ain't got them, then go get them! Surprised
PostPosted: 22:21 - 12 Nov 2004    Post subject: Reply with quote
Being an NS there was no inlet restriction, although the airbox is quite restrictive.
Silver 0wl
PostPosted: 22:25 - 12 Nov 2004    Post subject: Reply with quote
Kickstart, wonder if you can tell me then how much of a performance difference we should notice then with de-restricting the exhaust?
Cheers mate! Thumbs Up
PostPosted: 22:27 - 12 Nov 2004    Post subject: Reply with quote
From memory quite a lot of difference, from a true 70 and a bit to a true 90ish (although the speedo would read higher). The easiest thing to do was to fit a Micron. Not sure the one you have pulled out was the only restriction. Also if I remember the silencer was quite restrictive. Think DEP made a suitable replacement silencer.
Silver 0wl
PostPosted: 22:32 - 12 Nov 2004    Post subject: Reply with quote
cheers Thumbs Up Thumbs Up Thumbs Up
alains
PostPosted: 22:47 - 12 Nov 2004    Post subject: Reply with quote
i recommand a jollymoto exhaust line 402 CARB (+2.5 hp) and upjetting
Fortuna
PostPosted: 03:29 - 13 Nov 2004    Post subject: Reply with quote
That's how I deristricted my NS. Tank cutter to the exhaust. If I recall that's all the restriction it has. Oh yeah I put carbon reeds in mine too Thumbs Up
Fallen Angel
Franny the Nanny
PostPosted: 13:12 - 13 Nov 2004    Post subject: Reply with quote
Cheers Fortuna - what kind of difference did you notice in it's peformance after de-restricting yours?
Fortuna
PostPosted: 01:50 - 14 Nov 2004    Post subject: Reply with quote
Quite a bit for such a small bike Thumbs Up
Ian (GPX)
PostPosted: 02:30 - 14 Nov 2004    Post subject: Reply with quote
NS125R/F models
The only restriction is the exhaust, small washer in the front of the pipe and a plate thats in the end can (you need to take the end can off to see the plate, undo the 3 allen bolts that hold the end can to the exhaust and look inside that end and you will see it), both can be removed. Also change the reed valve for a race spec one and take away the air box and fit a K&N air filter, you might also need to rejet the carb, but in most cases you can play around with the needle hight to boost the power.
Stock 75mph to around 95/7mph with the above mods, or if you find a Micron exhaust you could top 105mph.
Honda's MBX125F was the same if I remember, as was Yamaha's RD125LC.
Fallen Angel
Franny the Nanny
PostPosted: 12:08 - 14 Nov 2004    Post subject: Reply with quote
Ian, cheers, the only thing we've done so far is remove the restrictor pipe as in the piccies above - is it advisable to do the other things you mention then before riding it again?
Flywheel
PostPosted: 12:23 - 14 Nov 2004    Post subject: Reply with quote
hi
i have an ns125r with a micron,air filter and carbon reeds on it and it tops out at 87/90mph. the micron gave it more acceleration but actually a slower top speed, which i thought strange. you are better to remove the restrictor in the exhaust, fit a pod type air filter and change the front sproket to 12 teeth, this should get you a ture 90mph and save you waisting money.
Other thing would be a big bore kit, dont know where to get them or how much they are though cause i would like a 180cc preferably myself.that would get you 110mph i would think anyway nut not too sure.
cya
The last post was made 21 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.42 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 86.37 Kb
