| Clutchy |
 Clutchy World Chat Champion
 Posted: 16:13 - 01 Feb 2013 Post subject: Inspecting a reg/rec on a cbr 125 04 EDIT: started charging? |
Worked out that the battery isn't being charged, so I'm guessing this could be down to the alternator or reg/rec.
Do not currently have a multi-meter so just doing a visual inspection today, heard I'm looking for burn marks on the connector?
Problem is, where is the reg/rec on this bike? Any help on doing this or diagnosing the problem would be greatly appreciated. Karma given. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Casper |
 Casper World Chat Champion
| Aff |
 Aff World Chat Champion
| Clutchy |
 Posted: 16:43 - 01 Feb 2013 Post subject: |
1888 Will do, thanks.
Aff quite possibly the most helpful post I've had on bcf thanks so much! Couldn't find anything on google. Oh checked the main fuse and it had a 25 amp fuse in instead of the 30? Changed to 30 now, doubt it will make a difference, just odd is all.
Manual says 30 amp too ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| CarlosCBR |
 CarlosCBR World Chat Champion
 Posted: 17:02 - 01 Feb 2013 Post subject: |
Im not sure how accurate that picture is, when i had both of my 2005 CBR125s, the reg/rec was behind the RHS tail fairing.
However if you have a different year (post 2010) then you may have to disregard what i have said.
Only eectrics down the left hand side of my engines were the neutral switch iirc. ____________________ https://www.youtube.com/watch?v=1OPv5mDPQ14
https://www.facebook.com/carl.simmonds.7 |
| MarJay |
 MarJay But it's British!
 Posted: 17:14 - 01 Feb 2013 Post subject: |
If you do get a multimeter this will be your bible:
https://www.electrexworld.co.uk/acatalog/pdfs/Troubleshooting-3P-PMG-&-RR.pdf ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Clutchy |
 Posted: 19:10 - 01 Feb 2013 Post subject: |
Same model as yours carlos, I remember seeing it in one of your threads.
Went to B&Q asked if they had any multimeters, asked 4 girls none of them knew what it was.
Went up to a bloke who worked there and said 'thank god, a bloke, at least you'll know what this simple tool is, do you have any multimeters'
To which he replied 'what's one of them?'
Me and my mate burst out laughing and just walked out.
Halfrauds are a lot more knowledgeable all round.
Tah for the link mate.  ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Casper |
 Posted: 19:43 - 01 Feb 2013 Post subject: |
| Clutchy wrote: | Same model as yours carlos, I remember seeing it in one of your threads.
Tah for the link mate.  |
I find that as fucking shocking. I take it you got one. |
| Clutchy |
 Posted: 19:44 - 01 Feb 2013 Post subject: |
Indeed I do, £20 from halfrauds ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Casper |
 Posted: 19:49 - 01 Feb 2013 Post subject: |
| Clutchy |
 Posted: 20:04 - 01 Feb 2013 Post subject: |
Useless people! ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Aff |
| Clutchy |
 Posted: 19:05 - 02 Feb 2013 Post subject: |
Quick update:
Checked the bikes current leakage came in at 37 mA so that's good.
Tested again, the batt terminals to see if there was 13.7-14.5 v while idling, came in at 12.4v so there's definitely no charge.
Visually inspected wires all around the bike and the ones that go into the reg/rec they seemed fine, found a snapped earth near the front R indicator, pushed them back together, made no difference.
Then followed the wires from the alternator to the reg/rec and one of the box's (not sure what to call it) the black one in the Aff's pic looked a bit shitty so tried to clean that up, along with any connectors concerning the reg/rec connectors. No burnt connectors going into the reg/rec.
Monday I'll test the reg/rec and see if that's broken. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Clutchy |
 Posted: 19:08 - 02 Feb 2013 Post subject: |
Just remembered, when checking to see if the batt was being charged, there was no change in voltage up to 5500 rpm but around 6k plus the battery voltage across the terminals suddenly dropped to around 8/9 volts. Is that just the reg/rec protecting the batt from being over charged at high revs?  ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Casper |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 22:27 - 02 Feb 2013 Post subject: |
^^^Agree about reg/recs being finicky in death. I had one that showed correct charging voltage when the bike was first started. After a few mins it would stop charging. I switch off the ignition and back on and it would start charging again. I'll add that I'd checked the stator's output (3phase system) and it was within limits.
It seems reg/recs are a very common failure on all types of bikes, so much so I installed a LED that glows green when getting charged and red when it isn't. At least it would give me enough time to limp off a motorway or maybe get home. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Clutchy |
 Posted: 21:09 - 11 Feb 2013 Post subject: |
Ordered a used reg/rec for a tenner and stator/coils for 30, hoping it's just the reg but at 30 notes I had to get the mag thing aswell, how are they to fit? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Timmeh |
 Timmeh World Chat Champion
| J.M. |
 J.M. World Chat Champion
| J.M. |
 Posted: 00:23 - 14 Feb 2013 Post subject: |
On a side note... I have a copy of the CBR125 (old shape) workshop manual if you need it (PDF). If you do, drop me a PM with your email address and I'll email it over to you  ____________________ 2004 R1 & 2018 XSR900 |
| Clutchy |
| Clutchy |
 Posted: 11:55 - 15 Feb 2013 Post subject: |
Ahhhhhhhggghhhh!!!!!!!
Just put in the new reg/rec and it hasn't made a fucking difference!
Any other ideas before I attempt to change the stator/alternator ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| J.M. |
| Clutchy |
 Posted: 14:25 - 15 Feb 2013 Post subject: |
Essex-ish/London. Updated the map now.
JM can you shed some light on this possibly?
Test for charging issues:
Step 5 - Generator Leakage Current Test
Disconnect the wire harness from the generator stator to the RR (Regulator Rectifier unit). Set the meter to measure OHMS, and probe into the open end of the block connector. Measure the resis- tance from any of the generator stator wires to the frame ground (battery -VE). A reading of less than about 10kOhms indicates damaged insulation in the stator winding, which often is indicative of a shorted turn fault at engine running temperatures. A reading of greater than 10kOhms does not actu- ally prove the generator is good, but a lower reading always indicates an insulation problem.
On the multimeter before anything is connected up, (this is on the OHMS setting) it shows 1 as you would expect, however, when doing what step 5 says, I don't actually get a change of ready on any of the connectors, and it remains unchanged on the screen (at 1). Is this showing completely fucked Stator then? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Aff |
 Posted: 14:57 - 15 Feb 2013 Post subject: |
If your doing the test right and have the meter on the correct setting, then it means you have a break in the circuit.
Test its continuity. Will most likely be a little diode symbol on the multimeter, with a sound symbol next to it (like the windows volume symbol or the android Wifi symbol)
If your getting continuity I would say you're on the wrong setting on the multimeter.
If you don't then you have a problem somewhere which will probably come apparent when you take it apart. Either a break around the plug or a serious breakdown in the stator wires insulation. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
The last post was made 13 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
