TRACKER
richfar
PostPosted: 11:37 - 09 Feb 2013    Post subject: TRACKER Reply with quote
Hi,
Has anyone used one of these, i have been given one but not sure how to set it up as no instruction. Exclamation
Thanks Richfar
https://www.ebay.co.uk/itm/Mini-GSM-GPRS-GPS-SMS-Real-Time-Network-Vehicle-Motorcycle-Bike-Monitor-Tracker-/390508588602?pt=UK_Car_Accessories_Safety_Security&hash=item5aec202e3a
Ja7
PostPosted: 15:21 - 09 Feb 2013    Post subject: Reply with quote
Seen them but never used one, let us know if there any good, there are basic instructions on the link you gave are they no good.
Edit just found this dunno if any good.
https://www.uescn.com/dowlist.php?id=23
bridgedino
PostPosted: 16:03 - 09 Feb 2013    Post subject: Reply with quote
I just removed mine. I found if my bike was sat un-used for 3 or 4 days then it drained the battery. I suppose a trickle charger would solve that problem.
Appart from that it worked fine, it replied with a google maps location text in reply to me texting it for its location no problems.
The instructions weren't the clearest to be honest. I'm waiting for a self powered replacement, something like a cheep smartphone.
ian505050
PostPosted: 16:35 - 09 Feb 2013    Post subject: Reply with quote
I fitted the same one and it has not drained my bikes battery over a 2 week period of the bike being sat
richfar
PostPosted: 16:58 - 09 Feb 2013    Post subject: Reply with quote
Thanks will let you know how i get on, this may be a stupid question but what is the white wire for and where does it go.
Richfar
Ja7
PostPosted: 20:26 - 09 Feb 2013    Post subject: Reply with quote
White wire ignition by the look of it
https://www.liveviewgps.com/how+to+install+a+hardwired+gps+tracker.html
Ammoman
PostPosted: 00:04 - 11 Feb 2013    Post subject: Reply with quote
Anyone give us a review on this product sounds to good to be true at that price Shocked . Or anyone recommend a tracker system...
2013 ZZR1400 & Honda CG125 1986..
LordShaftesbu...
PostPosted: 09:19 - 11 Feb 2013    Post subject: Reply with quote
How hard would it be to wire it to a separate 12v battery pack?
https://www.batteryground.com/img/3/229/1.jpg
bridgedino
PostPosted: 09:52 - 11 Feb 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Hidden-Auto-Motorbike-Motorcycle-Quad-Mini-GPS-Tracker-GSM-Tracking-Device-New-/111006596854?pt=UK_In_Car_Technology&hash=item19d8823ef6
Yes it would be easy enough to connect it to its own power source, it operates from something like 7-30v so there plenty of scope there
This is the actual one I bought. It's only weak point being the lack of its own power source. Other than that it worked ok. It basically responds to a text the user sends to it ,replying to the users phone with a google map link showing its location. It was acurate, even from my works under ground car park, though sometimes I had to re-send the text more than once to get a response from it.
The 2nd tracking option which requires the user to log onto www.track188.com allowing them to see live tracking. Sadly I could never get it to work, it always showed my bikes location as downtown Hong Kong.
I don't doubt for a minute that the other ones I see for sale on ebay are clones in slightly varying packaging so the £10 one will be very similar to the £30 one.
LordShaftesbu...
PostPosted: 10:30 - 11 Feb 2013    Post subject: Reply with quote
I figured at that price I'd take the risk and ordered the one in OP's post. Will post again once I've tried it out.
StormCrow
PostPosted: 17:25 - 27 Feb 2013    Post subject: Reply with quote
Did anyone get any luck with this?
I ordered one - it's arrived but the fucking useless 'Chinglish' manual doesn't actually explain very much.
There are three wires, red, black and white. According to the manual, you only need to connect the red and black (power and ground) but it doesn't work. Don't get any response from the messages, the delivery reports indicate that they're not being received, and if I call the SIM then it goes straight to voicemail.
Anyone on here got one that actually works so that I can verify mine?
The seller is being useless - just keeps sending me links to the manual - it might as well still be in Chinese for all the use it is!
richfar
PostPosted: 19:18 - 27 Feb 2013    Post subject: Reply with quote
Same as you reckon mine was broke so had refund, was going to get another but dont think i will now.
StormCrow
PostPosted: 19:31 - 27 Feb 2013    Post subject: Reply with quote
Yeah - I've given the seller the option of refund or replace - but told them that I'll open a PayPal dispute in two days if I don't hear anything other than "please read this manual here"....
LordShaftesbu...
PostPosted: 11:15 - 10 Mar 2013    Post subject: Reply with quote
Did anyone get theirs to work? Mine's arrived but I won't bother fitting it if we've all been ripped off.
PostPosted: 12:25 - 10 Mar 2013    Post subject: Reply with quote
Lolwutf? "1. Usually battery car is 48V, and it can reach to 80V in high speed running process. In this way, the device is easy to be burn off. So it should connect one to two batteries for safe use. Because each battery is 12V, two batteries series will be 24V(equipment normal working voltage is 9-48V)."
Ummm... OK.
Maybe the seller only speaks Chinglish? Have you tried replying with "Used only number 1 special official fitter to comply best with instruction. Is not burn and inverse by not proper install but function not."
LordShaftesbu...
PostPosted: 15:45 - 15 Mar 2013    Post subject: Reply with quote
https://stream1.gifsoup.com/webroot/animatedgifs2/2054482_o.gif
Guess we've been suckered. Sad
The last post was made 13 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 88.06 Kb
