| clancy |
 clancy World Chat Champion
 Posted: 21:08 - 13 Feb 2013 Post subject: Looking at buying a 2001 cbr 900 rr ( been sorn for a while) |
Just wOndered if anyone has any tips on things to look for With them ? Any common issues or faults or tell tale signs of previous ones?
And any advice from previous owners
Thanks for any help, leigh ____________________ KLX 300r
| polar |
 polar Nova Slayer
| steady eddie |
 steady eddie Nova Slayer
| clancy |
| Benson_JV |
 Benson_JV World Chat Champion
| clancy |
| The Tot |
 The Tot World Chat Champion
 Posted: 18:38 - 14 Feb 2013 Post subject: |
Get a brew on! - shamelessly linked from a similar question. Mine's on 44k miles
So, my comprehensive list on what to look out for if you're buying an RRY-RR1
Regulator Rectifier - make sure that this and the alternator and battery are in good working order. If any one of the components is out of kilter, then you are in a nightmare situation. I was unfortunate with mine in that my alternator blew, so I had it rewound with a new reg rec and battery. I noticed that my Yuasa battery only lasted a year, so bought another replacement yuasa. 6 months later, the alternator and reg rec went again, taking the battery. So, to avoid the problem ever happening again, get a MOSFET shindingen reg rec (from an 09 R1), and bypass your wiring loom entirely so that your charging system goes directly between your battery, alternator and reg rec. Presumably I had a bad earth somewhere or a faulty loom that was causing a huge drain on charging!
Total Cost £800 when you include the fact I had to get 3 reg-recs,3 batteries and 2 rewound alternators + labour. All in a matter of 20k miles over 18 months!
Suspension - Look for a receipt for a suspension overhaul, both for front forks and rear shock. By 35-40k miles, it would be way past it! I was bottoming my forks out on relatively moderate A roads and it started wallowing about. Any suspension specialist such as MCT will sort it out for £500 odd and get it set up for your riding style. I had mine done at HM racing which included K tech springs front and rear to replace the worn OEM items and set up for A/B roads
Total Cost - £750 - That was all parts, labour and set up at HM racing. Turned it around in 2 days
Discs - 330mm discs are brilliant stoppers, but are known to warp. Mine warped at 32k miles. Rode them in winter mind. So saying that, take the opportunity to get a set of braking/galfer wavy discs and pads from calsport for cheaper than OEM replacement.
Total cost - £420 including fitting
Head bearings - Replace the ball bearings in your headstock with needle race bearings and you out to see a service life of 20k miles. I've had to replace mine twice in the time I've owned her, so they're about £80 quid including fitting. At your sort of mileage, be sure you've had them done within 10k miles.
Total cost - £160
Clutch and Camchain Tensioner - I used to commute in and around London, so I was pretty heavy on the clutch. OEM item went within 30k, so be sure you've had a replacement clutch put in, or budget for one. The CCT was replaced at 30k at the same time for good measure since it was starting to rattle pretty badly.
Total cost - £400
That's an exhaustive list of what I had done to my bike as part of "wear and tear" and normal operation. Considering I put close to 30k miles on her in 2 and a half years, with extensive use in winter and commuting in london, it was bound to take it's toll. I haven't accounted for tyres and chain and sprockets. My C&S kits usually last me a good 20k miles. Dunlop roadsmarts last 8k on the front and 6k on the rear.
Issues I've had with mine were a faulty cam position sensor - The sensor itself cost £140, but it required 5 hours to diagnose the fault so it was a bloody expensive fix in the end! So, if you notice that when you turn the bike on, you have no engine warning lights, the fuel pump primes, but you can't start it despite having full charge, then likelihood is that your cam sensor/cam pulse generator has gone.
I've had a few dodgy earths that have left me stranded as well!
So long and short is that if you're buying a bike from that era - RRY or RR1, you might be liable to electrical problems. If the bike has been kept outside for most of its life, then you WILL expect these problems. Don't take it from me, ask any "reputable" honda workshop. Mine's an extreme case, but even the guys at bransons in gloucester have started taking bets as to when I'm going to kill the bike!
Other useful mods include the following
PCIII and pipe - the 16 bit ECU is a bit snatchy at low speeds and it likes to hunt between 2-3k in 1st and 2nd gear. Pretty irritating when filtering. Get those items fitted and it'll mean smooth running.
Balance your throttle bodies every 20k miles to bring back the smoothness in your throttle response.
OEM Honda nissan pads work the best for the brakes. They work better than after market items, and are a tenna cheaper than EBC HH's at bransons!
Hope this helps! ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| clancy |
| The Tot |
| clancy |
| Noxious89123 |
 Noxious89123 World Chat Champion
| Clutchy |
 Clutchy World Chat Champion
| The Tot |
The last post was made 13 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
