valve spring removal
andym
PostPosted: 10:47 - 28 Feb 2013    Post subject: valve spring removal Reply with quote
I had a look for removing valve springs without special tools and came across this video:
https://www.youtube.com/watch?v=WIhWgWEnNQY
Has anyone else actually tried this?
Casper
PostPosted: 10:54 - 28 Feb 2013    Post subject: Reply with quote
You still fucking about with that fucked bike? Count your losses, brake it and make some cash back But keep the CDI and get this
https://www.gumtree.com/p/cars-vans-motorbikes/for-sale-zxr750-h1-1989/1009806333
2nd attempt to sell and reduced by 100 quid. Get a cheeky offer in.
andym
PostPosted: 11:02 - 28 Feb 2013    Post subject: Reply with quote
The only problem with that is I don't have any money left now otherwise I would and just bin the other one.
As for the video, turns out a socket, molegrips and a magnet work perfectly for removing and refitting
Marmalade
PostPosted: 11:03 - 28 Feb 2013    Post subject: Reply with quote
Yes. It does work. use the rag or everything slips and the collets fly off into the grass.
So I hear Embarassed
MaybeGuy
PostPosted: 11:25 - 28 Feb 2013    Post subject: Reply with quote
A valve spring compressor costs about 5 quid. Seriously.
You need one to put them back in anyway (if you want to do it properly and minimalise valve dropping risk).
I see no point in this method, and either way, using a sliding t bar with the socket on the end and a bit of bodyweight works better, and won't make everything fly out.
andym
PostPosted: 12:12 - 28 Feb 2013    Post subject: Reply with quote
What can I say, I'm a cheap f**ker.
Anyway, I found the socket with a magnet through the centre and a pair of molegrips works fine for removing them without bits flying off into the sunset.
For putting them back on, I just used a pair of pliers to push the spring back down and the collets fall into place.
I just need to get the valve grinder and paste then I can work on the old head
pits
PostPosted: 13:52 - 28 Feb 2013    Post subject: Reply with quote
I can see that it does work, but am I the only one who thinks that hammers shouldn't really be used on the inside of an engine?
Dead Blow to pop pistons out fine
Lump hammer to twat a starter motor
Nylon hammer to tap the head loose.
But a ballpin and a socket to remove valves, I just feel that it will one day end with disastrous consequences
PostPosted: 16:15 - 28 Feb 2013    Post subject: Reply with quote
Nothing wrong with that method - I've never see it done any other way. You've more chance of firing a collet into oblivion if you use the compressor IMO.
I sit the head on a thick layer of rags (usually a rolled-up lumberjack fleece) to prevent any valve damage and pop them all out in a couple of minutes with a hammer and spark plug socket.
nightshaddow
PostPosted: 17:32 - 28 Feb 2013    Post subject: Reply with quote
i use this method
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/423859_10150675182568846_942925731_n.jpg
you will need
an old socket with a quarter of it cut out,
a G clamp
small screwdriver or probe
open the G clamp and place flat side to the valve, place the socket on top and compress the spring, slide collets out with screwdriver, remove tension then clamp and socket slide the spings off and if required the valve out
andym
PostPosted: 18:04 - 28 Feb 2013    Post subject: Reply with quote
OK if I could edit MP4's I'd have edited out all the crap, but a couple of videos I've just done for removing and refitting valve springs:
Removing: (Note the lack of hammer) https://www.youtube.com/watch?v=9Ph3Y9cEDUU
Fitting: (needle nosed pliers just to position the collet) https://www.youtube.com/watch?v=t_8hpMjLma0
Nothing lost, nothing flying around, nothing getting it's brains bashed in.... and more importantly, no buying special tools or adapting tools
MaybeGuy
PostPosted: 22:24 - 28 Feb 2013    Post subject: Reply with quote
much better method IMO Thumbs Up
wilz1234
PostPosted: 22:51 - 28 Feb 2013    Post subject: Reply with quote
Whats stopping the valve moving with the top of the spring? If its on a table, it seems a good way to bend a valve stem
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
andym
PostPosted: 23:05 - 28 Feb 2013    Post subject: Reply with quote
Not sure I totally understand your question there wilz.
But everything is on an 8x folded dust sheet, on a thick carpet with underlay, it would take an awful lot of force for it to hit something solid enough to bend a valve, and the method I used probably pushed down less than 1cm, as far as I'm aware the valves don't actually move when doing this as I have to turn the whole thing over and actually press the valves out afterwards.
***edit***
OK I just had to test out your theory there wilz, I couldn't be bothered to set up the camera to check so you'll have to take my word for it... but the valve itself does not move in the slightest using this method
PostPosted: 00:23 - 01 Mar 2013    Post subject: Reply with quote
You stick a rag under the valve head. This method has been used for donkey's years.
Walloper
PostPosted: 11:55 - 01 Mar 2013    Post subject: Re: valve spring removal Reply with quote
It wasn't a 'Mechanic' who showed him that 'trick'.
It was one of those Antipodean Fitter-Welders that they are aye harping on about.
It is a fucking moronic way to do a very simple job when £14 will buy you a tool to do it safely.
Fackin' Ozzis Rolling Eyes
https://compare.ebay.co.uk/like/310568484179?var=lv<yp=AllFixedPriceItemTypes&var=sbar&cbt=y
MaybeGuy
PostPosted: 14:42 - 01 Mar 2013    Post subject: Re: valve spring removal Reply with quote
Er no, mechanics are the sort of monkeys that would ask someone for advice on how to repair the valve they just clobbered to death. They're unskilled labourer scum that think they can rip people off.
Islander
PostPosted: 15:16 - 01 Mar 2013    Post subject: Re: valve spring removal Reply with quote
mattsprattuk wrote:
Er no, fitters are the sort of monkeys that would ask someone for advice on how to repair the valve they just clobbered to death. They're unskilled labourer scum that think they can rip people off.
FTFY. Thumbs Up
MaybeGuy
PostPosted: 15:30 - 01 Mar 2013    Post subject: Reply with quote
Good thing I'm neither then isn't it Wink
Walloper
PostPosted: 15:32 - 01 Mar 2013    Post subject: Reply with quote
Oh you have certainly proved that mate. Wink
MaybeGuy
PostPosted: 15:34 - 01 Mar 2013    Post subject: Reply with quote
pffahaha, and what are you supposed to be?
Walloper
PostPosted: 15:51 - 01 Mar 2013    Post subject: Reply with quote
Are you Measuring cocks now? Wink
Islander
PostPosted: 21:09 - 01 Mar 2013    Post subject: Reply with quote
With a combination spanner? Laughing
The last post was made 13 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 121.78 Kb
