Bandit, sitting a while, front wheel seized.
mysterious_rider
PostPosted: 14:28 - 02 Mar 2013    Post subject: Bandit, sitting a while, front wheel seized. Reply with quote
Hi guys, trying to get the bandit on the road and I just can't unseize the front wheel. The brakes have been overhauled with new pads, new HEL lines, and fluid.
I took it for a quick spin and it rode okay but if you put it on a stand and try and move the wheel by hand, it's super stiff. And i can't ride around trying to free it off because it needs an MOT.
Ripped apart the calipers and popped the pistons out halfway, and cleaned them up with a toothbrush, yet they still stick??
Any ideas why?/
KAWASAKIIIII
Quote Me Happy
PostPosted: 14:32 - 02 Mar 2013    Post subject: Reply with quote
How easily did the pistons move?
It could be corrosion behind the seals.
PostPosted: 14:34 - 02 Mar 2013    Post subject: Reply with quote
They are twin piston sliding calipers on the 600. My bet would be that they are not sliding on the pins.
If so whip the calipers off and get them off the pins on the carriers. Clean them up and lube them and reassemble
mysterious_rider
PostPosted: 14:38 - 02 Mar 2013    Post subject: Reply with quote
cheers lads I'll try the grease method first. And particular grease I should use kickstart?
KAWASAKIIIII
Drake
PostPosted: 15:58 - 02 Mar 2013    Post subject: Reply with quote
red rubber grease on brakes
PostPosted: 16:02 - 02 Mar 2013    Post subject: Reply with quote
Not on sliding pins, normal LMP will suffice.
OP: drop the calipers off and check the wheel again, in case the bearings have seized.
The last post was made 12 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 48.28 Kb
