Honda cg 125 expert requred xD
Mini Stalk
PostPosted: 19:34 - 06 Mar 2013    Post subject: Honda cg 125 expert requred xD Reply with quote
Hi guys my mates cg 125 kickstart isnt returning, once i have striped down the top end can i get away with just taking the left engine casing off after removing the flywheel or do i need to take the cluch assebly and oil pump off?
Thanks
Dave
Old Bikes; 2004 Piaggio Zip 50, 2005 Piaggio Zip 125, 1984 Honda Cb 125, 1982 Honda Cm125, 1984 Honda Cm 125, 1992 Yamaha Sr 125 Ratbike, 2010 Lexmoto XTR 125
Current Bike; Sachs Xtc 125
Mini Stalk
PostPosted: 20:06 - 06 Mar 2013    Post subject: Reply with quote
sorry ignore my post, after a careful read of haynes manual turnes out i cant :/ ohhh well. Thanks for looking anyway Smile
tomh
PostPosted: 21:37 - 06 Mar 2013    Post subject: Reply with quote
As you realised the whole clutch side needs to come off. I've got away with leaving the oil pump on as the two screws are easily rounded off so I found it easier to leave in place. The screws are the same on the centrifugal filter cover but that's needs to come off to remove the clutch. Use a Phillips screwdriver bit not a pozi drive while pushing to avoid rounding them off Wink
numpty2
PostPosted: 22:36 - 06 Mar 2013    Post subject: Reply with quote
Make sure it is worth the effort. My mate hand a Honda 250 for many years in which the kickstart was held up by a bungee strap. He unclippped it to start the bike, and then hooked it back up.
I'm just saying that if the bike is near death, it might not be worth all the effort. But would the bungee strap technique pass an MOT?
numpty2
PostPosted: 17:57 - 07 Mar 2013    Post subject: Reply with quote
Bungees = a significant contribution to all biking, along with cable ties, jubilee clips & PVC tape.
I'd really be tempted to bodge & make do. On a humble CG it sounds like an awful of of work, and there is always a risk of doing expensive damage to the engine in any strip down procedure. Why not get a selection of bungees to match your mood - pink, yellow, black etc.
von1papen
PostPosted: 09:19 - 08 Mar 2013    Post subject: Reply with quote
From memory as I recently rebuilt my CG's engine (gearbox problems), you only have to remove the clutch side case, rather than splitting the cranks.
Don't think it was massively accessable without removing the clutch assembly though
bikenut
PostPosted: 11:13 - 08 Mar 2013    Post subject: cg125 engine Reply with quote
:D check out cmnsl for the exploded views........ :D
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 55.75 Kb
