| Mini Stalk |
 Mini Stalk Renault 5 Driver
| Mini Stalk |
 Posted: 20:06 - 06 Mar 2013 Post subject: |
sorry ignore my post, after a careful read of haynes manual turnes out i cant :/ ohhh well. Thanks for looking anyway  ____________________ Old Bikes; 2004 Piaggio Zip 50, 2005 Piaggio Zip 125, 1984 Honda Cb 125, 1982 Honda Cm125, 1984 Honda Cm 125, 1992 Yamaha Sr 125 Ratbike, 2010 Lexmoto XTR 125
Current Bike; Sachs Xtc 125 |
| tomh |
 tomh Scooby Slapper
 Posted: 21:37 - 06 Mar 2013 Post subject: |
As you realised the whole clutch side needs to come off. I've got away with leaving the oil pump on as the two screws are easily rounded off so I found it easier to leave in place. The screws are the same on the centrifugal filter cover but that's needs to come off to remove the clutch. Use a Phillips screwdriver bit not a pozi drive while pushing to avoid rounding them off  |
| numpty2 |
 numpty2 Trackday Trickster
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 09:04 - 07 Mar 2013 Post subject: |
whole clutch side?I think the term is 'split the crankcases'.
Most cg's have the kickstart return spring pinned on the kickstart shaft and its impossible to replace the spring without splitting the crank cases.
My quick fix,use a bungee to pretension the kickstart,or fit a fancy modern electric start engine,although the electrics will need changing,
bungees,a significan t contribution to modern classic biking.
the springs on cg's seem to knacker very easy when they've been stood for years and then returned to life.NEVER BUY A PATTERN KICKSTART SPRING,since you have to split the crankcases to fit it. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| numpty2 |
| von1papen |
 von1papen Spanner Monkey
| bikenut |
 bikenut World Chat Champion
The last post was made 13 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
