| mudcow007 |
 mudcow007 World Chat Champion
| CarlosCBR |
 CarlosCBR World Chat Champion
| Shinigami |
 Shinigami World Chat Champion
| Islander |
 Islander World Chat Champion
| mudcow007 |
| toppetsaha |
 toppetsaha Two Stroke Sniffer
 Posted: 22:43 - 04 Mar 2013 Post subject: |
ooohhhh .... stick a set of flat handlebars on that  |
| mudcow007 |
 Posted: 22:13 - 06 Mar 2013 Post subject: |
Men & Women of BCF lend me your ears........
right finally got a chance to check the relay on my indicators
its rated as :-
23W x 2 + 3.4 (4) W
21W x 2 + 3.4 (4) W
indicators on the bike have 10w bulbs in
is my relay rated at 23W max so i will need 5W bulbs?
or am i getting this the wrong way?
Gracias
| Islander |
 Posted: 22:45 - 06 Mar 2013 Post subject: |
That's rated for 2 x 21W indicator bulbs per side + 1 x 4W bulb for the tell tale. Remember you'll only ever have two bulbs plus the tell tale active at any time.  |
| CarlosCBR |
| mudcow007 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 08:57 - 07 Mar 2013 Post subject: |
freinds, romans, bcf rs, give me your CG's.
another good cure for dodgy cg indicators is ...remove them,especially on a custom.It is more dangerous of course but you'll look cooler when you get t boned.
p.s..remember that the wrong wattage rated indicator relay box can also cause the indicators to stay on,usually a relay too higher wattage ,stays on,your lower wattage makes em flash too quick.
pps check out any dodgy earths. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Shinigami |
| Islander |
 Posted: 12:16 - 07 Mar 2013 Post subject: |
Yep. As above, you're only using half the rated capacity of the relay which means that the bimetallic element won't be heating and switching. You could do one of two things here:
1. Change the relay for a load independent electronic one.
2. Fit 21W bulbs to the indicators.
Either will sort the problem for you.  |
| mudcow007 |
 Posted: 08:42 - 08 Mar 2013 Post subject: |
| Islander |
 Posted: 10:09 - 08 Mar 2013 Post subject: |
If you buy a load independent electronic relay...
The last post was made 13 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
