| nhewitt |
 nhewitt Two Stroke Sniffer
| frostage |
 frostage Borekit Bruiser
| wots |
 wots World Chat Champion
 Posted: 20:55 - 13 Mar 2013 Post subject: |
Carb off and clean float bowl etc.
Worked with two scoots I've had recently with exact same issue, one was a 50cc 2 stroke and another a 250 4 stroke.
Carb off, can of carb cleaner and go to town it. Float bowl off and make sure there is no nastiness in there. Make sure you get a carb cleaner with the long pipe on and stick it in every orifice! ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| nhewitt |
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 21:06 - 13 Mar 2013 Post subject: |
Have you tried a new plug or cleaned old one up
Most 2t will oil plugs up ... Are you running it premixed? ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| bradh511 |
 Posted: 21:08 - 13 Mar 2013 Post subject: |
Also check all the jets sent blocked ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| J.M. |
 J.M. World Chat Champion
| nhewitt |
| nhewitt |
| nhewitt |
| J.M. |
| bradh511 |
 Posted: 21:44 - 13 Mar 2013 Post subject: |
Do you have to bump start the bike ? Also I'm wondering about a csi fault... But that a cdi and coil pack all in one I would check reads are in correctly I have seen them put in upside down before but can't remember if here's any thing stopping u doing this ... I would comp test the bike also just pull reads out and look for piston scoring if I remember right just look in reed inlet to barrell also is there any cracks in carb rubber and the sitting right it will not rev if u do not have air filter use a pair of tights folded a fewtimes to restrict air if when it's running and u rev it goes burrr then your in need of a filter the reason say to check piston is any marks or scores the bike may have been heat seized ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| nhewitt |
| nhewitt |
| Rogerborg |
 Rogerborg nimbA
| nhewitt |
The last post was made 13 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
