No power and stalling when accelerating
nhewitt
PostPosted: 19:17 - 13 Mar 2013    Post subject: No power and stalling when accelerating Reply with quote
I have a 2002 Derbi Senda 50.
The bike was due to be sold today and when I started it up to give it a quick run about it just wouldn't move.
It starts first time and idles but when I put it into gear and let the clutch out it sounds very boggy and travels at about 1mph and when i stop it just cuts out.
Brand new spark plug, reg/rec, battery etc, the carb has the correct main jet inside.
I have played around with the idle screw and air mixture screw but its no better.
I have taken the air filter off in my garage and started it up and the revs went very high but again no power on acceleration.
frostage
PostPosted: 20:29 - 13 Mar 2013    Post subject: Reply with quote
Compression?
2000 Gixxer 750
1995 RM 250
wots
PostPosted: 20:55 - 13 Mar 2013    Post subject: Reply with quote
Carb off and clean float bowl etc.
Worked with two scoots I've had recently with exact same issue, one was a 50cc 2 stroke and another a 250 4 stroke.
Carb off, can of carb cleaner and go to town it. Float bowl off and make sure there is no nastiness in there. Make sure you get a carb cleaner with the long pipe on and stick it in every orifice!
nhewitt
PostPosted: 21:00 - 13 Mar 2013    Post subject: Reply with quote
I will give the carb a good clean tomorrow. the float bowl seemed fine this morning when i changed the jet.
Would a clogged air filter stop the bike from moving at all?
i took the filter off and it ran the same just alot higher revs when at idle.
bradh511
PostPosted: 21:06 - 13 Mar 2013    Post subject: Reply with quote
Have you tried a new plug or cleaned old one up
Most 2t will oil plugs up ... Are you running it premixed?
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
bradh511
PostPosted: 21:08 - 13 Mar 2013    Post subject: Reply with quote
Also check all the jets Smile sent blocked
J.M.
PostPosted: 21:09 - 13 Mar 2013    Post subject: Reply with quote
Potentially. However if it ran the same without the air filter then I wouldn't presume that to be the issue.
Essentially without the air filter, your mixture will run leaner because the air flow is less restricted. A clogged air filter will make it run richer. If there is not enough air, the mixture will not run at all.
My thoughts would be with a clogged jet or bad fuel.
2004 R1 & 2018 XSR900
nhewitt
PostPosted: 21:12 - 13 Mar 2013    Post subject: Reply with quote
seperate oil tank and i changed the plug last week and the old one was brownish so a good plug. took the new one out today and its a little bit sooty.
The kicks over every single time its just when i go into first gear and accelerate there is literally nothing there, and then it cuts out when i take the revs off.
it idles perfectly fine and when i took the air filter off there was no power at all again, but the revs were alot higher and it didnt cut out when i took the revs off.
nhewitt
PostPosted: 21:15 - 13 Mar 2013    Post subject: Reply with quote
I upjetted the carb this morning as the previous owner didn't do this after putting a new exhaust on there.
I started the bike and took the fuel pipe off the carb and fuel was coming out with a good free flow
nhewitt
PostPosted: 21:17 - 13 Mar 2013    Post subject: Reply with quote
Am i correct in thinking that if the air/fuel mix was wrong the bike will still ride to an extent. as at the minute it isn't going for more than a few metres
J.M.
PostPosted: 21:36 - 13 Mar 2013    Post subject: Reply with quote
Of course. Checking the colour of your spark plugs would probably verify this!
bradh511
PostPosted: 21:44 - 13 Mar 2013    Post subject: Reply with quote
Do you have to bump start the bike ? Also I'm wondering about a csi fault... But that a cdi and coil pack all in one I would check reads are in correctly I have seen them put in upside down before but can't remember if here's any thing stopping u doing this ... I would comp test the bike also just pull reads out and look for piston scoring if I remember right just look in reed inlet to barrell also is there any cracks in carb rubber and the sitting right it will not rev if u do not have air filter use a pair of tights folded a fewtimes to restrict air if when it's running and u rev it goes burrr then your in need of a filter the reason say to check piston is any marks or scores the bike may have been heat seized
nhewitt
PostPosted: 21:45 - 13 Mar 2013    Post subject: Reply with quote
took the plug out last week a brownish colour indicating a good plug. replaced with a new one and today it is a bit sooty.
nhewitt
PostPosted: 21:52 - 13 Mar 2013    Post subject: Reply with quote
It kick starts first time every time.
The bike has never got hot at all so shouldn't be a heat seize anywhere.
when i rev it with or without the air filter on is just sounds boggy like its trying to find something but just doesn't have the energy lol.
the carb its sitting in nice and tight. i just don't understand it ran perfect last week.
PostPosted: 22:24 - 13 Mar 2013    Post subject: Reply with quote
You did something to a running bike and now it's not running? Thinking
Jet too big = flooding. Or you've not put it in securely, or have messed up the needle. Whatever you did, CTRL-Z that sucker and undo it.
nhewitt
PostPosted: 22:29 - 13 Mar 2013    Post subject: Reply with quote
The jet was too small as it had the original jet and it has been derestricted, with an aftermarket air filter and exhaust so I fit the new one earlier.
The bike was running like this the other morning also, I just haven't had time to look at it due to bad weather outside!
The last post was made 13 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 90.33 Kb
