France: compulsory reflective stickers on all helmets
Bike Chat Forums Index -> Touring & Exploration Goto page 1, 2, 3, 4  Next
willis1337
PostPosted: 14:07 - 17 Mar 2013    Post subject: France: compulsory reflective stickers on all helmets Reply with quote
https://ukfrancebikers.com/2013/03/16/france-compulsory-reflective-stickers-on-all-helmets/
I appreciate that this has been an ignored law for a long time but the french are now said to be applying it as the reflective vest thing has been done away with now. See above link. It is currently in force so anyone going to france soon should consider if they want to risk the fine (and points?) or get some stickers as per the regulation:
"All helmets must have four reflective stickers: one on the front, one at the rear and one on each side. The surface of each sticker must be 18 cm2 and, within each sticker, you must be able to draw a 40 mm diameter circle, or a 12.50 cm2 rectangle with a minimum of 20 mm length."
Also they "should not be removable without damaging the helmet and must remain reflective over time. They must also be water resistant and not interfere with the opening and closing mechanism of the helmet."
I am unable to find anywhere that sells regulataion size stickers in white. I have found some on "Get Geared" but despite them stating they are compulaory in France what they are selling are too small and so would not meet the regulatatory size.
I have heard that new helmets sometimes come with these stickers in the box with a leaflet stating what they are for. I have emailed Shoei asking if they sell the regulatory stickers and if so where (awaiting reply).
Does anyone know anywhere that sells regulaion size stickers to avoid falling foul of the gendarmes when away?
Hopefully the FFMC will get rid of this silly regulation in the same way they got rid of the reflective vests.
Current bike: KTM SD1290GT
Previous bike: BMW K1300S
Marmalade
PostPosted: 14:24 - 17 Mar 2013    Post subject: Reply with quote
I'll make you some if you want.
Let me know sizes and colours. the reflective vinyl is the same as used on some road signs so will last as required.
PostPosted: 15:21 - 17 Mar 2013    Post subject: Re: France: compulsory reflective stickers on all helmets Reply with quote
Unfortunately I've lost the pics, but Bendy did me a lovely scene on the Back of my Shoie Hornet with reflective flowers and 'hornets' (which looked more like friendly bees - ok I was thinking something a bit more manly like some flames etc, but it came out well regardless.)
You can get rolls of the reflective tape on ebay - I've liberally stuck it over bikes I've been doing lots of miles.
One of the ones used on the hemlet was a black tape which only shows up as reflective under head lights etc - and does seem to work quite well. So in the day, it just looks standard black, but at night with a light shined on it, it shows up well.
Marmalade
PostPosted: 17:05 - 17 Mar 2013    Post subject: Reply with quote
Thought I'd better comply as they are enforcing it now.
These should meet the need.
https://i370.photobucket.com/albums/oo141/bramble43/Img_3716_zps5eb31971.jpg
https://i370.photobucket.com/albums/oo141/bramble43/Img_3713_zps7407c16b.jpg
https://i370.photobucket.com/albums/oo141/bramble43/Img_3711_zpsc4c7eb53.jpg
noobRider
PostPosted: 17:20 - 17 Mar 2013    Post subject: Reply with quote
One more thing to do before our trip. Jeez.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Musketeer
PostPosted: 17:22 - 17 Mar 2013    Post subject: Reply with quote
Marmalade's photo....
Empty tills with hands up? Not DOable Wink
willis1337
PostPosted: 19:15 - 17 Mar 2013    Post subject: Reply with quote
I have circulated this round the group going on tour:
https://cgi.ebay.fr/6-BANDE-CASQUE-ADHESIVE-RETRO-REFLECHISSANTE-9x2cm-AUTOCOLLANTE-BLANCHE-BLANC-/180789191773?pt=FR_JG_Loisirs_Scrapbooking&hash=item2a17e0245d
So far I have a request for 3 x white, 1 x yellow and 1 x orange. The "get geared" ones are too small for regs, these are just right size. Personally I'll put up with it but would prefer something a bit more "arty" as my helmet is this:
https://www.ghostbikes.com/products/Helmets-Motorcycle-Helmets/1323-Shoei-XR-1000-Rogue-Motorcycle-Helmet-.html
Can you make the "standard" ones? In different reflective colours? Let me know and I'll pass on to the group. Also any suggestions on something for my helmet to comply with law but fit with design?
Thumbs Up cheers
Marmalade
PostPosted: 19:50 - 17 Mar 2013    Post subject: Reply with quote
As to comply they have to be have either a 4cm radius or 12.5cm area rectangle with 2cm length it is always going to interfere with the design, unless the side ones were made to go on the visor, the unused bits on the side that you can't look through anyway.
I'll make some of these standard ones but....
Are these regulation ones actually meeting the regs? If they are 2x9cm as stated but with rounded corners then they are just short of 18cm2 surface area.
I know it would take a real anal tossbag of a copper to stick you on for it but still.
So i'll make mine a mm or so bigger just in case.
I have white, red, blue, yellow and green reflective vinyl here
willis1337
PostPosted: 20:21 - 17 Mar 2013    Post subject: Reply with quote
Thanks marmalade. I prefer rounded corners to squarely cut off but see your point re the regs and gendarmes can be sticklers when it comes to the roast beefs, so your idea to make the sticker a couple of mm bigger to compensate is good thinking.
I'll put the query to the group and suggest we get from you rather than the french ebay site, assuming you're okay to make a batch. So far I have the following wanted:
3 sets of four white stickers
1 set of four yellow stickers
1 set of four blue stickers
Just thinking, would the sticker going on the front of the helmet need to have a curve to allow for the curve of the chinguard of the helmet?
BTW may be worth you putting up a set on ebay as I am sure they'll be others looking for this. Also what's your cost for doing this?
willis1337
PostPosted: 20:53 - 17 Mar 2013    Post subject: Reply with quote
Another set of white wanted.
willis1337
Marmalade
PostPosted: 21:17 - 17 Mar 2013    Post subject: Reply with quote
Here we go. 91mm x 21mm which will more than cover for the rounded corners.
I've put them on ebay as well as my shop.
Ebay link or Buy from the shop
Enter 527d416aca into the coupon/discount box at checkout in my shop for 20% off the total amount before 1st May.
EDIT: New code valid to 1 July 'bcfdiscount' enter it in the box at checkout.
https://i370.photobucket.com/albums/oo141/bramble43/Reflective91x21mm-600_zps371be21d.jpg
Rogue_Shadow
PostPosted: 21:25 - 17 Mar 2013    Post subject: Reply with quote
So the new Caberg helmet I've just brought for a Trip to France, has to be covered with horrible reflective UN removable stickers!
Evil or Very Mad
Hurray!
Marmalade
PostPosted: 21:28 - 17 Mar 2013    Post subject: Reply with quote
Evil or Very Mad
Hurray!
Yes. That just about covers it.
noobRider
PostPosted: 21:55 - 17 Mar 2013    Post subject: Reply with quote
Nice job Marmalade. I'll get my order in.
Rogue_Shadow
PostPosted: 22:10 - 17 Mar 2013    Post subject: Reply with quote
I'll add them to the Wish list on ebay Sad
Cheers Marmalade Thumbs Up
yen_powell
PostPosted: 22:11 - 17 Mar 2013    Post subject: Reply with quote
Can they be white flag shaped rectangles with the letters C.E.S.M. on them in honour of our brave gallic cousins across the channel?
XT1200Z and a DR350 in bits
willis1337
PostPosted: 22:20 - 17 Mar 2013    Post subject: Reply with quote
Marmalade
PostPosted: 22:27 - 17 Mar 2013    Post subject: Reply with quote
I can specially cut whatever you like but probably best to put different coloured reflective on top of the white rather than cut holes into the white so that it is still a solid reflective block that should still be legal.
willis1337
PostPosted: 22:41 - 17 Mar 2013    Post subject: Reply with quote
Nice one marmalade. I've emailed the group so they're all be ordering direct. Karma
(PS I don't think the discount code you put above is working on your site).
Hamayar
PostPosted: 22:53 - 17 Mar 2013    Post subject: Reply with quote
Damn, That really is ridiculous
Bunch of robbing gits.
Never liked France only go there on the way to elsewhere and if the chunnel wasnt there would touch the place.
Ill risk tunnel ride up to Belgium, but if I get pulled once Ill never go to Frogland again.
Pity, as I did like the chunnel.
Current bikes: CBF600Cowl GL1500SE...
Recent bikes since 2000: ST1100 TCS ABS VTX1300C ZZR1100D1 GS500S DR750 XJ600S GL1200DG
Marmalade
PostPosted: 22:56 - 17 Mar 2013    Post subject: Reply with quote
Sorry. I hadn't confirmed it. It should work now.
willis1337
PostPosted: 23:19 - 17 Mar 2013    Post subject: Reply with quote
No worries, ordered already anyway. I've also posted a link (currently awaiting moderation) to your ebay shop on the UK France Bikers.com link in my original post above, as a few are saying they can't find anywhere to buy the regulatory stickers in the UK Wink Thumbs Up
I noticed the details on ebay say very sticky may take helmet paint with them if removed. I understand that has to be the case to meet the silly french law, however in reality could they be removed without damaging the helmet's paint? using hairdryer? As at the price your selling I was planning on putting them on when in france then removing them at first opportunity when I leave the country. ie getting a set each trip.
Joncrete Cungle
PostPosted: 23:29 - 17 Mar 2013    Post subject: Reply with quote
The ferry straight to Santander or Bilbao has never looked more appealing! Silly cheese eating surrender monkeys.
Marmalade
PostPosted: 23:35 - 17 Mar 2013    Post subject: Reply with quote
Thank you Thumbs Up
You 'may' be able to get them off but I've tried to get this stuff off after making a balls up of sticking it on and it sticks like shit to a blanket. It is the same stuff used to make some road signs and as you can imagine it is meant to stay there for a while.
I'll stick some on an old helmet and have a go getting it back off.
The last post was made 13 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 135.95 Kb
