Bike still cutting out in the wet
J.M.
PostPosted: 19:24 - 23 Mar 2013    Post subject: Bike still cutting out in the wet Reply with quote
Bugger.
https://sphotos-e.ak.fbcdn.net/hphotos-ak-ash4/317528_556561484378819_134680059_n.jpg
GS500 2004.
Essentially as the bike gets wet. One (right) cylinder starts to intermittently work. As you progress, it'll just stop working completely.
Moving from a standstill requires a lot of clutch slipping and yields the performance of a 50cc ped.
Motorway at full throttle just maxes out at about 7k RPM, so you can get a 50mph.
Eventually it got to the stage where the engine was just completely cutting out.
What I have done:
- Replaced spark plugs with known working ones
- Replaced coils/ht leads/ht caps with known working ones
- Gone over all the wiring of the bike that I could see with heat shrink
- Removed all accessories from the bike
I'm thinking there must be a connection somewhere which is earthing once wet.
Does anybody have any clues what to check?
2004 R1 & 2018 XSR900
PostPosted: 19:29 - 23 Mar 2013    Post subject: Reply with quote
Have you checked the coils themselves.
WD40 the lot, sand down where they bolt to frame.
Cover it in silicone spray and let it set. Happened to my Bandit 600, died in rain only... did that and problem went away Thumbs Up
Scythe
PostPosted: 19:32 - 23 Mar 2013    Post subject: Reply with quote
Fit a fender extender to front mudguard to stop water getting kicked up?
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
PostPosted: 19:34 - 23 Mar 2013    Post subject: Reply with quote
Plugs are on the sides. Expect both to die if that was the case.
J.M.
PostPosted: 19:35 - 23 Mar 2013    Post subject: Reply with quote
Well the coils were replaced. Replaced them as an entire unit of Coil -> Lead -> Cap.
Rides exactly the same as before. Makes me hesitate that there may be an electrical issue before the coils.
Hmm. Got any ignition wires exposed at all? Like absolutely anything in direct path of water.
J.M.
PostPosted: 19:37 - 23 Mar 2013    Post subject: Reply with quote
Nope. Even covered all exposed wires in insulation tape just to make sure.
PostPosted: 19:38 - 23 Mar 2013    Post subject: Reply with quote
Wanna buy my CBR. Laughing
J.M.
PostPosted: 19:40 - 23 Mar 2013    Post subject: Reply with quote
I can't afford to buy/insure nice bikes Sad
bladerunner
PostPosted: 20:04 - 23 Mar 2013    Post subject: Reply with quote
Switch gear or loom going to them suffering water ingress? Try disconnecting the kill switch connector when at home and hit it with a hose pipe. Also steam rising from the engine/ rad condensing under the tank and dropping onto the loom and ht side of things can give issues. Finally is the motor water tight where the pickup leads exit?
YBR Ric
PostPosted: 20:30 - 23 Mar 2013    Post subject: Reply with quote
Spray the water over it at night and look for any electrical arcing which would almost be invisible during the day.
Clutchy
PostPosted: 00:57 - 24 Mar 2013    Post subject: Reply with quote
Not really sure how to word this, ill give it a go, someone please correct/help me!
The electrical component that generates the spark (is it known as a distributor on a bike?) could be an issue, water could be getting in but I imagine that would affect the other cylinder aswell? Neutral
If not keep working backwards?
Clutchy
PostPosted: 01:00 - 24 Mar 2013    Post subject: Reply with quote
If not can we not go back to looking at the carbs?
Long shot but is there a chance that water could be getting in at any point (assuming all issues are because of the rain) on the carb and diluting the petrol to a point where it wont spark?
Is there anyway where you can get the bike to cut out like before and test to see if the plug actually sparks off the block to test?
haroman666
PostPosted: 01:15 - 24 Mar 2013    Post subject: Reply with quote
^^^ Think they're CDI unit, like the Bandits.
If it's CDI problems then good luck to you sir. I believe you can open them up and replace a capacitor or resistor or something in there, but it's not easy (Saw a thread on some other website, i'll see if I can find it, although it's for a Bandit)
Or a replacement for >£100.
Have you got a wiring diagram for the ignition system? Might be worth getting one and just going over everything that goes between Battery, signal generator, CDI, coils, plugs.
As said in your last thread: WD EVERYTHING!!.
J.M.
PostPosted: 11:39 - 24 Mar 2013    Post subject: Reply with quote
I'll try to answer in order:
@Blade
I doubt it will be anything like the kill switch, as those circuits completely cut both cylinders from sparking. The issue seems to be that the spark gets progressively weaker until it just can't spark.
I will look at the wiring diagram later today... although I've left my manual at my other address 30 miles away Doh!
My hope is that the coils are attached in series rather than parallel, with the left coil being before the right coil. If that's the case then I suspect a dodgy earth before the left coil, meaning the right coil is getting progressively less voltage until it cuts out, then the left cylinder does the same.
It's also worth noting... in the wet the backlights for the clocks seem to vary in brightness depending on RPM. This doesn't happen in the dry. The last time that happened, I had a charging fault which I fixed (but not this present fault).
@YBR, cool idea to try, thanks
@Clutchy, carbs aren't the issue. There will physically be no spark present, rather than just a terrible mixture. I have managed to reproduce it on one occasion (before replacing the coils+leads+caps) by chucking water all over the front of the bike.
@Haroman
Mine is CDI, yes. It has a range of confusing gizmos on the bike, like a throttle position sensor and an air flow sensor, along with a CDI and a signal generator to tell the coils when to spark, on a carbed bike.
I have a wiring diagram, but it's in my manual 30 miles away. I think I have a PDF on my laptop too though, which I shall be looking for/through today.
WD shall be coming to play I feel, yes.
sickpup
Old Timer
PostPosted: 12:08 - 24 Mar 2013    Post subject: Reply with quote
Is it a single twin lead coil or two single lead coils?
TotalGSXR
PostPosted: 12:16 - 24 Mar 2013    Post subject: Reply with quote
Two separate coils on GS500s.
J.M.
PostPosted: 12:50 - 24 Mar 2013    Post subject: Reply with quote
Two single lead coils. On this model they both use a single pulse generator (I think that's the name?), whilst earlier models had two pulse generators (one for each).
Vincent wrote:
Sorry if mentioned already but have you tried swapping coils to see if the problem changes cylinders?
I replaced both sets of coils, as a complete unit with the ht lead and caps attached. Utilising the same spacers/bolts as the previous coils though.
I think I can be fairly certain (although not 100%) that the coils aren't inherently to blame because of replacing them both and having the exact same symptoms as before.
PostPosted: 12:52 - 24 Mar 2013    Post subject: Reply with quote
You replaced both.
Do you remember your old working one, tried that on the currently broken side? Doubt you would have 2 faulty coils but... I would have swapped and seen if it was the coil breaking down or some wiring somewhere.
Well, you have 2 weeks or so it strip absolutely everything electrical off and check for everything.
Start with the loom Laughing
moppy
PostPosted: 12:57 - 24 Mar 2013    Post subject: Reply with quote
Wanna buy my ZZR then? Mr. Green
Don't have anything to contribute, but will stick around to learn something new.
J.M.
PostPosted: 12:58 - 24 Mar 2013    Post subject: Reply with quote
Unfortunately I left the other coils back in Birmingham... so I can't try those until I'm back there.
Although I may go back sooner than 2 weeks. I'll look for a dry day after a week or so and go for it probably. Need to see that girl ASAP because I have been, quite frankly, ruining all chances with her slowly since Saturday morning. Laughing
As for the ZZR... I would love one. However insurance still says no... at that was before my fault accident.
Alpha-9
PostPosted: 13:03 - 24 Mar 2013    Post subject: Reply with quote
Pour small amounts of water on bits of the bike while it's running to try and isolate the problem area?
Fzr-600 1999
J.M.
PostPosted: 13:10 - 24 Mar 2013    Post subject: Reply with quote
Yeah, I'll be trying that Alpha Smile
Okay... just been looking at the wiring diagram. TotalGSXR has sent me a photocopy of his manual's wiring diagram, thank you! Very Happy
From the CDI, 1 wire goes to a solenoid, which then goes directly to the coils. The diagram makes it appear that the coils are ran in parallel rather than in series.
I anticipate that my first port of call shall be to track down this wire + solenoid and check it for defects.
sickpup
Old Timer
PostPosted: 13:40 - 24 Mar 2013    Post subject: Reply with quote
DO you have a copy of a wiring diagram you can post for me to look at?
The last post was made 13 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 127.95 Kb
